Author Topic: What kind of dyes do you guys use for your Artisan keycaps?  (Read 2407 times)
Offline Gi1l
Hello, just wondering what kind of dyes everyone is using with their resin. I have been struggling with color for a while now. I am using smooth cast 320 and no matter how much dye I use it seems to wash it out or alter the color is some drastic way. Which part of your resin do you mix the dye into before pouring into your mold? do I need to be using a clear resin for better color ? Thanks !
