Author Topic: Diameter/dimensions of BKE rubber domes  (Read 1710 times)
Offline diymkb
« on: Sun, 24 May 2020, 20:40:31 »
Does anyone know the inner/outer diameters of the top and bottom openings on a BKE rubber dome? And the height from top to bottom?
I was thinking of purchasing an old Mitsumi variant AKII M0487 to salvage its weird domes (if the dimensions match).
Offline ddrfraser1
  • RIP Neil
Re: Diameter/dimensions of BKE rubber domes
« Reply #1 on: Mon, 25 May 2020, 18:36:22 »
243473-0
243475-1
243477-2
243479-3
Offline diymkb
« Reply #2 on: Tue, 26 May 2020, 00:50:44 »
Thank you so much for information hook up, ddrfraser1! I couldn't find the info anywhere on the internet.
