Author Topic: Can any Model M experts out there tell me what keyboard I just bought?  (Read 2669 times)
Offline funkmon
Okay, it's got a straight metal 240 degree din plug, terminal layout with F13-24 sublegends, small feet, and the square badge. Through my method of lowballing every single Model M I don't have in my collection on eBay, I picked this thing up for a steal, but I have no idea what I'm looking at. I assume a standard soarer's converter will work, BUT I would like to know if you guys know when this was made, for what, if it's a 0th gen or 1st gen, what it was for, etc.
I've posted on deskthority and reddit, I'll update this with a part number if we decide on one so future googlers will find this info.
« Last Edit: Tue, 19 May 2020, 20:30:12 by funkmon »
Offline E TwentyNine
    • Some of My Keyboards
Very early.  Terminal. 1383603/4.
Offline funkmon
That's what I was thinking initially, but those don't have a straight metal DIN plug, do they?
Offline ddrfraser1
  • RIP Neil
It’s one of the good ones. Very well built. I had one once but I can’t remember how to get it to talk to my PC. Pretty sure you need an active converter.
Not the first time I've seen a plug on a board it's supposedly not supposed to be on.   I know I've seen that particular one before but can't pin down the exact hardware config.
It's always possible it was a replacement plug.
Offline funkmon
Deskthority seems to think it's this, the 1390305. Do we concur? https://www.recycledgoods.com/ibm-1390305-terminal-keyboard/
Looks like a match to me.
Offline Maledicted
This suggests that the protocol is probably AT.
IBM apparently used the 240 degree connector for some terminals instead of the more common RJ45. I could have sworn I had seen a thread about it in regards to those terminal Model Fs once.
