Author Topic: Help: Identifying keyboard  (Read 4888 times)
Offline icecold
« on: Mon, 08 June 2020, 12:37:52 »
Hi.
Im new to the community so I hope I don't break any rules.
Could you guys help me identifying the keyboard?
Are the switches Cherry MX Blacks?
Here are some photos:
244642-0
244644-1
244646-2
« Last Edit: Tue, 09 June 2020, 16:23:05 by icecold »
Offline Maledicted
Re: Help: Identifying keyboard
« Reply #1 on: Mon, 08 June 2020, 13:27:11 »
Hello icecold. Welcome to Geekhack.
Those do look to be Cherry MX black switches. It is interesting to me that that is what they are, since the "KB-5150" with that exact same styling and layout, is usually supposed to have foam and foil switches.
Offline TalkingTree
    • My projects
« Reply #2 on: Mon, 08 June 2020, 13:36:50 »
Cherry G80-0439, I own it.
Offline icecold
« Reply #3 on: Mon, 08 June 2020, 14:01:33 »
Yeah, i checked it now and I see that G80-0439 has MX Blacks and IBM layout, and surprisingly keyboards i found doesnt always have cherry mark on them. So it might be it. Thanks for the answer!
Yes, i was surprised too when i saw the keyboard and it didnt have foil switches. Thanks for your answer.
I guess i'm buying it, the auction ends on friday and it's only about ~6$ and i like it, especially with MX Blacks. I just hope that nobody outbids me. I never really had mechanical keyboard and I was going to build my own with (lubed)gateron yellows, but this keyboard might be even better :)) I just wanted to be sure if they are MX Blacks.
Thank you people of geekhack <3
Offline Maledicted
« Reply #4 on: Mon, 08 June 2020, 14:31:31 »
I would prefer Gateron yellow myself, both in weighting and feel, even without lube. Have you typed on a layout similar to that before? It can be a little rough to try to adjust to. I personally don't do it, even though I have a perfectly good IBM Model F XT at home. I hope you win it as well. It is worth a lot more than $6 just to the vintage MX black crowd.
Offline icecold
« Reply #5 on: Mon, 08 June 2020, 15:24:36 »
I haven't :/
But i think i will try it anyways, of course if i win. If i don't I will surely build that gateron yellow keyboard. I have been following mechanical keyboards for almost a year now and I was in situations when i was just about to buy some prebuild board, but then thought that i want to build one myself. I don't like RBG and all that "gamer" stuff.
You know - i don't even know if it's going to work. The seller says in description that he doesn't know if it works. So i could desolder and then use those MX Blacks for another keyboard if the pcb is broken or something just doesn't work. For 6$ it still might be a good deal.
I have one question. Do you think it would work with AT -> PS2 passive adapter and PS2 -> USB active (i guess*) adapter?
* i think it is active - i have read somewhere that if the PS2>USB adapter has two inputs: one for keyboard and one for mouse, it is active. I'm not sure, if it's true, though. I have this one, so I wouldn't need to buy another one if it could work like that.
Offline Maledicted
« Reply #6 on: Tue, 09 June 2020, 09:04:38 »
I haven't :/
Do they even make RGB prebuilts with Gateron yellows in them?
Well, the interface looks to be 5-pin Din. Most people who aren't keyboard and/or computer collectors/fanatics are not gong to have any way to interface it with a computer in order to try to test it. For $6, a board's worth of Cherry switches of any kind is a good deal. Those are what people would call "vintage" MX blacks though, which are sought-after by many. People buy boards, working or not, just to desolder those and put them in something else. Personally, I would leave the poor board alone if it works.
It might work, it might not. With 5-pin Din, we were approaching protocol standards, but it was still sort of the wild west. The Leading Edge DC-2014 and Zenith Z-150 beige/white label are good examples of this.  The DC-2014's protocol is ... sort of XT, but not quite. It is my impression that it won't even work with most original XT systems. The white/beige label Z-150 is sort of AT, but not quite. I have gotten mine to work with a handful of modern computers through their PS2 ports, but that's been very hit or miss. It doesn't even work with a Soarer's converter, and I have tried to help Hasu get the thing working perfectly with his TMK firmware (which I still need to get him some more data on).
If the board follows the AT protocol to a T, then a passive AT -> PS2 adapter chained with an active PS2 -> USB adapter will work. That's how I'm using this weird old Nan Tan board as we speak.
You would be correct. There was a weird period some time in the late 90s and/or early 2000s where keyboards were designed to work over both PS2 and USB, with which the passive adapters would work. That was a dark time in keyboard history anyway though. Almost everything mechanical made then was using Cherry switches, what little there was.
Offline icecold
« Reply #7 on: Tue, 09 June 2020, 16:17:09 »
I haven't :/
I think they don't make prebuild boards with RGB and gateron yellows.
Gateron yellows are my recent discovery - they sound lovely.
When i said i was just about to buy some prebuild board, i meant that it usually had gateron blues or gateron browns xD
I will post here on friday, because it's when i know if I won or not.
Thanks for your answers, they were really helpful for me.
« Last Edit: Tue, 09 June 2020, 16:22:09 by icecold »
Offline Maledicted
« Reply #8 on: Tue, 09 June 2020, 16:25:59 »
Gateron yellows feel great too, for linears. They're just the right weighting, if you ask me, and they're a lot smoother than MX. They don't actuate when you rest your fingers on them, but they're not so heavy as to be fatiguing like MX black, etc. I think you'll like them if linears are your thing.
Sounds good. Good luck in the auction. You're very welcome. I'm happy to help.
Offline icecold
« Reply #9 on: Mon, 06 July 2020, 16:29:39 »
I know it's been almost a month.
I didn't win - auction ended at above 50$.
I'm still thinking about those gateron yellows :) I'm looking for some summer job to get some money first, though.
See ya next time. I will try to update this post later, when i get to build some nice keyboard.
