Author Topic: [IC] MT3 Extended 2048  (Read 228519 times)
Offline Vizir
Re: [IC] MT3 Extended 2048
« Reply #150 on: Mon, 13 July 2020, 12:43:07 »
Ergo still needs 2x R5 1.5u (and 2x 1.25u)
Sent from my Pixel 4 XL using Tapatalk
Offline ryukomatoi
« Reply #151 on: Mon, 13 July 2020, 16:34:51 »
If it comes in WS2 white, I'd buy for sure.
Offline radam
« Reply #152 on: Mon, 13 July 2020, 16:54:35 »
Unless the ergo kit is going to turn into an assembly kit, it probably shouldn't have 1.25u in it. I understand not wanting to buy more than 1 kit for your needs, but there are many other options for the r5 bottom row to fill those modifiers.
I'd rather have alternate options for some of the other 1.5u keys; things that don't exist in other kits (r4 return, r3 ", r1 delete); or 1.5u blanks.
Offline jimboytacos
« Reply #153 on: Mon, 13 July 2020, 18:32:34 »
Agree.
Ergo kit needs two more 1.5u row 5
Offline cijanzen
« Reply #154 on: Mon, 13 July 2020, 21:53:27 »
Thank you for R5 bottom row!
Offline winterbear
« Reply #155 on: Tue, 14 July 2020, 05:24:31 »
This looks exciting! I'll definitely keep an eye out for it.
If I wanted to fit this onto my Niz Plum Atom68 (65%), I'm probably looking at Alpha, Modifiers, and if I want colors, Accent Modifiers, is that right?
Any chance for some R1 - R4 accents for the Page Up, Page Down, Home, etc.?
Current:
Realforce 87U, Niz Plum Atom 68 (35g), CM Storm QF Blue
Previously Owned:
Leopold Tenkeyless Brown, Leopold Tenkeyless Blue, HHKB Pro 2 (Blank, Charcoal), Poker X Red
Offline Vizir
« Reply #156 on: Tue, 14 July 2020, 13:52:51 »
What you'd rather have is not what I'd rather have. Do not try to make my suggestion irrelevant just coz you have different thoughts or needs.
Here is the last /dev/tty mt3 ergo set
Offline radam
« Reply #157 on: Tue, 14 July 2020, 16:35:59 »
Where are the 1.25u mods in that image?
My point was that you have the option to get whatever r5 modifiers that you want in other kits. If this kit is going to be expanded, it would be nice to have alternate r1, r2, r3, r4 mods that will never be available in other kits. I would still need to pick up another mod kit for the exact 1u r5 mods that I use.
The /dev/tty ergo kit has many options that would be nice to have in the ergo kit here (which are exactly the keys that I asked for)
« Last Edit: Tue, 14 July 2020, 16:41:29 by radam »
Offline Vizir
« Reply #158 on: Tue, 14 July 2020, 18:29:28 »
The reason I posted that image is so that you can see that you get your choices and I get mine. Don't shoot down my critique coz you don't think it valid. Ergo kits need those keys, imo.
There are many boardwalk-esque keyboards now which use R5 1.5u's. and a fewer number which do 1.25u's. i personally don't use 1.25u's, but I will still mention them coz I think those need support too.
If you are implying that I use whatever R5 1.5u's I can scavenge with random legends from other sets but you NEED multiple legends for each key already present, is kind of ironic.
You can't use the R4 1.5u shift (and want enter) but want me to use random R5 1.5u legends and I have to purchase a whole set and even then I don't get the correct legends.
« Last Edit: Tue, 14 July 2020, 18:34:49 by Vizir »
Offline radam
« Reply #159 on: Tue, 14 July 2020, 19:34:16 »
You posted that picture earlier as well, saying that /dev/tty added support for the keys you were asking for. How is it showing me that I get my choices? I get them if I go purchase /dev/tty?
I'm not implying you "scavenge random legends". You never even mentioned WHAT legends you want. Just that you want 2x1.5 and 2x1.25u r5. So presumably they can be whatever? The mods kit and nomad kits have 1.25 r5 mods of every type. You literally have your pick, if you choose to spend the money, of whatever coverage you want in r5. As do I. The ergo kit is missing some r1 mods that I need, but I'm not asking for those, because the other mods are more important. Those can only be added to ergo, and I can get those 1u mods in nomad if I choose.
1.5 r4 enter does not exist, nor does it make sense, in any other kit. If it did, I could just buy that kit if legend accuracy was important to me. Same goes for ANY 1.5u r1 or R3. If /dev/tty offers these as options, there must be other ergo users that can benefit from them. The only place for me to request these keys is in this kit. There is effectively zero chance for them to be included in any other kit.
If ext 2048 ergo has the same coverage as /dev/tty ergo mods, there is nothing more I could personally want, and any ergo users happy with that kit would be happy here. If other ergo users need different modifiers, I would prioritize the 1.5u mods in r1-r4 before adding anything else.
I'm done trying to make this case.
Offline Vizir
« Reply #160 on: Tue, 14 July 2020, 20:28:25 »
See devtty ergo kit. It fixes most if our issues. I posted that to explain how things could be done, an example of an almost complete ergo kit. It also contains the legends
I would like along with what you wanted as a discussion starter with the designer of this set on how to cater to ergo users. The designer can either use that same template or come up with something unique.
We both had feedback, and we could have had a conversation with the designer instead of YOU deciding how he/she should do it. If you want to make the decisions, run your own set. Until then, don't try to stop others from providing feedback. The decision will be the set designers to make.
Offline GokieKS
« Reply #161 on: Wed, 15 July 2020, 20:50:03 »
Oh man, I wish those accent sets were available on the original Extended 2048, as I much prefer OEM profile to MT3. :(
Offline rockydbull
« Reply #162 on: Thu, 16 July 2020, 08:33:10 »
Original 2048 was cherry profile, but maybe accents for R2?
Offline biip
    • @biipmk
« Reply #163 on: Thu, 16 July 2020, 08:38:35 »
Definitely :thumb:
Offline biip
    • @biipmk
« Reply #164 on: Thu, 16 July 2020, 09:52:15 »
Some kits update.
and additions:
« Last Edit: Thu, 16 July 2020, 10:35:56 by biip »
Offline GokieKS
« Reply #165 on: Fri, 17 July 2020, 01:34:19 »
Definitely :thumb:
Oooh, there definitely is a R2 for the Cherry (I forgot which one it was since it wasn't in front of me) profile Extended 2048 coming?
Offline biip
    • @biipmk
« Reply #166 on: Fri, 17 July 2020, 04:07:53 »
small update ;D
Offline violeaf
« Reply #167 on: Fri, 17 July 2020, 07:04:26 »
Looks really nice.
Just my personal opinion - apologies if I missed it, but as italic is one of the main features, it would make sense to make the following also more obviously italic (could just be me but they are not that obvious)
Print screen
Scroll lock
Delete
Arrows
Ctrls
(edit)
Numlock
Divide and multiply signs
« Last Edit: Fri, 17 July 2020, 07:05:58 by violeaf »
Offline biip
    • @biipmk
« Reply #168 on: Fri, 17 July 2020, 08:04:00 »
and last update (for now)
Offline winterbear
« Reply #169 on: Fri, 17 July 2020, 18:39:14 »
Can we add a R2 Delete key to the modifier kit?
Current:
Previously Owned:
Offline konstantin
  • Formerly constexpr
« Reply #170 on: Sat, 18 July 2020, 02:11:44 »
There are already R0, R1 and R2 Delete keys in the Modifiers kit.
Offline mode
« Reply #171 on: Sat, 18 July 2020, 02:54:43 »
Would love R4 `~ and R1 §± in the intl kit so european AEK layouts are possible.
Offline uncleakamai
« Reply #172 on: Sun, 19 July 2020, 00:26:04 »
Looking forward to this!
Offline johndavidwright
« Reply #173 on: Mon, 20 July 2020, 21:29:24 »
I’m in!
Offline filuwow
« Reply #174 on: Mon, 20 July 2020, 22:36:49 »
Alpha kit mixup with susuwatari could be interesting  :p :p :p
Anw, even accent kit can go with alpha and you dont need to get extra kit like /dev/tty/
« Last Edit: Mon, 20 July 2020, 22:38:22 by filuwow »
Offline parablol
« Reply #175 on: Tue, 21 July 2020, 19:52:50 »
There's a lot to like about this. If I join I'm def getting Ergo & Colevrak. Only thing I wish for is addition if some R4 1.5u & 1u keys for thise of us who prefer it over R5.
Offline biip
    • @biipmk
« Reply #176 on: Wed, 22 July 2020, 02:23:25 »
What kit are you talking about?
Offline nao921
« Reply #177 on: Wed, 22 July 2020, 09:36:19 »
Looking forward to this.  So the vintage base + vintage modifier will not be part of the Drop GB this fall?
https://drop.com/vote/MIX-MT3-Extended-2048/result
Offline biip
    • @biipmk
« Reply #178 on: Wed, 22 July 2020, 09:39:57 »
That's an outdated project.
I didn't like the look of the "vintage"kits.
Offline toniwonkanobi
« Reply #179 on: Wed, 22 July 2020, 11:38:21 »
What about the Accent Modifiers Kit? Is that planned for Drop?
Offline biip
    • @biipmk
« Reply #180 on: Wed, 22 July 2020, 13:48:00 »
This?
« Reply #181 on: Wed, 22 July 2020, 14:15:05 »
This?
Yeah. Will that be for the Fall Drop? 🙏🏼
Offline biip
    • @biipmk
« Reply #182 on: Wed, 22 July 2020, 14:17:08 »
This?
Every kits which you can find on the first post of this thread will be available during the group buy of the set (in December on Drop).
Offline musicgecko
« Reply #183 on: Wed, 22 July 2020, 14:39:41 »
KAT profile please!
« Reply #184 on: Wed, 22 July 2020, 16:04:29 »
This?
Okay. Good to know. I was confused because the voting thing only had a few of the sets. I guess the point of that is to have a pseudo-IC as to which set you’ll do (vintage vs regular)?
Offline samanth
  • Thocc
« Reply #185 on: Wed, 22 July 2020, 18:59:05 »
This is a must buy for me. will start saving up for this kit.
Sent from my ONEPLUS A3003 using Tapatalk
Offline husnulhamidiah
« Reply #186 on: Wed, 22 July 2020, 20:48:11 »
any update on pricing? i'm definitely in.
Offline lamonayon
« Reply #187 on: Thu, 23 July 2020, 12:16:01 »
Can't wait for December!  Are the colors final, what tone of white is this (sorry if I missed it), WS1 or WS2?
Offline biip
    • @biipmk
« Reply #188 on: Thu, 23 July 2020, 12:17:37 »
L9 BV
Offline parablol
« Reply #189 on: Thu, 23 July 2020, 14:44:05 »
Not sure actually which kit would be appropriate. I just wish there was an option for R4 Tsangan bottom row mods.
Offline thedavefulton
« Reply #190 on: Thu, 23 July 2020, 18:15:31 »
So I'm going to ask one more time (since I haven't actually been told no  ;D ), is there any possibility of an R4 1u RCtrl . Even if it was in a Nomad kit, it would be deeply appreciated. Set is fire :thumb:
Offline konstantin
« Reply #191 on: Thu, 23 July 2020, 19:17:27 »
There is a generic-looking R4 1u Fn/Code key in Modifiers, as well as a second one in Nomad, why not use that?
« Last Edit: Thu, 23 July 2020, 19:20:31 by konstantin »
Offline biip
    • @biipmk
« Reply #192 on: Fri, 24 July 2020, 02:28:52 »
Wouldn't the 1u R4 >_ key work?
« Reply #193 on: Sun, 26 July 2020, 12:07:15 »
I use the HHKB layout but instead of the 1u Fn key next to the RShift, I prefer to use that as a Ctrl key. There are definitely keys I could use instead, and there are matching >_ keys I could use in place of the Ctrl keys, but it wouldn't be perfect  :(
So I just wanted to ask  :thumb:
Offline biip
    • @biipmk
« Reply #194 on: Mon, 27 July 2020, 02:34:08 »
That's too specific. I cannot please everyone's specific needs, sorry!
Offline ILikeShorts
« Reply #195 on: Sun, 02 August 2020, 10:31:35 »
These look fantastic. I greatly appreciate the colevrak kit. What're the chances of mono-legends?
Offline biip
    • @biipmk
« Reply #196 on: Sun, 02 August 2020, 11:41:52 »
latin mono legends?
Offline ILikeShorts
« Reply #197 on: Sun, 02 August 2020, 17:46:27 »
latin mono legends?
Oops, sorry. I mean for the numbers and special characters.
Offline therealemanuelmartinez
« Reply #198 on: Mon, 03 August 2020, 15:38:29 »
Words cannot express how much I love you for including a media kit. I hope it does end up making it through to the GB.
Offline biip
    • @biipmk
« Reply #199 on: Tue, 04 August 2020, 03:08:05 »
