Author Topic: [IC] Saturn-60: High-Profile Steel Keyboard [GB ordering closed]  (Read 169871 times)
Offline DanielUlbrich
Re: [IC] Saturn-60: High-Profile Steel Keyboard [vendors and GB!]
« Reply #100 on: Sat, 26 September 2020, 14:11:16 »
Looks super sick!! Since you mentioned fitting a RPi in there, any thoughts about cooling, options to fit ports somewhere?
Offline Dissitesuxba11s
« Reply #101 on: Sat, 26 September 2020, 16:07:26 »
Super dope, definitely considering getting one for the price. Not sure if it has been asked but can you mix and match the colors like that one white render?
Offline Magnificent Bureaucrat
  • Sooooo much red tape
« Reply #102 on: Sat, 26 September 2020, 18:10:13 »
Pretty sure it has been confirmed on discord that you can get bases and tops in different colours.
« Reply #103 on: Sat, 26 September 2020, 21:37:55 »
Yea I see it on the discord announcements now. Looks like two-tone is good :thumb:
Offline HiiragiAkira
« Reply #104 on: Sun, 27 September 2020, 02:56:26 »
Holy...
Imagine putting rails on this big boi and having him in a drawer or a server rack!
Nice design!
this sounds so cool, how would you install it tho? Have the handle on the outside to tug or?
Offline darthcapn
« Reply #105 on: Sun, 27 September 2020, 05:36:02 »
Dang it I missed to respond to this and hence I AM NOT ON THE LIST. But what a beautiful chonker is this lad! Wish I can get one.
Sent from my SM-G988U using Tapatalk
Praxis | Portal | Frog F13 | Vega | Sat75 | F2-84 | Iron 165 | KFE CE | Spring | Pandora | Mr Suit | MGA | Jelly Epoch
Dolice | Glare | Vmax chyuu | W1-AT | Hoshizora | iron 160 | Nazaré | Tomo
Offline BirgusLatro
« Reply #106 on: Tue, 29 September 2020, 18:49:24 »
Thank you very much!  Sorry I am a little behind on the geekhack replies - for the RPi cooling I did not really make any special provisions, but I suppose it is possible to mount it to the case with some thermal paste.  For ports, I have created a breakoff tab on the bottom of the case that can be used to pass cables through.
Yes, as one person replied, two toned ordering will be perfectly acceptable.  Thank you for the compliment!
Offline ShovelScum
« Reply #107 on: Fri, 16 October 2020, 01:36:42 »
Can't wait to see this hit GB status! Waiting for my turn.
Also, why is the Vendor website for the US still not up? Will it go live once the GB starts? I really want this, but don't want to order from overseas....
Like the name suggests, I am the ScumBag who rides a Shovel through this landfill.
Offline Capone1423
« Reply #108 on: Fri, 16 October 2020, 08:12:02 »
I would like to order one on candy keys but it’s still password protected, any ideas or help?
Offline child
« Reply #109 on: Fri, 16 October 2020, 08:34:44 »
Wait 4.5h from now for EarlyBird Sale to complete (if I get the timing right), then it should be unlocked
Offline BirgusLatro
Re: [IC] Saturn-60: High-Profile Steel Keyboard [GB Opens Today!]
« Reply #110 on: Fri, 16 October 2020, 09:08:16 »
Thank you!   ;D
Yep - the GB sites are going live at 6PM GMT+0  I am going to make a GB thread now.
Offline Gunt0x
« Reply #111 on: Fri, 16 October 2020, 14:49:18 »
Is it compatible with other PCB such as Insta60 or DZ60?
Offline nathanchere
Re: [IC] Saturn-60: High-Profile Steel Keyboard [Update June 11]
« Reply #112 on: Sat, 17 October 2020, 07:32:55 »
HHKB please
Thank you for saying please!  I'm not opposed to it -  I am willing to do other R5 options depending on interest.
Looks like this didn't happen in the end?
Offline m3t4lm4n222
« Reply #113 on: Sat, 17 October 2020, 09:50:35 »
Does this case fit any standard 60% PCB, so, say, for example, I wanted to use an ANSI Layout Hotswap PCB?
Offline aadk5
  • AKA: feeebleminded
« Reply #114 on: Sat, 17 October 2020, 11:14:57 »
Since the USB is a passthrough, it should be able to use any 60% PCB. Just pick the correct plate for your layout. The purist plate should work for most PCB's, but the utilitarian plate should be used if you're using a 2U left shift
Offline BirgusLatro
« Reply #115 on: Sun, 18 October 2020, 21:48:03 »
HHKB please
Correct, there was not enough interest in HHKB unfortunately.
Offline Selbor
« Reply #116 on: Sun, 18 October 2020, 22:00:36 »
I"m new to all this.  Are the switches swappable?  Or do I have to solder them?
Offline aadk5
« Reply #117 on: Sun, 18 October 2020, 22:13:30 »
If you buy the PCB from them, you'd have to solder. However, you should be able to use any hotswappable 60% PCB
Offline acaban
Re: [IC] Saturn-60: High-Profile Steel Keyboard [GB is OPEN]
« Reply #118 on: Mon, 26 October 2020, 02:57:46 »
Utilitarian pcb supporting ISO enter but not left shift split?
Offline BirgusLatro
« Reply #119 on: Mon, 26 October 2020, 09:56:27 »
Yes that is correct
Offline fuzewall
« Reply #120 on: Mon, 26 October 2020, 19:44:20 »
I dig it. Not sure that i would get, but its a unique build for sure. The more plain builds just don't excite me quite as much, but i get more detail-work would take away from the space-camp/ space-race tech vibe.
Offline piercejenkins
Re: [IC] Saturn-60: High-Profile Steel Keyboard [GB ordering closed]
« Reply #121 on: Fri, 07 May 2021, 19:51:36 »
She’s here and she’s solid asf!!  I expected it to sound hollow but the design along with the included foam makes it sound like a solid aluminum board. Excellent EXCELLENT QC to boot. This is my new endgame! 😍🥰
Laced her with some alpacas, Durock v2 stabs lubed with krytox, and SA Royal. I’m in love.
Here are a ome potato glamour shots for your viewing pleasure.
Offline BirgusLatro
« Reply #122 on: Fri, 07 May 2021, 20:38:07 »
This build is stunning!  Thanks for the kind review as well  ;D
Offline darthcapn
« Reply #123 on: Fri, 07 May 2021, 23:33:36 »
Sound test!!
« Reply #124 on: Mon, 24 May 2021, 17:53:44 »
Giving off 3277 vibes!!
Offline hottrout
  • I'd Hit Dat Key
« Reply #125 on: Tue, 25 May 2021, 08:58:10 »
Nice build, I like the look.
Current Daily Driver : Virgo - Ultramarine - Standard Lube  |  WTB : Topre Realforce Hi-Pro, please PM me if you have one for sale.
Systems -
Work |i9-7940x@4.8ghz|32GB(3600)|STRIX-RTX3090Ti|Bespoke Water, 360m Rad|X299 Prime Deluxe|EK x299 Monoblock|Optane 900p|2x1TB 960 Pro|2x10TB Helium|Dell U3415W + Dell UP2116Q
Home |i9-13900ks|32GB(7300)|Rog RTX 4090|Asus Z790 Rog Maximus Hero|Torrent Air|2TB 990 Pro|2TB 990 Pro|Dell AW3423DW QOLED|NEC MultiSync|Drobo16TB
Mining |i5-7500|16GB(2400)|H110 Pro BTC+|8x1080Ti|2x1650Watt PSU
Plus 40 years of collecting retro computers, consoles, games, peripherals, mainframes and mini's as well as their software, keyboards, games and manuals. 100's of systems including every Amiga model made
  Keyboards -
IBM 3101 | IBM 3276 | IBM 5150 | IBM ModelM | Dictaphone Dual Display | Vintage Cherrys (1982 onwards, just about all of them) | Commodore (all of them) | Nixdorf | Siemens | ICL | Apple (all of them) | Filco Majistouch | KBDFans 5degree - Chocolate | Rama M6-B - Moon | CA66 Silver | ClueBoard Graphite/PC | Varmilo VA69M Silver | E7-V1 SE Yellow | Rama U-80 Space Grey | VN66 Navy | BOCC Frosted Polycarbonate | Rama M10-C Midnight | FLX Virgo Teal & Black | Rama M60-A LYN Kuro | Space65 CyberVoyager WhiteGold | Space65 CyberVoyager Terminal | Hyper 7 | Clarabelle Sandblasted Polycarbonate | Elongate Mini 1800 Blue | Petrichor 1800 Red | Vulcan Maja Ergo Green | Think6.5v2 RoboCop | Jacky Bear 65% E-White | Sakabato CB87 TKL Champagne | KCK KY-01 Aquamarine | Jae J-01 F&F E-White & Copper | S7.7 E-White | The Adélie Blue | NIX OxalyS80 LE Dark Polycarbonate | Mesa TKL E-White | Smith & Rune IRON180 Graen/Brass | Skog Reboot Desert | CU7 Black | ROTR Silver & Copper | RAMA Kara Soya | Grid 650 E-White | SIX5 LE Aluminium & Gold | OwLab Voice65 Grey | BOX 75 Black Stainless Steel | Onyx E-White | Ikki68 BT Charcoal | Smith & Rune Iron 165 Graphite & Stainless Steel | Epoch 80% Black | RAMA Thermal SEQ2 Kuro | Paper Crane Gerald65 SE PC & CF | CB1800 ZANBATO | GLiTCH | Eclipse Grey & SS | TGR Tomo Silver | Mountain Ergo Black | Keebwerk NASU Black/Red | Phase One 65 Grey | Command TKL Fire | Chalice Frosted | VIENDI 8L Shadow | | Vulcan Maja PC | Glove 80 | Matrix 8XV 3.0 Starry Night | Sagittarius Grey Lilac | AKB OGR & Numpad Dolch | Type K Black
Offline Nonnegaard
« Reply #126 on: Mon, 29 November 2021, 02:46:42 »
shipping notice in from ck, soon boys
Aeon, TGR Jane V2, Dolphin 2021, Gherkin, Model M, 5°, NCR80, M0110-A
Offline nathanchere
« Reply #127 on: Thu, 09 December 2021, 08:21:08 »
HHKB please
Time for a poll for R2 HHKB :D
