Author Topic: Plate sourcing for old LZ-S  (Read 1991 times)
Offline brohothepirate
« on: Wed, 10 June 2020, 15:47:31 »
So I stumbled across an old LZ keyboard, an LZ-S.
I've confirmed that I can get a new compatible Snow Pro PCB, but the plate is an unknown.
I'm also super new to the hobby and don't really understand what the worst case scenario is.
Can I just learn CAD and draw up a compatible PCB if I open up the case and measure dimensions?
Not shy about learning how to do it myself since it's basically learning a new skill.
How would you approach a plateless Kustom?
Offline wholypantalones
  • text and icon mods plz.
Re: Plate sourcing for old LZ-S
« Reply #1 on: Wed, 10 June 2020, 16:01:37 »
Maybe ask LZ if there's a plate file and get one cut?
Isn't the S the same as an LZ-GH? The plates might actually be compatible.
Multiple pcbs in existence will fit the S, check the tkl compatibility list: https://geekhack.org/index.php?topic=96123.0
« Reply #2 on: Wed, 10 June 2020, 16:45:09 »
Thanks, I've reached out to LZ so hopefully I can either find one or get one cut. Looks like the plate is pretty much incompatible with everything as far as the hivemind can tell.
