Author Topic: Everglide Cheap Linears! (Need help)  (Read 2819 times)
Offline wyz3
« on: Fri, 12 June 2020, 16:41:17 »
Everglide has 3 (Well, 4 I think but only 3 of them are cheapish) linear switches to buy. They include: Amber Orange, Coral Red, Sakura Pink. I barely know much about them accept their actuation forces of 35g (Sakura) , 45g (Amber) and 50g (Coral). In terms of smoothness,  is there any differences between the two and are some of them noticeably scratchier? Is the quality of the switches consistent? I am leaning towards buying Coral Reds because of its actuation force, are there any cons about this particular switch? If you can I would appreciate if you can point out the pros and cons of each switch. Thank you.
Edit: I guess the Everglide Sky Blues are also cheapish, I think they are similair to Amber Oranges but  they have a slightly lower bottom out of 55g rather than Amber's 58g bottom out force.
« Last Edit: Fri, 12 June 2020, 16:56:16 by wyz3 »
Offline wyz3
Re: Everglide Cheap Linears! (Need help)
« Reply #1 on: Fri, 12 June 2020, 16:43:01 »
Jus' one more thing. How do each of these switches compare to Gateron Yellows, in terms of smoothness and scratchiness? And I would appreciate if you could also compare them with Kailh Box Blacks.
Offline Toffee
« Reply #2 on: Sat, 13 June 2020, 12:48:48 »
Toufusoup compared one of the linears to a gateron yellow in this video:
Offline Maledicted
« Reply #3 on: Sun, 21 June 2020, 18:51:01 »
I love the feel of every everglide switch I have in my tester, which I believe includes all 3 of those. They definitely all feel a bit smother to me than Gateron yellows, which are already pretty smooth. Just going by the test switches, in a tester, wobble may be a bit less than the Gaterons as well, if you care about that (I do not). No idea how well they may hold up, etc, but they feel great in a tester.
