Author Topic: GMK Glacier  (Read 6213 times)
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
GMK Glacier
« on: Thu, 21 May 2020, 12:19:17 »
Opinions? Would you buy this set?
Offline Pluto19
  • All who break the taboo will be eliminated.
Re: GMK Glacier
« Reply #1 on: Thu, 21 May 2020, 13:18:30 »
I would not.
Offline Pylon
Re: GMK Glacier
« Reply #2 on: Thu, 21 May 2020, 13:23:06 »
Please post this in the Interest check forum. I also don't know how you're going to do the spacebar.
Offline Laur
  • Formerly dudeship
  • gmk retro runic
    • wip
Re: GMK Glacier
« Reply #3 on: Thu, 21 May 2020, 13:48:53 »
Sorry about both of those things, and I only just found out about the spacebar thing, thanks for the reply.
Offline ogWalker
Re: GMK Glacier
« Reply #4 on: Thu, 21 May 2020, 14:17:28 »
Maybe look at some other interest checks to have an idea of the standards of an actual IC.  :thumb:
Offline PseudoLlama
  • Ṗ̵̡̝̀̓e̸͉̲͛̔̓͝p̵̢̳̦̲̬̌͊̃̑͝e̷̯͔̾g̶̢̡̳̀̑̋a̶͕̺͆͌͒
Re: GMK Glacier
« Reply #5 on: Thu, 21 May 2020, 15:11:37 »
As someone who is also trying to make an IC, you need more than that. You should probably put some consideration into a full base kit. (I'm also working on that step) and also modifiers, because everyone needs modifiers. Plus it adds some pizzazz to your set. That spacebar isn't impossible though, just really damn expensive to produce probably.
Offline Zoomtech
Re: GMK Glacier
« Reply #6 on: Fri, 22 May 2020, 15:05:52 »
the space bar isnt aligned with the other keys with the blue and white
