Author Topic: Spilled water on my IBM Model M  (Read 3989 times)
Offline qorg11
« on: Mon, 25 May 2020, 14:40:34 »
Hi
I spilled a bit of water on my IBM Model M, some keys are working flawlessly, but my 'c' key is not working (it's the only one that is not working), and when i press caps lock (I rebinded it to ctrl) the keyboard does not register the other key (ctrl + x, the x is not registered)
What can I do about this?
Thanks.
Offline ddrfraser1
  • RIP Neil
Re: Spilled water on my IBM Model M
« Reply #1 on: Mon, 25 May 2020, 18:25:19 »
Oh dear
Offline treeleaf64
    • treeleaf64
« Reply #2 on: Mon, 25 May 2020, 19:05:08 »
 :-X
Everyone must pay the cat tax
Offline Maledicted
« Reply #3 on: Mon, 25 May 2020, 19:30:55 »
Is it bolt modded? Otherwise, you're not getting the thing apart to clean/dry off the membrane. I certainly wouldn't be using it at all until it is dry inside, the more you've got it plugged in like that, the more potential damage will be done.
Offline qorg11
« Reply #4 on: Tue, 26 May 2020, 02:44:58 »
I let my keyboard dry for the entire night, and C key is working now, do you think i shuold let it dry for a bit more?
Offline Maledicted
« Reply #5 on: Tue, 26 May 2020, 09:30:37 »
I wouldn't trust that short of time in such an enclosed space, although that's great news. I have literally seen moldy water and rust inside of laptops before. I think the least I would personally try to do is pull all of the caps, pull the board apart, and put the plate sandwich in front of a fan for a few days. I have also used 91% isopropyl alcohol in places I can't disassemble, to help displace and evaporate the water more quickly.
Offline ddrfraser1
  • RIP Neil
« Reply #6 on: Tue, 26 May 2020, 10:39:36 »
^ I agree. Good time to learn how to do a bolt mod. (it's really not as hard as you think)
« Reply #7 on: Tue, 26 May 2020, 13:16:06 »
Taking the internals out of the case would improve air flow.
If it is warm and sunny where you live, an afternoon outside in the sun would probably drive out the water.
- Franklin Roosevelt 1933
Offline typo
« Reply #8 on: Sun, 31 May 2020, 22:44:36 »
Completely take it apart. leave it that way for a month. Put it back together. should work.
