Author Topic: Am I the only one that hates R5 (as oppose to just use R4)?  (Read 5913 times)
Offline Hyde
  • White Tofu Extraordinaire
I find R5 overly sculpted and I actually like my Esc key almost flat (OEM and Cherry profile).
Hence I think R5 is a waste of money they should've just kept using R4 twice which is perfectly fine and also cheaper.
R5 isn't too common but say in the instance of KAT profile I'd much rather they use R4 twice.
Offline HungerMechanic
Re: Am I the only one that hates R5 (as oppose to just use R4)?
« Reply #1 on: Tue, 26 May 2020, 13:30:00 »
I guess I'll find out, should I choose to open 9009 R3.
Offline clasicks
  • Formerly KeyboardUser4
« Reply #2 on: Tue, 26 May 2020, 13:36:17 »
i dont like r5
Offline Hyde
« Reply #3 on: Wed, 27 May 2020, 22:10:16 »
Hmmmm I think that's a bit different since it's the bottom row.  I think when I said R5 I meant the Esc and Function row.
I guess some companies count from top and some count from bottom lol.
« Reply #4 on: Wed, 27 May 2020, 22:24:03 »
Maybe it's just me, but is it R0 that you actually hate?
« Reply #5 on: Thu, 28 May 2020, 04:25:49 »
https://deskthority.net/wiki/Keyboard_profile#Numbering
I find Row F and other high-profile keys to be too wobbly.
Row A is divine, though.
Offline Rico
« Reply #6 on: Thu, 28 May 2020, 07:04:38 »
R0 is the row were F keys are,R5 is the row were the space bar is.
Offline Hyde
« Reply #7 on: Fri, 29 May 2020, 20:49:16 »
My first board was Costar made (Filco, Das Keyboard, WASD Keyboard, CM Storm Rapid Fire.....etc) so I kind of just went with Costar numbering.
For Costar row 1 is spacebar and row 4 is function row.
But yeah I think I like the current 112344 layout.
Offline Sup
« Reply #8 on: Sat, 30 May 2020, 08:30:01 »
I got some OG R5's here and i dislike them feels very unnatural for me they do look cool though not gonna lie.
current
Coming soon
Offline Pylon
« Reply #9 on: Sat, 30 May 2020, 12:10:46 »
Also they hurt layout compatibility (e.g. if you have an R4 1u Fn key you can use it next to the Shift key or on bottom row, while if you do R0/R5 you need two separate Fn keys to cover those).
