Author Topic: MOITOY - 85KB // My first build - Handwired 60% + Numpad + Extra Row  (Read 5153 times)
Offline Moitoy
This is one of my first post in this forum and my first mechanical keyboard and also my first custom and handwired Keyboard....I always start with the simplest way  :))
The idea was to make a keyboard that fit my needs, I wanted a small keyboard a 60% but I also need a numpad as I use it a lot, my first idea was to buy one but has very few options and less in ISO layout so finally I decided to follow the great tutorials of Matt3o and Cribbit and made a handwired one.
I started with "keyboard-layout-editor" to see options, look for diferent layouts and how to match it with a complete PBT keycaps in ISO Spanish that I found in China and this lead to me for a 60% + 1 extra row + numpad in the right ride, ISO layout and cursors at the bottom.
This was easy thanks to "keyboard-layout-editor"as is simple for a noob like me. The second choice was the switches, I bought a tester and I liked the khail box and as I was unable to decide just one type and I finally mixed 3 different types, Whites for alphas, pale blue for modifiers and orange for numpad and arrows
As I need 5 rows + 20 columns I decided to use a Teensy ++ 2 (chinese version that surprisingly worked with oficial teensy loader)
For the firmware as I´m not a great programmer I used "RUIKI MAO GMK Keyboard Firmware Builder", other simple and powerfull tool for noobs
And the final decision, how to made the case, I used 1.5mm laser cut plate for the switches plate, the bottom plate and the cover top plate and to mantain a low profile I used 8x8 aluminium box profile and custom printed corners to make the 2 sandwiches. Top cover has 2 funtions, cover the keyboard and be a wrist rest
Lets go to the build process  :cool:
After file all aluminium chips of the laser cut, lets put all stabs and switches in a colourfull way
Note there is a GATERON Intruder, this is just to allow the 3mm led for the CAPS Lock status Led
All switch plate has M3 tappered holes
Color is the way  ;D
I realised that Khail box do not have a perfect fit to the plate so I had to hot glue them a little bit to ensure them and now the hard work....HANDWIRING  :eek:
Diodes rows bucling and soldering
Completed rows
For the colums I used rigid cable from a Ethernet cable donor and a visegrip magic
To wire Teensy controller I used some fancy coloured cables from a SCART trash cable (20 colours FTW)
Rainbow teensy is ready to go
Some extra wiring and a 330Ohm resistor for the CAPS Lock led
Time to cut, file and mount 8x8 profile to the case and 3d printed teensy holder, and a little bit of EVA foam to isolate the bottom plate
Some details of the teensy holder
For the visible aluminium parts I brushed them with Scotch Brite to make a nice finish, not as cool as anodizing but nice enought to me and some details of the case build
The CAPS lock led worked, not at the first time as I put in firmware the pin for NUM Lock instead and then because I wired it wrong GND + Pin instead the CORRECT one +5v and Pin
Now its a low ligt under the cap, but im thinking in made a window in the keycap
Finally the result of the build
I hope it was as entertaining as for me was the build  :p
« Last Edit: Tue, 19 May 2020, 03:29:51 by Moitoy »
Offline kkatano
Re: MOITOY - 85KB // My first build - Handwired 60% + Numpad + Extra Row
« Reply #1 on: Tue, 19 May 2020, 06:55:11 »
Wonderful! Simple and clean looks.
I think EVA foam for isolation also has a positive effect on the sound of the board. How did you feel about it?
Offline Zustiur
« Reply #2 on: Fri, 22 May 2020, 00:08:55 »
The 8x8 box aluminium tubes may be exactly the solution I didn't know I needed. Thanks for the idea!
