Author Topic: [IC] KAM Ocean Front - Update - Groupbuy up!  (Read 97732 times)
Offline GreenLantern
Re: [IC] KAM Ocean Front - Update - Boardrenders + All kits rendered!
« Reply #150 on: Wed, 24 February 2021, 04:17:44 »
Is there update on if greens come glossy
Offline Mistah
« Reply #151 on: Thu, 11 March 2021, 11:14:51 »
Spacebar kit for Alice?
In the works, will be added. :)
amazing renders by liz! though i feel you should probably include acknowledgements to the creators of the boards used in your post
You're right, thought I already did that oops
It was already there, under special thanks to
I also spoke to DrHigsby and he helped me kitting, after this is finished the pricing quote will be updated.
Also requested some greener samples, hopefully those will come soon.
Estimated GB date is 1 June :)
I think they meant list the name of the boards and their creators not whoever did the renders./
Yeah I'm gonna have to ask... What is that first board? Lol
Edit: for anyone wondering, the first board is the M011Y https://thekey.company/products/m0lly?variant=30337112997977
« Last Edit: Thu, 11 March 2021, 13:57:20 by Mistah »
Offline eljudio42
« Reply #152 on: Thu, 11 March 2021, 13:23:27 »
Any plans for a discord to keep up with the project?
Offline adamyli
« Reply #153 on: Thu, 01 April 2021, 11:30:04 »
Any news on the GB date and availability of the original darker green colours?
Offline eljudio42
« Reply #154 on: Thu, 01 April 2021, 12:29:32 »
gb date is possibly june 1st per a comment just above yours ;D
Offline BullRage
« Reply #155 on: Mon, 05 April 2021, 16:19:49 »
So I guess I need this set.
Offline Timception
« Reply #156 on: Tue, 06 April 2021, 02:34:55 »
Are there going to be arrow keys in the base kit, I ask because the renders don’t have any keebs with arrow keys.
Offline BullRage
« Reply #157 on: Tue, 06 April 2021, 03:51:00 »
So far it looks like the Alphas Kit and the TKL Modifier Kit are separated.
Offline Timception
« Reply #158 on: Sun, 11 April 2021, 23:51:30 »
are any of the images real pictures of the keycaps, or all renders?
Offline eljudio42
« Reply #159 on: Sat, 01 May 2021, 12:59:07 »
they're all renders
Offline watchsasquatch
« Reply #160 on: Tue, 04 May 2021, 16:09:19 »
Is this still on track for GB to happen in June?
Offline citrusfruit
« Reply #161 on: Wed, 05 May 2021, 07:37:21 »
Will you get an Oceania vendor?  :-[
𝕔𝕚𝕥𝕣𝕦𝕤 (●´ω`●)ゞ
Offline FOTANA
« Reply #162 on: Thu, 06 May 2021, 15:03:50 »
I have been excited about this set for a while now!!
Offline frasnow
« Reply #163 on: Fri, 07 May 2021, 18:57:17 »
I've been excited about this set for nearly a year. Of course, I've also been waiting for over a year for Keyreative to make my first order of KAT keycaps. KAT Arctic better arrive before this set goes group buy, and it better be amazing so I can justify ordering KAM Ocean Front.
Offline FOTANA
« Reply #164 on: Fri, 07 May 2021, 19:46:46 »
all I can say is if you have the funds available to buy a few extra kits for resale - good investment
Offline Meijboom
« Reply #165 on: Tue, 11 May 2021, 15:15:08 »
Yup, they will be in the TKL kit! (Icon+Text)
YES!
After the quote gets updated, I will announce the date. But 100% in June!
I contacted a vendor, hopefully it will work out. :)
Will do :)
Offline Meijboom
« Reply #166 on: Tue, 11 May 2021, 15:19:18 »
The colours are set in between both versions, in the original post you can see the samples + pantone matching.
I personally really like how they came out, and 100% match with the colours I asked for!
Yes, this will be included in the Groupbuy
Yes, they will! Final colours in the original post, with glossy samples incoming :D
Offline Meijboom
« Reply #167 on: Sat, 15 May 2021, 12:34:34 »
Just got confirmation that the set will be sold at Dailyclack.com!  ;D
Offline bamblerow
Re: [IC] KAM Ocean Front - Update - Deskmat + Samples - Groupbuy in June!
« Reply #168 on: Sat, 29 May 2021, 10:38:20 »
Hi,
Please consider adding the u measurements to the kit renders: it is something I see some occasionally done and it is greatly appreciated. My ability to eyeball all the correct keycap measurements isn't perfect.
Looking to kit out a redox keyboard and I need 10 1.25u and 6 1.5u. Sadly the blanks kit doesnt feature 1.25u, but likely too late for that now.
My count is that a TKL mods and a Novelties gets me to that count, hopefully that is right  :D.
TKL mods has
  • 7 1.25u (left crtl sys alt, right alt sys menu ctrl)
  • 6 1.5u (left tab crtl alt, right alt ctrl bksp)
Novelties has
  • 3 1.25u (uhm... chain thingy, chain loopy thingie, and anchor thingy)
  • 1 1.5u (boat thingy)
which gets me the 10 1.25u and 7 1.5u I need to kit out.
Offline jakk
« Reply #169 on: Sun, 30 May 2021, 16:22:25 »
Stunning set, Love the concept and execution is phenomenal!
Offline hagiwaraDaisuke
« Reply #170 on: Mon, 31 May 2021, 23:08:06 »
If I want to fit an alice layout which kit should I buy?
Offline Mistah
« Reply #171 on: Mon, 31 May 2021, 23:30:27 »
That's probably something you should ask on a thread of the keyboard you're getting, because it can vary, even between Alice styles. Generally they are standard tkl sets though
« Reply #172 on: Mon, 31 May 2021, 23:36:19 »
Yeah sorry, I think I should revise the question, I did not find a spacebar kit in the kitting, or is it coming soon? It's 2u and 2.75u spacebar.
Offline Mistah
« Reply #173 on: Mon, 31 May 2021, 23:38:45 »
Oh wow yeah, that's a massive oversight. Didn't even realize because I was looking at this kit for someone else. Doesn't look like there is a spacebar kit at all. In this case, the best you can do is use the shifts/novelties. Not sure it would go with the gradient though
« Last Edit: Mon, 31 May 2021, 23:40:49 by Mistah »
Offline lazaret
« Reply #174 on: Tue, 01 June 2021, 12:50:44 »
Uhhh good point! I also have the same problem, for my split keyboard I need a 2.25 U and 3 U spacebars (or blanks). Is it really too late for a spacebars kit? :'(
Offline Havattack
« Reply #175 on: Tue, 01 June 2021, 12:59:28 »
I don't think June's a good idea.. there is a ton of popular sets going down this month, and May was packed too. It would suck pretty bad, if after all the effort put into designing this set, if it did not meet MOQ.
Maybe i'm wrong, and that's the way every month will be going forward in this hobby, but I don't know..
Offline cmander7688
« Reply #176 on: Tue, 01 June 2021, 13:04:48 »
there's a spacebar kit available for purchase on the keyhive page, at least.
Offline frasnow
« Reply #177 on: Tue, 01 June 2021, 14:32:33 »
I agree June is a bad idea, but my reasoning is more selfish. I'm still waiting on my first KAT order from May of 2020. It would be nice to see if Keyreative can actually deliver a quality set. With the quality control issues I've seen on every set released, I'm not sure I can put more money into a startup. That is what Keyreative is, a startup. They used the money from the first set of group buys to buy their equipment after their supplier failed to produce quality keycaps, but Keyreative is still having quality issues.
When is GMK Ocean Front?   ;D
Offline lazaret
« Reply #178 on: Tue, 01 June 2021, 15:19:52 »
You're right, I had not looked at the vendors. It it really going live now? They say 1st June, but it's not online everywhere yet.
« Last Edit: Tue, 01 June 2021, 15:21:23 by lazaret »
Offline rockydbull
« Reply #179 on: Tue, 01 June 2021, 17:31:20 »
Kam wraith turned out pretty well. A couple of small issues but nothing I would consider terrible.
Offline Mistah
« Reply #180 on: Tue, 01 June 2021, 20:57:43 »
To be honest, I've seen more issues with GMK recently. I've had two GMK sets with oily-looking surfaces that can't be washed off
Offline rockydbull
« Reply #181 on: Tue, 01 June 2021, 21:24:23 »
Am I missing something or should the 2u shift in the TKL kit be blue instead of brown? 2u left shift is (almost?) never on the right side of a board.
« Reply #182 on: Tue, 01 June 2021, 21:26:31 »
Is the set still not live on zFrontier?
Offline BullRage
Re: [IC] KAM Ocean Front - Update - Groupbuy up!
« Reply #183 on: Wed, 02 June 2021, 11:42:54 »
Got it!
Offline Meijboom
« Reply #184 on: Wed, 02 June 2021, 12:48:07 »
Hi Guys, Sorry for the one day delay. to compensate the GB runs till July 3.
TKL's, Ortho, and alpha's are updated to better suit the 40 kits. I also added a spacebar kit to support Alice.
The groupbuy page is currently awaiting approval :D
meanwhile this post has all the updated kitting :)
Offline psxndc
« Reply #185 on: Wed, 02 June 2021, 14:45:53 »
Is there a diagonal alphas kit for ortho AND a straight alphas kit? Looking on Keyhive, all I see is the generic alphas kit (diagonal). Just want to confirm before I hit "buy". Or do I need to get the Ergo kit in addition to alphas to make it straight? Thanks!
Ortho. Always.
Offline Meijboom
« Reply #186 on: Wed, 02 June 2021, 15:09:41 »
Both sets are possible with a single ortho set (A+B) or (A+C)! :D
Offline Meijboom
« Reply #187 on: Sun, 13 June 2021, 15:11:54 »
