Author Topic: [IC]Infinikey Blacklight - GB Sep 10th! Final Update.  (Read 61724 times)
Offline Inner-Ear
Re: [IC]Infinikey Blacklight - Update! Kits & Renders
« Reply #50 on: Sat, 30 May 2020, 10:20:44 »
Another option is to Change to KAT PBT and then you can do separate alpha kits and mod kits for the different fonts. People can mix and match then. Everybody wins
Offline Ulliam
  • Formerly Papithered
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #51 on: Sat, 30 May 2020, 10:28:34 »
I just got done with 26 KAT Kits and I'd quite like to keep at least the blacklight portion of this in the cherry profile. In my opinion KAT / Cherry aren't really interchangable profiles.
Offline Fredington
    • Instagram
« Reply #52 on: Sat, 30 May 2020, 11:10:00 »
I like Opt. 1
Offline PikaJoyce
« Reply #53 on: Sat, 30 May 2020, 11:11:19 »
I believe ePBT is able to split up kits? Kuro Shiro allowed you to buy alphas separate from the mods but I’m not sure how they do it actually! Might be worth exploring?
I’m a big fan of the colorway and less so of fraktur, so I’d prefer being able to pick out the appropriate kits as well!
Offline rewke
« Reply #54 on: Sat, 30 May 2020, 12:58:15 »
I vote 2/3... but if the above is possible then everyone wins!
Offline neutralstate
« Reply #55 on: Sun, 31 May 2020, 05:52:43 »
I vote 1.
Maybe a poll or google form might be a better way of doing this?
Offline Acoipat
« Reply #56 on: Sun, 31 May 2020, 10:29:57 »
My vote is for 2/3
I prefer the default cherry font but seeing the quick render of Franktur with matching mods I may be enticed to buy both... either way I think having the sets split up is the way to go rather than the "in between" you have now.
As others mentioned if ePbt can run sets with mods and alphas split up at reasonable pricing that seems like a great solution.
Keep up the great work on this!
Offline thornkin
« Reply #57 on: Sun, 31 May 2020, 11:45:13 »
I am a cherry font person myself, but I think the dual kit option where each is pure is the way to go.
Offline fransuso
« Reply #58 on: Sun, 31 May 2020, 14:51:32 »
2/3 is the way to go!!!
Offline The_Runz
« Reply #59 on: Mon, 01 June 2020, 05:32:32 »
I might be doing something wrong, but the form doesn't allow for multiple answers to the which kits I'd be interested in buying.
Offline CF73
« Reply #60 on: Mon, 01 June 2020, 06:26:59 »
I vote for 1
if not, 2.
Offline alphabirth
« Reply #61 on: Mon, 01 June 2020, 15:59:04 »
I vote for option 1.  A question too: is that colour palette actually black-light reactive?  It would be awesome to see some samples of that!
Offline mrpokemone
« Reply #62 on: Mon, 01 June 2020, 17:05:31 »
Option 2 for me!
Offline bloodyxkatana
« Reply #63 on: Tue, 02 June 2020, 08:35:46 »
Option 2 for me, but I'm going to jump in on this no matter what.  ;)
Offline konstantin
  • Formerly constexpr
« Reply #64 on: Tue, 02 June 2020, 08:43:50 »
Perhaps use N instead of Nulla for the Latin numerals 0 legend? This use of N for 0 does have some historical backing, according to Wikipedia.
Offline Jupark
« Reply #65 on: Mon, 08 June 2020, 14:45:06 »
Can't wait for this set!
Could you consider DeskHero.ca as a Canadian proxy for us up north, please?
Offline Bachoo
« Reply #66 on: Tue, 09 June 2020, 11:37:07 »
First cyberspace, now this. You're killing it dude!
Offline zakatak
  • no cash
« Reply #67 on: Tue, 09 June 2020, 21:30:46 »
2/3 please!
Sent from my POCOPHONE F1 using Tapatalk
Offline tectonicplate
« Reply #68 on: Tue, 09 June 2020, 22:26:39 »
I would love a well done set in Fraktur, but with more appropriate colors… the WoB or some other semi-neutral direction would be ideal. Novelties could be amazing… thinking of illumination elements.
Offline Hanabi
  • Falling into a black hole.
« Reply #69 on: Tue, 09 June 2020, 23:40:05 »
1. Perhaps doing a poll would be better? Also I think 1 with icon mods would look good.
Offline alanskiii
« Reply #70 on: Wed, 10 June 2020, 00:56:55 »
So then, seems i'm at a bit of an impasse. I agree wholeheartedly that Cherry Mods + Fraktur look jank. It was a poor attempt at a solution. I also take on bored the critisicism that Fraktur/Blackletter and Blacklights aren't associated each other futher than my fascination with both. That being said here is my preposal and I'd love if you could comment and let me know what you think so I can get a better idea of how to move forward.
Option 1)Stick with the theme and pallet, lean heavier into the blackletter dropping all Cherry legends and mods entierly
Option 2)Split the 2 ideas into two sets one Blacklight using cherry style Type/Icons with this pallet and theme, one "Blackletter" a compleately new set based on Fraktur leaning heavily into the history and Blackletter type.
I have put together a very quick mock up of what these might look like:
1- Current pallet, Fraktur everything 2- Current pallet, Cherry everything 3- New Blackletter themed set (probably wont be WoB)
So i guess the choice is Between either 1 or 2/3 together
Hope you all have an amazing weekend, please let me know what you think.
Stay safe
Liam
I vote for 2. Cherry 🙏
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
Re: [IC]Infinikey Blacklight - OVERHAUL! - GB Sep 1st!
« Reply #71 on: Sat, 20 June 2020, 15:19:21 »
Massive update in the top post! please check it out and let me know what you all think.
Offline rewke
« Reply #72 on: Sat, 20 June 2020, 15:38:17 »
Looks great! I know some people loved Fraktur but I'm personally glad it got separated out from this set.
Offline PikaJoyce
« Reply #73 on: Sat, 20 June 2020, 16:21:19 »
+1 to this
Offline zoo
    • zoo
« Reply #74 on: Sat, 20 June 2020, 16:57:50 »
Delicious.
Offline alphabirth
« Reply #75 on: Sat, 20 June 2020, 18:12:29 »
-1.  I was a fraktur fan.  I still like the colours, but without fraktur, it ends up looking too similar to Miami Nights.  I'd be dropping out in the current iteration.
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #76 on: Sat, 20 June 2020, 18:23:44 »
Fraktur is still coming, but thats fair. Thats why i'll be making both sets tho.
Offline alphabirth
« Reply #77 on: Sat, 20 June 2020, 18:38:26 »
Oh sweet!  I missed that bit!  Will it be structured in a way like KAT sets, with the type of alphas being modular?
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #78 on: Sat, 20 June 2020, 19:24:23 »
Nice update, where'd ya get it.
Offline psxndc
« Reply #79 on: Sat, 20 June 2020, 19:40:13 »
The row numbering is messed up in one of the pics. Row 4 is bottom (and Row 1 is top) in one, Row 1 is bottom (and row 4 is top) the other.
Regardless, would love to see a 1u option for the "A" row (Row 3?) in the ortho kit that isn't Tab or Esc. If there's a novelty that can go there, that's fine. Just can't tell with the current row numbering discrepancy if there's a 1u novelty for that row.
« Last Edit: Sat, 20 June 2020, 19:44:38 by psxndc »
Ortho. Always.
Offline okfish
« Reply #80 on: Sat, 20 June 2020, 20:26:47 »
Awesome update, can't wait for GB  :thumb:
Offline Tree_
« Reply #81 on: Sat, 20 June 2020, 22:28:19 »
Must be in an odd boat compared to everyone else:
I was for Option 1 and have zero interest in 2/3, in its current form I've lost any interest in the set. My initial interest was also that Fraktur was being used with interesting colours, a Fraktur set in something "boring" like WoB or similar isn't something I'd be keen on.
I'd go one further than alphabirth and say I'm not interested in this iteration or any going forward that use Fraktur if it doesn't pop like this originally did.
Offline i luv chuletas
« Reply #82 on: Sat, 20 June 2020, 22:50:01 »
Damn, super clean with striking colors. Gonna be tough deciding between Cyber and this!
Offline ilikerustoo
« Reply #83 on: Sun, 21 June 2020, 00:59:23 »
I like the set a lot more now. Glad to see the other font will also be another option for the others though
Offline SwitchKeys
    • SwitchKeys
« Reply #84 on: Sun, 21 June 2020, 02:26:09 »
*Chef Kiss*
Offline fransuso
« Reply #85 on: Sun, 21 June 2020, 07:23:20 »
no EU proxy? :(((((
Offline mchanneh
  • trying to reset terrible typing habits!
« Reply #86 on: Sun, 21 June 2020, 08:06:56 »
Kailh Box Royals | Cherry Reds | Knockoff Blues
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #87 on: Sun, 21 June 2020, 09:56:14 »
no EU proxy? :(((((
This x2   :(
I actually havent contacted any proxies myself yet, but there will most certainly be an EU proxy.
« Reply #88 on: Sun, 21 June 2020, 10:38:22 »
I'm so ready for this set
Offline konstantin
« Reply #89 on: Sun, 21 June 2020, 15:36:48 »
I suggest changing out the Win key for System/Super/Code, and the Menu key for System/Super/Code too :thumb:
Double 1u Ctrl isn't necessary; one of them can be safely removed, or moved to the add-on kit for ortho support.
Consider using R3 \|, R4 <> for basic ISO support in the base kit, and keeping all of the UK keys grouped together in the add-on kit. See how Tidal did it. More on this topic here.
In short: move R3 #~, R4 \| from base to add-on, move R3 \| from add-on to base, add R4 <> to base.
Not sure how useful a R2 num = key is. R1, sure, but R2 — dunno, you might want to remove that.
Is that accent legend color seen on Esc and Enter the same as the alphas legend color?
« Last Edit: Sun, 21 June 2020, 15:41:59 by konstantin »
Offline Ulliam
  • 𝖚𝖑𝖑𝖎.𝖆𝖒
« Reply #90 on: Sun, 21 June 2020, 19:12:34 »
Thank you Konstantin I'll take your advice on board anmd the kitting will be updated tomorrow.
« Last Edit: Sun, 21 June 2020, 21:35:14 by Ulliam »
Offline wil
« Reply #91 on: Sun, 21 June 2020, 20:42:06 »
Stay safe
Liam
1 and 3.
Offline solomonshv
« Reply #92 on: Mon, 22 June 2020, 16:38:21 »
god damn it dude. i don't want to buy anymore key caps!
ok, fine. just one more.
Keebs::: Bok.CP - Antique Copper | Keycult No.2/65 Black/Brass | Keycult No.2 Rev 1 Grey/Brass | Jane V2 CE - Black/Multicolor | J-01 Rev1 - Blue | Haus - Silver | Kohaku - Red | OwLab Jelly Epoch - Ruby SE & Popcorn | KBD8X MKII WKL - Black PC | Ayleen WKL - Gin
Caps::: GMK Modo, GMK Jamon, GMK Olive, GMK Mizu, GMK Olivia++, GMK Bingsu, GMK Analog Dreams, GMK Botanical, GMK Moondust, GMK Taro R2, GMK Hennessey, GMK Serika R2, GMK Birch, GMK Tuzi, GMK Red Alert, GMK Zooted, GMK Hazakura, GMK Cyrillic Beige, GMK Lavender, GMK Daifuku, GMK November Fog, GMK Villanelle, GMK Blossom, DCS 9009 WYSE Alps
On order: GMK Tiramisu, GMK Maroon, GMK Bordeaux, GMK Taiga
Offline DALExSNAIL
  • 𝖋𝖚𝖈𝖐 𝖆𝖑𝖕𝖘
« Reply #93 on: Mon, 06 July 2020, 09:48:58 »
 :cool:
Offline Ariamella
Re: [IC]Infinikey Blacklight - OVERHAUL! - GB Sep 11th!
« Reply #94 on: Tue, 21 July 2020, 22:22:16 »
I would very much like it if it had more novelties for every row :)
Offline bakerozee
« Reply #95 on: Fri, 07 August 2020, 04:33:37 »
Keen for this  ;D ;D ;D
Looks really nice and clean.
Bring it to Switchkeys for Oceania.
"more the knowledge lesser the ego, lesser the knowledge more the ego..." Albert Einstein
Offline Whale_algorithm
« Reply #96 on: Mon, 10 August 2020, 10:21:26 »
Infinikey is doing some great things with PBT. Good chance I’ll be in for this
Offline psxndc
« Reply #97 on: Mon, 10 August 2020, 12:30:59 »
Sorry if this got lost in the shuffle, but the row numbering still isn't fixed. Can OP provide some clarity on what's in what row? Thanks!
« Last Edit: Sat, 29 August 2020, 14:58:44 by psxndc »
Ortho. Always.
Offline davisthegreat
    • 3DKeebs
« Reply #98 on: Mon, 10 August 2020, 13:56:39 »
I'm in. 1) hope there is enough contrast between the black and purple legends 2) can we get a stepped control?
Offline despairsray
« Reply #99 on: Mon, 10 August 2020, 17:49:06 »
I like this more than my Tokyo Nights, most likely in
