Author Topic: [IC] MT3 Extended 2048  (Read 228538 times)
Offline pandaman97
Re: [IC] MT3 Extended 2048
« Reply #250 on: Sat, 10 October 2020, 09:53:16 »
Can you make a hiragana mono kit?
Offline whatoe
« Reply #251 on: Sun, 11 October 2020, 14:33:54 »
Need this!
Offline cohesive_glue
« Reply #252 on: Tue, 13 October 2020, 17:35:08 »
Super nice! ;D
Offline BigBeile
« Reply #253 on: Tue, 13 October 2020, 17:35:45 »
Love this set. Very clean and nice can't wait
Gesendet von meinem VOG-L29 mit Tapatalk
Offline CONIN
« Reply #254 on: Wed, 14 October 2020, 00:34:38 »
Hi guys; I understand this is an Interest Check thread but I don't see any link to a form or survey, am I missing something?, or it's already a fact this set will be manufactured? Thanks a lot in advance!
« Reply #255 on: Wed, 14 October 2020, 00:37:55 »
Sure!
Offline vsrnth
« Reply #256 on: Wed, 14 October 2020, 00:40:11 »
this set will run as a GB in December on Drop.
That said if you have a some comments feel to free to post them, Biip does read this thread
Sent from my SM-G975F using Tapatalk
Offline CONIN
« Reply #257 on: Wed, 14 October 2020, 00:43:08 »
This set will run as a GB in December on Drop. That said if you have a some comments feel to free to post them, Biip does read this thread.
Thanks a lot for the helpful reply!, will keep an eye on Drop for sure.  :3
Offline biip
    • @biipmk
« Reply #258 on: Wed, 14 October 2020, 03:25:04 »
Kits renders added :thumb:
Offline Zaprey
« Reply #259 on: Mon, 19 October 2020, 10:58:52 »
pls can you add 1.5u spacebars in nomad kit to support boards like the Corne? thanks
Offline Debido666
« Reply #260 on: Tue, 20 October 2020, 10:17:47 »
Is it true that Drop is also releasing WOB and BOW with this set at the same time?
Offline biip
    • @biipmk
« Reply #261 on: Wed, 21 October 2020, 02:22:05 »
No.
Offline StrangPrisoner
« Reply #262 on: Wed, 21 October 2020, 09:45:46 »
Is this the BoW to which they have been referring?
Offline biip
    • @biipmk
« Reply #263 on: Wed, 21 October 2020, 10:01:04 »
MT3 Extended 2048:
Keycaps spec: PBT plastic with dye-subbed legends. L9/BV colors.
Offline Debido666
« Reply #264 on: Wed, 21 October 2020, 10:02:33 »
« Reply #265 on: Wed, 21 October 2020, 13:40:16 »
MT3 Extended 2048:
Forgive me, I am finding no reference to those color codes. I looked at the Deskthority wiki and PMK's PBT color guide and did not find these codes. I did a cursory search for MT3 color codes to no avail.
More to the point my question was related to the thread Debido666 referenced. They make mention that a BoW set will be happening in December same as MT3 Extended 2048. If you need to play things close to the vest I totally understand. I'm just trying glean some sort of insight as to a release schedule and available sets.
Offline pixelpusher
« Reply #266 on: Wed, 21 October 2020, 14:02:07 »
MT3 Extended 2048:
He is referring to the color equivalent in GMK colors L9 and BV.  L9 is common, BV can be seen in the color ring here:
https://uniqey.net/media/image/fd/72/d1/Ebene-1.jpg
Offline Debido666
« Last Edit: Wed, 21 October 2020, 18:01:25 by Debido666 »
« Reply #268 on: Thu, 22 October 2020, 10:15:04 »
Thank you both for that information. Still looking forward to a Mac compatible set with the good ol' Mac aesthetic.
Offline komodo90
« Reply #269 on: Wed, 04 November 2020, 19:39:49 »
A bit late to arrive here, but what are the kitting suggestions for Boardwalk users with 2x 2u spaces? Actually I heard 2x 2u spacebars are also not uncommon for any ortho set as a matter of fact.
I was hoping that KAT ergo kit guidelines (https://geekhack.org/index.php?topic=105714.0) to include 2 convex 2u spacebars would apply here. But looking at kits posted on the first page it seems we have just 2x concave (which follow the profile of numpad-enter and should never be used for horizontal spacebar purposes either way). Worse than that I don't even see any additional kit that would have 2x 2u concave. Do we really need to get Ergo + Nomad + Spacebars to equip such keyboard?  :'( That would be very unfortunate.
Is there anything we can do about it?
« Last Edit: Wed, 04 November 2020, 19:41:53 by komodo90 »
Offline pandaman97
« Reply #270 on: Wed, 04 November 2020, 22:20:50 »
 I thinks "Accent Modifiers kit" still missing some keys. Tab, Backspace and Delete (split backspace). Can you add these in?
Offline azzipa
« Reply #271 on: Thu, 05 November 2020, 20:06:09 »
Do the icon keys not interest you? Granted the 1u backspace will have to substitute for delete if going split BS (and you'd have the same icon directly below for your 'real' backspace) but looks like you're covered.
Offline pandaman97
« Reply #272 on: Fri, 06 November 2020, 00:44:56 »
I just want those have different color than white  :D
Offline singlexyz
« Reply #273 on: Sat, 07 November 2020, 15:48:33 »
look's too white, just like (black on white)
Offline krautcat
  • local the flammable man without identity
« Reply #274 on: Sat, 07 November 2020, 16:09:59 »
What? Photo biip posted here was about legends not colors.
Or did you comment colors of the set?
Offline biip
    • @biipmk
« Reply #275 on: Sun, 08 November 2020, 11:33:08 »
white is light beige (check the first post of the thread for more info).
The prototype featured another color scheme that's why I displayed it in grayscale though.
Offline krautcat
« Reply #276 on: Sun, 08 November 2020, 14:30:01 »
I perfectly understand that set is designed in the beige color. I just replied to singlexyz to say that photos of prototype is not referred to any actual color of the design.
Btw as fellow ePBT 2048 Extended user I am waiting for the GB.
Offline TopreMoon
« Reply #277 on: Mon, 09 November 2020, 10:53:22 »
Any chance there will be more accent offerings? I would love to be able to fill all the modifiers on a HHKB layout with purple for example.
Offline Curin Derwin
« Reply #278 on: Fri, 13 November 2020, 13:49:09 »
Will these be a white or a cream color?
EDIT: L9 and BV... so these: https://uniqey.net/media/image/fd/72/d1/Ebene-1.jpg
« Last Edit: Fri, 13 November 2020, 15:55:19 by Curin Derwin »
Offline pol139
« Reply #279 on: Fri, 13 November 2020, 18:14:42 »
I'll cheer for you :-*
Offline youngki.bear
« Reply #280 on: Fri, 20 November 2020, 13:36:41 »
Very much looking forward to this becoming my first MT3 set.
Offline MortalKonga
« Reply #281 on: Fri, 20 November 2020, 19:22:58 »
 Goddam!!!! This is exactly what I was looking for. Not many sets with international add-ons!
Offline ggggggg
  • schmeiß die forties durch den club
« Reply #282 on: Wed, 25 November 2020, 04:25:20 »
It's probably been mentioned, and maybe the kitting is final but I figure it can't hurt to say that I really really absolutely would love a second 2u spacebar in the Nomad kit.
Offline Poet_Li
« Reply #283 on: Fri, 27 November 2020, 01:54:46 »
There's no 2.75u spacebar in nomad?
Offline Jo_hannes
  • You can never learn less. You can only learn more.
« Reply #284 on: Fri, 27 November 2020, 03:29:33 »
Oh no, please let there be a 2.75 SB. I would really like this set on my coming Adélie... :/
/Johannes
Offline Drakenocas
« Reply #285 on: Fri, 27 November 2020, 09:46:05 »
I closed out the page and I can't find the person I was replying too, but there are 6 ABS Doubleshot MT3 sets on Drop right now.  There are also a couple more kits that aren't on sale right now.  I would call it market saturation, though I am not complaining.
WoB
BoW
Susuwatari
3277
JUKEBOX
CAMILLO
Offline azzipa
« Reply #286 on: Fri, 27 November 2020, 14:47:49 »
Agreed, but there's something like 7 months left on 3277 and unless you really prefer MT3 to GMK you might check out Deepwell
WoB
BoW
Susuwatari
3277
JUKEBOX
CAMILLO
Offline RabidNomad
« Reply #287 on: Sun, 29 November 2020, 12:17:21 »
...I'm all in on this set for sure.
« Last Edit: Sun, 29 November 2020, 14:35:26 by RabidNomad »
Offline NassimO
« Reply #288 on: Sun, 29 November 2020, 12:26:40 »
Sign me up !
About time that the AZERTY layout get some love. Think you can do a Baguette kit like you did for a previous set ?
Offline PizzaForce
  • Eat me.
« Reply #289 on: Sun, 29 November 2020, 14:17:33 »
Digiorno. You know its gonna be good, you know the group buy will be run well, you know its gonna sell well on Drop. But that doesn't mean I have to like it.
Offline pol139
« Reply #290 on: Mon, 30 November 2020, 03:53:17 »
So cool~~~
Offline Razer1987
« Reply #291 on: Mon, 30 November 2020, 06:52:31 »
Sign me up !
Azerty seems to be in the intl kit.
I am in for this one and lot of extras. I think it will be a first for iso fr in MT3!
Offline biip
    • @biipmk
« Reply #292 on: Mon, 30 November 2020, 07:06:28 »
Sign me up !
Can confirm, AZERTY is supported.
Offline futurekatsu
« Reply #293 on: Tue, 01 December 2020, 01:29:41 »
Love this
Offline wolverine92
« Reply #294 on: Tue, 01 December 2020, 13:19:07 »
Sorry if already answered, but will the color nomad accent kits include lower and raise icons? I saw them in the off white nomad kit, but not in the color accent one.
Sent from my Pixel 5 using Tapatalk
Offline kidpid
« Reply #295 on: Tue, 01 December 2020, 17:07:39 »
The Nomad and Accent Nomad kits lack legend support for staggered 40% boards that have symmetrical bottoms rows. Examples include the TMO50/Nightmare, TMO50v2, Adélie, Prime_E, Cajal, Phoenix 45, etc. The Nomad kit is lacking a second 1.5u Alt, second 1u OS, second 1.25u OS, and a second 1.25u Ctrl. A 1.25u R3 Ctrl would be nice too, like GMK Serika R2. The Nomad Accents kit could use a second 1.25u Ctrl and OS, a second 1.5u Alt, and a second 1u OS (and the aforementioned R3 1.25u Ctrl). This is all assuming the Nomad kits are meant to be used without the corresponding mods kits.
Offline wolverine92
« Reply #296 on: Tue, 01 December 2020, 19:29:46 »
Definitely agree they need to offer the 1.25/1.5/etc  space bars in pairs.
Offline NassimO
« Reply #297 on: Tue, 01 December 2020, 22:07:52 »
Sign me up !
Yeah i already saw that AZERTY is supported, what i asked is a kit with only the FR keys in it, like biip did for Milkshake.
Offline azzipa
« Reply #298 on: Wed, 02 December 2020, 16:28:21 »
@blip - Wondering if Drop is correct with pre-order window open for 5 months? I see ship date is late May but that kind of takes away the urgency for anyone to pre-order this month.
Offline geewiz
« Reply #299 on: Thu, 03 December 2020, 02:11:52 »
That's probably the reason why it's available at a discount for the first 30 days.
