Author Topic: [IC] GSKT-00  (Read 143642 times)
Offline weaston
[IC] GSKT-00
« on: Mon, 06 January 2020, 18:49:17 »
GSKT-00
The first in the GSKT series. Gasket mounted, 6063 aluminum.
Introduction
Some of you may know me or know about this board, but for those who don't, I'm Weaston and this is the GSKT-00. I originally made this board around a year and half ago and it was a small private group buy for some friends. After all the time that we have spent with the board, it has become a mainstay on many desks. For this I am extremely grateful and proud, that people use a keyboard I made and enjoy it so much that it got to the top of their rotation. Ever since pictures and videos of the 00 began to surface, I have gotten many pms asking about the future of the board. Now that it has had enough time to really be tested and approved, it feels like it's time that I open up a public sale.
Some of you may have heard rumors about why I only wanted to sell them privately or about me not wanting people to share pictures of the internals. Keeping all this quiet was an attempt to just let the board exist without any hype or expectations around it. I wanted the people who had them to get to use it as honestly as they could so I could gather feedback over a long amount of time. So with that, I now feel comfortable selling them here, and I hope you enjoy the 00 just as much as me and my friends have. My personal favorite setup for it is a half plate with 62-67g linears, it really hits a sweet spot with the compression of the gasket, the flex and the sound.
The GSKT-00 comes in Silver, Gray, Black or Red.
Minimum 50 units, 200 unit maximum with 2 cases per person, 4 plates per person and 4 pcbs per person.
All components are priced separately, this is done to better inventory parts per order. Each case comes with 1 gasket and 1 sets of screws. Additional gaskets are $10 each and additional screws are $5 each.
I would like to start the GB as soon as possible. Shooting for January 20th as the opening date.  I don't know the GH process and if I need to get approval for a GB thread or what, so trying to give some buffer time.
More info about GB details will be outlined in the GB thread, but I included final pricing below.
Notes to consider
The 00 had very specific internals which made the usage of larger screws not possible (in it's current design at least) so it uses M2 screws for assembly. They are hex head and stainless steel but please be warned if you have a fear of small screws or cases that use them as you will need to be gentle and careful. The USB port also is fairly tight and has a bit more than the usual depth that other boards have. Most cables will work but those with large heads will not. Personally I know that Mechcables and Yarbo work, and so will anything that doesn't have an oversized head like a Lindy. Any standard "custom" cable with the heatshrinked head should be perfectly fine. I have not tested this thoroughly as I am not a cable connoisseur so I make no guarantees here, but you have been warned.
The 00 also does NOT support 6.25U bottom row, it is 7U only. This was done as preference on my part as I typically use 60% boards in WKL or HHKB layouts and I far prefer 7U spacebars.
Supported layouts below.  MX plates are universal caps lock (all 3 positions), split right shift and split backspace.  Non-splits are still supported by the plate.  ANSI Enter only unless you opt for an ISO plate which is ISO Enter only and split left shift also.  You will have your choice of layout on the GB order form.
The original units did not have bumpon cuts on the bottom, but they have been added to these units for ease of use.
Cerakoting is an optional service that can be done as part of the GB. Please be ready to wait at least an additional 3 weeks of time after the initial ship date for this service to be complete and have units ready for shipping. Colors on a board will differ slightly from photos online, so please pick your color carefully. There will be no refunds or free re-coating if you do not like the color.
Pricing
- Case: $225
- Plate: $25 Half - $30 Full
  - Materials: Aluminum (Silver, Gray, Black, Red), Stainless Steel (Brushed), POM (black transparent, expect slight warping), Acrylic (Clear), Polycarbonate (Frosted)
- PCB: $25
- Shipping: $25 CONUS - $45 International
- Cerakote (any non-custom color): $50
Typing Tests and Pictures
Pictures:
Full album of a 00 from the original run (note that it did not have bumpon cuts but new units will): https://imgur.com/a/9lQFCkH
Brendan's Silver WKL with Orange Alps
Chris Swires Gray HHKB
LightningXI's Silver Standard with Cherry SAT - https://imgur.com/a/YuIZroq
ChucklingKumquat's Silver WKL with GMK Royal Alpha - https://imgur.com/gallery/Rb86HZp
inachie's Red HHKB - https://i.redd.it/eaecyq1bddx11.jpg
Typing Tests:
Taeha Types
LightningXI
LightningXI Flex Test
Invisibiliti
Invisibiliti #2
Chris Swires
Chris Swires #2
Eizdeb
ChucklingKumquat
A final thank you to all the friends who have used this board and those who have expressed interest in it.  You are appreciated.  :thumb:
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
Offline weaston
Re: GSKT-00
« Reply #1 on: Mon, 06 January 2020, 18:49:46 »
Reserved
Offline PeenixStarr
Re: [IC] GSKT-00
« Reply #2 on: Mon, 06 January 2020, 18:50:51 »
:thinkySweat:
Offline dimo
Re: [IC] GSKT-00
« Reply #3 on: Mon, 06 January 2020, 18:50:54 »
yes
Offline XtReeM1337n355
Re: [IC] GSKT-00
« Reply #4 on: Mon, 06 January 2020, 18:51:00 »
ULTRA HYPE. I’ve wanted one of these for a while
Offline would?
  • Formerly wouldworks
    • Finder Works
Re: [IC] GSKT-00
« Reply #5 on: Mon, 06 January 2020, 18:51:34 »
Im going to be gunning HARD for this
Offline zian_
Re: [IC] GSKT-00
« Reply #6 on: Mon, 06 January 2020, 18:52:18 »
Yep. Absolutely.
Offline Jae-3soteric
  • https://www.youtube.com/channel/UCAIHiFKJt69HNad6r
    • Jae | Top Clack
Re: [IC] GSKT-00
« Reply #7 on: Mon, 06 January 2020, 18:53:11 »
Will def be in on this. I really enjoyed Chris’ board when I visited him
Sent from my iPhone using Tapatalk Pro
Offline duckboi
Re: [IC] GSKT-00
« Reply #8 on: Mon, 06 January 2020, 18:53:47 »
200 units? u wild for this one
The m0ar empty you feel,  the m0ar space for Keycaps..
Offline Shenpai
  • always found
    • padoru
Re: [IC] GSKT-00
« Reply #9 on: Mon, 06 January 2020, 18:54:02 »
yay
Nunu | KR FC660C
Offline mrpetrov
Re: [IC] GSKT-00
« Reply #10 on: Mon, 06 January 2020, 18:54:17 »
Awesome that you're rerunning this, thanks a lot weaston!
Offline Quriosity
Re: [IC] GSKT-00
« Reply #11 on: Mon, 06 January 2020, 18:56:11 »
So very interested
Offline belgium_waffles
Re: [IC] GSKT-00
« Reply #12 on: Mon, 06 January 2020, 18:56:56 »
pretty cool i guess
Offline Remsky
  • Lubed switch count > Puddsy post count
Re: [IC] GSKT-00
« Reply #13 on: Mon, 06 January 2020, 18:57:35 »
time to dremel my 00 for bumpon cuts and sharpie it red for the stripped ano!
TGR Jane v2 - GSKT00(coming) - TGR Jane CE V2 - TGR Poly alice - LZ Physix - Matrix 8XV 2.0 - RS - LZ FE - Dalco 959 Mini GT edition (coming) - Mc65 - Hiney TKL one - HHKB Pro 1 - 25th anniversary edition HHKB pro Hybrid - 30th anniversary Filco 2S keyboard
Offline tex_live_utility
  • MX brown apologist
    • twitch.tv/salt_rock_lamp
Re: [IC] GSKT-00
« Reply #14 on: Mon, 06 January 2020, 19:01:18 »
This is probably going to sell out instantly. Hopefully I get one of the 200 units. Impressively low price as well. Good luck with the GB.
Edit: would you consider making the plate file available for modification? I'm one of those weirdos who actually likes 6.25 on 60%.
« Last Edit: Mon, 06 January 2020, 19:08:17 by tex_live_utility »
Offline Furikurichemy
Re: [IC] GSKT-00
« Reply #15 on: Mon, 06 January 2020, 19:02:25 »
So keen for this!!
Offline snelltrail
Re: [IC] GSKT-00
« Reply #16 on: Mon, 06 January 2020, 19:03:37 »
One of the best sounding boards out there for sure. Will be trying my luck!!
Offline Shadohhh
Re: [IC] GSKT-00
« Reply #17 on: Mon, 06 January 2020, 19:04:26 »
Excited to see this finally reach the public. Glad that I got to support this project.
Offline zekkin
  • my entire life was unlimited zekk works
Re: [IC] GSKT-00
« Reply #18 on: Mon, 06 January 2020, 19:04:35 »
i buy
Offline dantambok
Re: [IC] GSKT-00
« Reply #19 on: Mon, 06 January 2020, 19:12:39 »
let's go
Stuff  I have
2x TGR Alice / TGR 910 RE / TGR 910 CE / TGR 910 VKC / 2x TGR Jane V2 / 2x Matrix 2.0 / Matrix 2.2 / Matrix 1.2OG / Lyn Whale v2 / Lyn EM7 v3 / DK Saver / Keycult No. 1/60 /  Quantrik Hachi /  Quantrik  Kyuu / Duck Orion V2 / TGRxSinga Unikorn R1 / 2x Unikorn 2.2 / Quantrik QXP /  JER80 / TMO50 / 2x 86u / ION i69 / LZ MP / 2x FMJ80 / TGR Jane V2 CE / Matrix Project F / IDB60 / is0  / MXSS / Atom TKL / HBCP / Noxary 280  / FLX Virgo / Modern M0110 / Matrix 2.0 ADD / TGR Police / Noxary XRF / Noxary Vulcan Pro / 35g0 Mimi / Matrix 2.0CP / Kira80 / Exent 65% / FMJ60 / Haus 65 / Kikuichimonji / Cake 60 / 2x AU Unikorn  Commission/ LZ XE / Paraluman 60 / AI03 Andromeda / Dalco 959 Mini GT /  Finder Works Hyphen / Linworks EM8 / GAFxTGR 910 / TGRxKLC Dolice / TGR 910v2 ME / Noxary Valhalla / Hiney Ibis / LZ REs / PerryWorks MC65 / Hiney Poly TKL One / RS60 / Zekk RBB / Keycult No 2 TKL
100+ GMK sets
Offline Captain Shwah
Re: [IC] GSKT-00
« Reply #20 on: Mon, 06 January 2020, 19:13:40 »
Cool stuff! I've been keeping an eye on this board so its nice to see a public buy after successful trials.
Offline Fredington
    • Instagram
Re: [IC] GSKT-00
« Reply #21 on: Mon, 06 January 2020, 19:15:28 »
Huh. I told myself I wouldn't get anymore boards but this might change that.
Offline kconfire
Re: [IC] GSKT-00
« Reply #22 on: Mon, 06 January 2020, 19:16:51 »
Hell yeah.
[Collection] Monokei Kei SE, Realforce R2 TKL, Leopold FC660C
[Soon TM] Monokei Tomo SE, GSKT-00
Offline dondongler
  • Gotta Light?
Re: [IC] GSKT-00
« Reply #23 on: Mon, 06 January 2020, 19:19:11 »
Ahh yeah, stoked to have the chance to grab one!
Offline txclack
Re: [IC] GSKT-00
« Reply #24 on: Mon, 06 January 2020, 19:26:26 »
Amazing board, stellar price, great designer.
Offline Slash Emperor
  • Lust for life lost, keyboards acquired.
Re: [IC] GSKT-00
« Reply #25 on: Mon, 06 January 2020, 19:31:45 »
Super stoked for this, thanks for opening this up to a public GB.
Sent from my Pixel 3 XL using Tapatalk
Offline Warrenified
Re: [IC] GSKT-00
« Reply #26 on: Mon, 06 January 2020, 19:36:06 »
Been on the hunt for one for a while, glad its coming to the public! Thanks weaston :)
Offline Storm-
Re: [IC] GSKT-00
« Reply #27 on: Mon, 06 January 2020, 19:37:35 »
I'm down, very excited.
TGR Jane V2 CE | TGR Alice | Unikorn
Offline Xerpocalypse
Re: [IC] GSKT-00
« Reply #28 on: Mon, 06 January 2020, 19:38:12 »
Very interested 👀
Offline Remsky
Re: [IC] GSKT-00
« Reply #29 on: Mon, 06 January 2020, 19:40:07 »
The pcb doesnt support 6.25U
Offline vaughno
Re: [IC] GSKT-00
« Reply #30 on: Mon, 06 January 2020, 19:45:10 »
Unikorn | Orion v3 | GSKT-00
Offline CarterH
Re: [IC] GSKT-00
« Reply #31 on: Mon, 06 January 2020, 19:45:34 »
Been an honor to support this board since its inception, so glad more people will get to experience it.
Happy to give my thoughts on the 00, I've felt a lot of em.
Here's some old pics of mine: https://imgur.com/a/jNgBYnV
Re: [IC] GSKT-00
« Reply #32 on: Mon, 06 January 2020, 19:47:36 »
Will this board support usb type c?
Offline aeryxz
    • aeboards
Re: [IC] GSKT-00
« Reply #33 on: Mon, 06 January 2020, 19:47:48 »
keen
Offline gabbbe
Re: [IC] GSKT-00
« Reply #34 on: Mon, 06 January 2020, 19:50:19 »
That’s the board I want!
Offline Remsky
Re: [IC] GSKT-00
« Reply #35 on: Mon, 06 January 2020, 19:51:44 »
this board is mini usb
Offline datfroyodoe
Re: [IC] GSKT-00
« Reply #36 on: Mon, 06 January 2020, 19:54:09 »
Will there be a library of the cerakote colour options/finishes? Interested to know what's available/applicable for this board.
Offline PikaJoyce
Re: [IC] GSKT-00
« Reply #37 on: Mon, 06 January 2020, 19:54:54 »
I’m really hoping to hop in on this!!!! Best of luck to everyone trying to nab one :)
Offline weaston
Re: [IC] GSKT-00
« Reply #38 on: Mon, 06 January 2020, 19:59:01 »
Aw man I thought I put the link in the body, must have missed it.
You can get any H Series coating, that's the standard Cerakote.  Check them all out on the official site: https://www.cerakote.com/finishes/?tab=coatings&cat=HSERIES
It's cerakote so the feeling and color reflection will definitely be much more matte than ano, but it doesn't affect fitment because it's super thin.  The aluminum I use also takes really well to it, so there should be little to no inconsistencies in it.
Offline NotBing
Re: [IC] GSKT-00
« Reply #39 on: Mon, 06 January 2020, 20:07:55 »
Oh baby, give me that g00sket
Collection: Yohane, RS, RS60, MC65
Soon: GSKT-00
Offline datfroyodoe
Re: [IC] GSKT-00
« Reply #40 on: Mon, 06 January 2020, 20:15:28 »
Cheers! :)
Offline heloitsame
Re: [IC] GSKT-00
« Reply #41 on: Mon, 06 January 2020, 20:19:04 »
- Case: $225
just wanting to clear this up, are the materials referring to just plate options? would also like to see the plate!
super hyped for this though!
Offline nickaster1
Re: [IC] GSKT-00
« Reply #42 on: Mon, 06 January 2020, 20:21:44 »
- Case: $225
Yes
Offline weaston
Re: [IC] GSKT-00
« Reply #43 on: Mon, 06 January 2020, 20:22:07 »
Yeah that's just for plates, cases are only 6063 Aluminum.
Offline trg1234
Re: [IC] GSKT-00
« Reply #44 on: Mon, 06 January 2020, 20:23:39 »
hope I snag one
Offline haingo1094
    • @pump_upp - best crypto pumps on telegram !
Re: [IC] GSKT-00
« Reply #45 on: Mon, 06 January 2020, 20:33:53 »
Hell yeah , i am down and wait for it for so so so long
Offline sirieous
  • help
Re: [IC] GSKT-00
« Reply #46 on: Mon, 06 January 2020, 20:38:29 »
Are spots going to be raffled or is it first come first serve. I feel like with a 200 cap this gb is gonna run out real quickly.
Offline hineybush
  • student of error
    • hineybush keyboards
Re: [IC] GSKT-00
« Reply #47 on: Mon, 06 January 2020, 20:39:14 »
sick. GLWB
Offline TheArcticFox_27
Re: [IC] GSKT-00
« Reply #48 on: Mon, 06 January 2020, 20:47:06 »
Hell yeah starting the week with some good ic's!
Offline weaston
Re: [IC] GSKT-00
« Reply #49 on: Mon, 06 January 2020, 20:48:41 »
FCFS, raffles are too complicated.  If the 200 fill too quickly I may open it up a bit more, not much though.  We'll have to wait and see  :thumb:
