Author Topic: [IC] KAT Blanks  (Read 14787 times)
Offline CaptainVinceO2
    • ApexKeyboards
[IC] KAT Blanks
« on: Fri, 12 June 2020, 09:59:44 »
Introducing KAT Blanks!!
We're happy to announce KAT Blank Keycaps, a cost effective way to try out the KAT profile. KAT Blank keycaps will feature the same color and compatibility as KAT Alpha. The group buy will start on June 19th and will end on July 3rd. The expected date for everything to be finished manufacturing is in September and fufillment in October. Credits to Avi on Discord for helping me kit it and getting in contact with Zfrontier for the set.
Renders & Kits by Kingk22
Full Album
IC FORM
Timeline
  • Interest check COMPLETE
  • Group Buy Opens June 19th
  • Group Buy Ends July 3rd
  • Fulfillment September/October
Vendors
  • CAN/US ApexKeyboards
  • EU Mykeyboard.eu
  • AU/OCE DailyClack
  • ASIA/CHINA Zfrontier)
Pricing & Info
  • $45 USD MSRP (Price May Vary)
  • Shipping from ApexKeyboards will be Tracked Packet $15-20CAD
  • US Buyers will not need to pay tax since the set is lower than the taxable value
Note Regarding KAT Issues:
We've been assured that the Keyreative will be fixing the issues present in KAT Milkshake and has provided us with an extensive email addressing all issues that were brought up by the community. Since our set is blanks one of the main issues we would need to worry about is the caps lock being misaligned. In the lengthy email, they have assured us that this issue will be fixed in all future KAT sets including ours. This was due in part to factory closures and the factories needing to run extensively to keep up with the backlog from the pandemic.
Thanks for reading this IC!
Edit 1: Rows are the same as KAT Alpha 5-4-3-2-1-1 and numpad 0 is supposed to be a 2u not 2x 1u.
Edit 2 (6/13/2020): Current kle file that wil be submitted to Keyreative  http://www.keyboard-layout-editor.com/#/gists/fcb1b3da18b2817f43dfe8787dd77bed
LAST UPDATE (6/19/2020) GB is now up! Awaiting GB post approval HERE
« Last Edit: Fri, 19 June 2020, 10:32:14 by CaptainVinceO2 »
Offline cijanzen
Re: [IC] KAT Blanks
« Reply #1 on: Fri, 12 June 2020, 10:02:43 »
Huh. Cool! I’m in
Offline Slayer77
Re: [IC] KAT Blanks
« Reply #2 on: Fri, 12 June 2020, 10:11:01 »
Please offer multiple colors.
Sent from my GM1911 using Tapatalk
Offline maoam
Re: [IC] KAT Blanks
« Reply #3 on: Fri, 12 June 2020, 10:11:56 »
In short: Yes!
Offline MinaDarsh
Re: [IC] KAT Blanks
« Reply #4 on: Fri, 12 June 2020, 10:14:41 »
Very interesting, might pick this up too. By the way, can we get row info?
    • ApexKeyboards
Re: [IC] KAT Blanks
« Reply #5 on: Fri, 12 June 2020, 10:20:52 »
It's going to be the same rows and color as KAT Alpha from Kono. So it should be 5-4-3-2-1-1.
Offline maoam
Re: [IC] KAT Blanks
« Reply #6 on: Fri, 12 June 2020, 10:23:01 »
Is there a possibility for a black kit as well?
    • ApexKeyboards
Re: [IC] KAT Blanks
« Reply #7 on: Fri, 12 June 2020, 10:33:53 »
Not at the moment, for us to do no MOQ we have to stick with the same colors as KAT Alpha.
Offline zekth
Re: [IC] KAT Blanks
« Reply #8 on: Fri, 12 June 2020, 10:37:55 »
Missing 2x1U spacebar no?
Other than that good initiative!
    • ApexKeyboards
Re: [IC] KAT Blanks
« Reply #9 on: Fri, 12 June 2020, 10:42:09 »
Yep! Seems like it was left out 1x 2u in the render's if that's what you're asking. Here's the link to the correct kitting and the row indicators https://i.imgur.com/felGSQX.png
« Last Edit: Fri, 12 June 2020, 10:45:05 by CaptainVinceO2 »
Offline chriszhu
  • (* ̄(エ) ̄*)''
Re: [IC] KAT Blanks
« Reply #10 on: Fri, 12 June 2020, 13:40:51 »
Looks nice, totally in!
Offline Bonsa
Re: [IC] KAT Blanks
« Reply #11 on: Fri, 12 June 2020, 16:27:23 »
I'm afraid of white keycaps, but I have to say yes to this one.
Offline depletedvespene
    • Keyboard-related resources.
Re: [IC] KAT Blanks
« Reply #13 on: Sat, 13 June 2020, 07:56:11 »
I looked at the diagram in https://i.imgur.com/felGSQX.png and those are my comments:
- The third row from bottom-to-up says R4, should be R1.
- The second R5 row has one 1U key; consider having four instead of one, to fully support all 1800-like layouts.
- Shouldn't the R3 1.25U key be in R2?
- The three R2 homing keys are missing; they are specially important in a blank keyboard.
- Consider adding an extra R1 1.25U key, so the 6.25 space bar can be comfortably split (2.25+1.25+2.75).
- Consider adding one column of 1U keys in R1,R2,R3,R4. This will simplify adjustments to the numpad, bottom row, extra Alice alpha and several other variations on physical layouts.
GLWIC!
    • ApexKeyboards
Re: [IC] KAT Blanks
« Reply #14 on: Sat, 13 June 2020, 11:11:00 »
GLWIC!
Thanks a lot for the suggestions! Standard homing from KAT Alpha since the set.
We've modified the KLE slightly here http://www.keyboard-layout-editor.com/#/gists/fcb1b3da18b2817f43dfe8787dd77bed and we'll take your suggestions into consideration when we post the GB next Friday. Will update this post as we make changes.
Re: [IC] KAT Blanks
« Reply #15 on: Tue, 16 June 2020, 20:34:57 »
can't hate blanks
wish there were more colors
Offline amperrsand
Re: [IC] KAT Blanks
« Reply #16 on: Tue, 16 June 2020, 22:01:48 »
Damn, how did you even come up with this theme? And the colorway to match? It's so out there and so fresh. So bold yet so understated. If you tell me you spent no less than 5 months going through color swatches, contacting and arguing with vendors, and going back over the novelties in Photoshop or InDesign or whatever to make sure every millimeter was this perfect, then I can't believe you.
Offline Kyekoro
Re: [IC] KAT Blanks
« Reply #17 on: Wed, 17 June 2020, 03:39:58 »
Change the font or I'm out.
Offline bow3i
Re: [IC] KAT Blanks
« Reply #18 on: Wed, 17 June 2020, 05:11:42 »
Gotta get me a set, maybe two
Offline grundlemere
Re: [IC] KAT Blanks
« Reply #19 on: Wed, 17 June 2020, 08:16:26 »
Been needing. Pls to more colors
    • ApexKeyboards
Re: [IC] KAT Blanks
« Reply #20 on: Wed, 17 June 2020, 11:23:23 »
can't hate blanks
Sounds good! We'll look future blank sets featuring more colors. Just more of a test run this time around by going with the same specs as KAT Alpha without the legends ofc.
Offline megabacon
Re: [IC] KAT Blanks
« Reply #21 on: Thu, 18 June 2020, 20:46:19 »
Any chance of Ergodox coverage?
Offline baobaozi
Re: [IC] KAT Blanks
« Reply #22 on: Sat, 20 June 2020, 05:13:46 »
Ordered, but yeah! next run some more colours would be amazing, a few different choices of coloured mods, with still-white alphas would be sweet.
Offline makenova
Re: [IC] KAT Blanks
« Reply #23 on: Sat, 27 June 2020, 00:09:21 »
Will these take dye easily?
Offline skydread
Re: [IC] KAT Blanks
« Reply #24 on: Sun, 19 July 2020, 20:16:32 »
So upset that I missed out on these but I hope I can get some if a second round comes around!
Offline Avijit
Re: [IC] KAT Blanks
« Reply #25 on: Mon, 20 July 2020, 00:11:58 »
Vendors should have bought extras. So Come October you should be able to buy a set
