Author Topic: [IC] Krytox GPL 205 G2 grease  (Read 10258 times)
Offline AdrianMan
« on: Sat, 16 May 2020, 07:58:07 »
Hi everyone !
   This is an interest check for Krytox GPL 205 Grade 2 grease
   Compared to Krytox GPL 205 Grade 0 the only difference is in consistency:
  Grade 2: Normal Grease (Peanut Butter Consistency)
vs
 Grade 0: Very Soft Grease (Brown Mustard Consistency)
Grade 2 has the same uses (stabilizers,switches,topre sliders etc.) but is thicker and for that is a bit better for stabilizers but needs to be applied very thin on switches or you can mix is with a bit of GPL 105 oil.
If enough interest is gained, I will pack them in 10ml containers, of which you can get multiple. Shipping anywhere, check the interest form for more info.
Google Interest check form here : https://forms.gle/JxbK4HPhAUHMLA2t5
This will be active until Friday 22 May 2020.
If all goes well and we have over 200ml in orders, I will move forward and they should be shipped to you until 30 May 2020.
Thank you !
Offline AdrianMan
Re: [IC] Krytox GPL 205 G2 grease
« Reply #1 on: Sat, 16 May 2020, 08:33:36 »
People getting over 20 ml will receive a bonus 10% quantity of the same stuff.
Ex. 3 x 10 ml will get a bonus of 3ml.
Offline ddnomad
« Reply #2 on: Sat, 16 May 2020, 08:36:14 »
I’ve used grade 2 for 3 different batches of switches. All of those are actively used right now and I can vouch for grade 2 being just fine both in terms of lubing (no issues and not any harder then apply g0, 3204 etc) and usage (no weird feel, just your regular 205 experience).
I’d strongly suggest using 0 size brush to apply lube though, that’s for all lubes but for 205 g2 in particular as it’s a tad bit thicker.
UPDATE: Checked the IC form. First of all, that container is 500 grams and (correct me if  I’m wrong) it’s not the same as 500 ml. Also price seems to be a tad steep. I got my 500 grams container from EBay for 105€ shipped.
« Last Edit: Sat, 16 May 2020, 08:38:43 by ddnomad »
Offline AdrianMan
« Reply #3 on: Sat, 16 May 2020, 10:05:03 »
Thanks for the great feedback. I'll do more research and adjust the price. Also pm'd you :)
Offline nicodelacruz
« Reply #4 on: Sat, 16 May 2020, 23:58:16 »
You can buy this on Amazon already.
Offline strawberryyogurt
« Reply #5 on: Mon, 18 May 2020, 16:58:04 »
Huh I happen to need a switch lubricant but it's odd to see this on IC.
