Author Topic: [IC] ePBT Kavala - GB is Live!  (Read 146006 times)
Offline Cylent
  • Formerly cylentshadows
« on: Mon, 07 June 2021, 06:50:10 »
Click Here to go to the Group Buy Thread!
GB Oct 1 - Nov 1, 2021
Signature:
Please consider copying this banner to you show your support for ePBT Kavala!
Code: [Select]
[url=https://geekhack.org/index.php?topic=113229.0][img width=320 height=120] https://i.imgur.com/1J1xdm7.png [/img][/url]
« Last Edit: Fri, 01 October 2021, 07:54:01 by Cylent »
Offline Cylent
Re: [IC] ePBT Kavala
« Reply #1 on: Mon, 07 June 2021, 06:51:06 »
Reserved
Offline Pontus
« Reply #2 on: Mon, 07 June 2021, 06:56:02 »
Cute set. I like the decision to not go reverse dye-sub as well  :thumb:
Offline cthalupa
« Reply #3 on: Mon, 07 June 2021, 07:16:28 »
Excited to see this reach IC! Beautiful set.
Offline spikedsynapse
« Reply #4 on: Mon, 07 June 2021, 07:17:40 »
Woot! Watching this set evolve has been great. Knowing the work you put into this makes it a definite buy from me. Well done & GLWIC
Offline Afresh
« Reply #5 on: Mon, 07 June 2021, 07:46:36 »
glwic  :thumb:
Offline Fredington
    • Instagram
« Reply #6 on: Mon, 07 June 2021, 08:12:20 »
Imma need that Greek in the Base kit.
EDIT: Never mind, I prefer Clouds+Sky.
« Last Edit: Wed, 16 June 2021, 09:03:22 by Fredington »
Offline andromache
« Reply #7 on: Mon, 07 June 2021, 08:25:27 »
This set is beautiful, and I love the Greek sublegends kit, but I wish they were available in a base kit...not sure if that could be feasible with EPBT kitting? Anyway, great work.
Offline bansheetango
« Reply #8 on: Mon, 07 June 2021, 08:43:08 »
Loved Kavala, passed through it on our way to Thassos.
Second this, the set is inspired by a Greek town, seems fit to have Greek sublegends in base. No sublegends should be the addon.
Offline TyPo.mk
« Reply #9 on: Mon, 07 June 2021, 10:07:40 »
Consider 2 base kits like epbt origami. I imagine many people will want the Greek set and each Base would have a moq of 100 instead of 200
Offline ThickJimmy
« Reply #10 on: Mon, 07 June 2021, 10:47:44 »
Glad to finally see this in IC after watching the development process. GLWIC homie!  :thumb:
Offline MIGHTY CHICKEN
« Reply #11 on: Mon, 07 June 2021, 11:06:59 »
Been loving this set since the first concept, GLWIC
Offline Shiba1337
« Reply #12 on: Mon, 07 June 2021, 11:13:35 »
other than the feedback that I've already given (which was preference anyways), looks really good! Exited to see where this goes, and will probably pick a set up if it goes to gb.
Offline Trigozen
« Reply #13 on: Mon, 07 June 2021, 11:17:47 »
Looks great man! GLWIC
Offline jagger27
  • ne 1.5U supers???
« Reply #14 on: Mon, 07 June 2021, 11:18:22 »
Gotta get some Sky+Clouds renders
Offline Cylent
« Reply #15 on: Mon, 07 June 2021, 13:04:20 »
Thank you all for the feedback and kind words. This set has been a labor of love, and to see it receive such a positive response on day one means a lot to me.
Regarding the greek subs in base, please fill out the IC form with that feedback if changing the kitting would significantly increase the likelihood that you would buy something from the set. I am open to changing kitting based on IC feedback. Rn I am hoping that the Sky kit will be $30-40, and therefore not significantly cost-prohibitive.
I have tried to cover as many variations as possible in my renders (under the "more" tab), including Sky+Clouds variations. If there are additional variations you would like to see please let me know and I will try to satisfy the request(s) to the best of my ability.
Offline PradyXT
« Reply #16 on: Mon, 07 June 2021, 13:29:48 »
Wooo IC! Excited to see what this is going to turn into :D
Watching this set progress was interesting!
Offline azzipa
« Reply #17 on: Mon, 07 June 2021, 13:42:50 »
your design captures the sunset image well. and after admiring the colors, the next thing i thought was: no reverse dye-sub! glwic  :thumb:
Offline jabe8i
« Reply #18 on: Mon, 07 June 2021, 14:02:29 »
this give off similar vibes as taihao's hawaii but this is much better imo
Offline jabe8i
« Reply #19 on: Mon, 07 June 2021, 14:10:05 »
Not sure if the moq thing is a big issue for ePBT. Correct me if im wrong but isn't it if one set hits moq then all of them get made?
I personally prefer a separate sublegends kit because I can potentially fill up 2 boards without having to buy 2 whole base kits, I also don't want to be left with half a dozen shift keys that I will never use if I buy 2 base kits.
Offline WQ
« Reply #20 on: Mon, 07 June 2021, 15:09:32 »
It's finally here!!!
I've been following ur work on discord for a while, can't wait for the GB and good luck with the interest check!
Offline PradyXT
« Reply #21 on: Mon, 07 June 2021, 20:13:08 »
(iirc) If base kit is reaches MoQ, all kits will be made.
Offline TyPo.mk
« Reply #22 on: Mon, 07 June 2021, 20:26:47 »
You are correct, My point in bringing up moq was that for epbt  if you have 2 base kits the moq is only 100 each (so still only 200 total) not 200 each. So there’s very little downside in offering 2 base kits
Offline clickpig
  • naisu naisu naisu
« Reply #23 on: Mon, 07 June 2021, 21:35:05 »
This colourway is really pretty, glwic!
Offline ManoliVisuals
« Reply #24 on: Mon, 07 June 2021, 21:41:09 »
Absolutely love this. I'm always in for Greek themed sets <3 my only suggestions (my preference of course) is that you have the sublegened alphas in base, but thats just me lol
Offline pararch
« Reply #25 on: Tue, 08 June 2021, 00:00:07 »
Looks great! GLWIC
Offline Technofrikus
[IC] ePBT Kavala
« Reply #26 on: Tue, 08 June 2021, 00:14:47 »
Poly orea! :)
« Last Edit: Tue, 08 June 2021, 00:23:12 by Technofrikus »
Offline Ruinate
« Reply #27 on: Tue, 08 June 2021, 00:16:39 »
Absolutely gorgeous!
Reminds me of the sunrise scene in Hades game as well.
Offline Neely_12
« Reply #28 on: Tue, 08 June 2021, 00:30:47 »
Really like this! well done
Offline crusader_alex
« Reply #29 on: Tue, 08 June 2021, 04:48:38 »
Πολύ όμορφο σετ φίλε! Καλή επιτυχία!
Sent from my HD1913 using Tapatalk
Offline Cylent
« Reply #30 on: Tue, 08 June 2021, 10:08:31 »
Thank you, I'm a big fan of GMK Evil Eye as well! IC feedback + quotes will likely determine whether sublegends are in base.
Offline bobtheguitar
« Reply #31 on: Tue, 08 June 2021, 14:21:49 »
I love the lowercase Greek sublegends. But as pretty as the set is, I’m not sure I can make it work… Will definitely consider it though. GLWIC
Offline Cylent
« Reply #32 on: Tue, 08 June 2021, 23:13:03 »
σε ευχαριστώ φίλε μου!
Offline KeyboardPeople
« Reply #33 on: Wed, 09 June 2021, 00:06:03 »
I really like all the colors, but it's a little much. I would drop the orange and just the rest. Either way it looks nice though GLWIC.
Offline Cylent
« Reply #34 on: Wed, 09 June 2021, 15:27:41 »
I understand this sentiment completely. Clouds + Sky is meant to be an alternative for those who aren't on board with so many colors. Check out the additional renders, there are quite a few combinations you can put the set in, including a blue-only colorway I'm partial towards.
As an update, I am currently working on securing vendors and collabs. If you're interested in working with me don't hesitate to reach out!
Offline Kokaloo
  • 🤘(• ω •)🤙
« Reply #35 on: Wed, 09 June 2021, 15:51:39 »
This is really swell, really like the usage of regular dyesub instead of opting for reverse dyesub.
Offline Cylent
« Reply #36 on: Thu, 10 June 2021, 13:32:35 »
Update: Most preliminary agreements with vendors have been made, expect a formal vendor announcement soon (tm).
Offline CHEESETWIST
« Reply #37 on: Fri, 11 June 2021, 15:43:34 »
Love it! The gradient is beautiful!
Offline Cylent
Re: [IC] ePBT Kavala - NA vendor secured!
« Reply #38 on: Mon, 14 June 2021, 07:15:40 »
Vendors so far:
NA - Vala Supply
AS/Global - KBDfans
Expect other vendor announcements this week!
Offline Cylent
Re: [IC] ePBT Kavala - Vendors Announced
« Reply #39 on: Wed, 16 June 2021, 08:50:38 »
Vendors Announced!
Global/AS: Kbdfans
NA: Vala Supply
EU: MykeyboardEU
CA: Ashkeebs
UK: Prototypist
OCE: Daily Clack
PH: ZionStudiosPH
India: Stackskb
Offline NimbleTortoise
« Reply #40 on: Thu, 17 June 2021, 01:21:18 »
This set would look even nicer with icon mods, what a shame.
Offline DerBonk
  • I'm just this guy, you know.
« Reply #41 on: Thu, 17 June 2021, 03:12:23 »
I am far from an expert on kitting, but for my personal use, it would be fantastic if you added two R1 1u mods to the mikró kit. It would allow me to just get the Sky alphas and the mikró kit to fill my 4-row split ergos (for example Sofle, Lily). For full Preonic-style orthos, you would need more R4 1u, but many users might find a way to still make that work with the extra R4 keys in the alphas set. Just a thought, totally understand if it is not worth it, esp. with the base kit MoQ being important with ePBT, afaik.
Offline OfficialP3
« Reply #42 on: Thu, 17 June 2021, 07:41:42 »
Agreed, Icon mods would make this more than incredible
Gesendet von meinem Pixel 3 mit Tapatalk
Offline Cylent
« Reply #43 on: Fri, 18 June 2021, 11:33:32 »
I hear you. A while back a survey was completed by an NA vendor (if memory serves) that showed people generally prefer icon+text mods with icon-only a somewhat close second, and text-only a distant third.
« Last Edit: Mon, 21 June 2021, 17:47:32 by cylentshadows »
Offline Cylent
« Reply #44 on: Mon, 21 June 2021, 17:49:39 »
Update: I will be updating the 40s kit with icon-only mods. 40s users should be able to fully cover their boards by purchasing the Sky Greek sublegend alphas and the mikro 40s kit. Keep a lookout for that sometime this week or next!
Development on the novelties is progressing, what Greek-themed illustrations would you like to see?
Offline HappyB0T
  • I'm a Piggie
« Reply #45 on: Tue, 22 June 2021, 01:43:46 »
Anyway to get a cloud + sky render?
Sublegends + Icon Mods = :D!
Offline DerBonk
« Reply #46 on: Tue, 22 June 2021, 01:59:53 »
My main suggestion would be to follow your inspiration. It is so personal, so, I bet you can draw some great non-cliche ideas there.
My personal associations with Greece and the image on the deskmat would be: an olive branch (or just an olive), a small fishing boat, the sunset in the sea, the shape of the Peloponnese and/or Crete, a branch of thyme, the Bouzouki, and of course the building style with lots of interwoven cubic shapes and some domes, as well as ornate wooden doors (this is probably very hard to capture in novelty, though). To me, all the references to ancient Greece (columns, pantheon, statues) are not as strong/too cliched, but if these are strong associations for you, I can totally understand that.
I guess it might make sense to decide what aspects of Greece you want to focus on, to make the theme stronger and more coherent.
Offline Ruinate
« Reply #47 on: Tue, 22 June 2021, 14:04:54 »
I love anything and everything to do with Greek Mythology, but realize that's not really the aesthetic you're going for here. But if you decided to make novelties or a set in the future with this theme (especially using pbt again!), I would likely have to instantly buy all of it.
Offline Cylent
« Reply #48 on: Tue, 22 June 2021, 18:33:40 »
Hi, please click "more" underneath where it says "Click Here for More Renders" in the render section of the IC.
Offline DrHigsby
  • The doctor is in.
« Reply #49 on: Wed, 23 June 2021, 13:44:08 »
I really dig the greek sub-legends on the alt alphas!
