Author Topic: [IC] GSKT-00  (Read 147769 times)
Offline weaston
Re: [IC] GSKT-00
« Reply #50 on: Mon, 06 January 2020, 20:50:03 »
DK Saver | Kingsaver | OTD 360 Corsa | OTD 456GT | OTD Cheat | KMAC 1.3 | KMAC 1.2 | KMAC Happy | KMAC Pad | KMAC Mini (Revo) | Singa | HHKB Pro 1 | GSKT-00 | IBM 5251 | IBM Model F XT | IBM Model M | Dolch PAC | Kinesis Advantage
Offline sirieous
  • help
Re: [IC] GSKT-00
« Reply #51 on: Mon, 06 January 2020, 20:51:08 »
Are spots going to be raffled or is it first come first serve. I feel like with a 200 cap this gb is gonna run out real quickly.
FCFS, raffles are too complicated.  If the 200 fill too quickly I may open it up a bit more, not much though.  We'll have to wait and see  :thumb:
Thanks for the quick reply. Hopefully I can get in.
Offline eniigma
    • Storefront:
Re: [IC] GSKT-00
« Reply #52 on: Mon, 06 January 2020, 20:51:28 »
couldn't exactly tell from OP, is a plate/pcb included in the base kit? or is that separate?
and will plate files be public later on?
also, would be nice if you would release a PCB footprint file in the case that it stops working, since it is nonstandard.
best of luck with the GB man!
Offline Mcnos
    • GMK Fuyu
Re: [IC] GSKT-00
« Reply #53 on: Mon, 06 January 2020, 20:53:33 »
Nice
Offline noahf
Re: [IC] GSKT-00
« Reply #54 on: Mon, 06 January 2020, 20:54:36 »
300 shipped? in for sure
it wasn't clear but will all 3 versions of the top be available? WK, WKL, HHKB?
Offline deathwalker113
Re: [IC] GSKT-00
« Reply #55 on: Mon, 06 January 2020, 20:57:05 »
love it
Offline Solotov
Re: [IC] GSKT-00
« Reply #56 on: Mon, 06 January 2020, 21:00:36 »
Holy moly  :eek:
Flex is love, flex is life.
Offline bthezebra
Re: [IC] GSKT-00
« Reply #57 on: Mon, 06 January 2020, 21:01:27 »
More open is more cool
Offline TheArcticFox_27
Re: [IC] GSKT-00
« Reply #58 on: Mon, 06 January 2020, 21:04:08 »
Btw, all 3 layouts will be available again? Standard, Winkeyless and HHKB?
Offline Visionaire
Re: [IC] GSKT-00
« Reply #59 on: Mon, 06 January 2020, 21:04:16 »
Welp.  :eek:
Offline NoxNoxNox
Re: [IC] GSKT-00
« Reply #60 on: Mon, 06 January 2020, 21:06:00 »
Oh this is interesting.
Is there a list of what the 'standard color' cerakote options will be? Or is that the 4 colors you mentioned in the posdt?
Offline xine007
Re: [IC] GSKT-00
« Reply #61 on: Mon, 06 January 2020, 21:08:04 »
Great group buy run last time  ;D  Easily the smoothest keyboard GB I've been in and it's a super price for an excellent board!
Offline weaston
Re: [IC] GSKT-00
« Reply #62 on: Mon, 06 January 2020, 21:09:33 »
All pieces are priced separately. You will order them all at the same time, but I separated the price for more transparency and ease of sorting on my part.  There isn't a pre-made "base kit" for that reason and I don't want to force a default plate choice on someone.
Probably won't release any files, can always offer new runs of components, or make replacements if anything poses a problem as far as pcbs go.
Thanks for the kind words.
Yes all 3 versions are available.
Offline ramblinrose
Re: [IC] GSKT-00
« Reply #63 on: Mon, 06 January 2020, 21:13:56 »
Cool to see this one have a public run! What's the front height?
Offline weaston
Re: [IC] GSKT-00
« Reply #64 on: Mon, 06 January 2020, 21:15:56 »
No standard options for Cerakote.  Any H-Series Cerakote is fine, take your pick.  The colors listed are anode colors, no flexibility on those unfortunately.
Re: [IC] GSKT-00
« Reply #65 on: Mon, 06 January 2020, 21:16:12 »
I've had a soft spot for these since I saw Lightning's build. I love the fact that you allowed such a long period of time to gather feedback on the board, and the mounting system is really well thought out. The price point is amazing too. Will these be produced by the same factory that made the ones shown in OP?
Good luck with the GB; I hope I have the money to join when it starts.
Offline Zeelobby
Re: [IC] GSKT-00
« Reply #66 on: Mon, 06 January 2020, 21:22:36 »
Definitely gonna try to get in on this one.
Sent from my Pixel 3 XL using Tapatalk
Offline beefwelldone
Re: [IC] GSKT-00
« Reply #67 on: Mon, 06 January 2020, 21:31:11 »
Yess
Offline weaston
Re: [IC] GSKT-00
« Reply #68 on: Mon, 06 January 2020, 21:52:46 »
Wow thanks man, that means a lot coming from you :thumb:
Yep these will be from the same factory.
Offline wt1155
Re: [IC] GSKT-00
« Reply #69 on: Mon, 06 January 2020, 22:30:57 »
What is the type of port for the pcb ? Might need some additional info on the pcb and the plate eg: if the pcb or full plate have some flex cuts on it ?
« Last Edit: Mon, 06 January 2020, 22:33:47 by wt1155 »
Offline weaston
Re: [IC] GSKT-00
« Reply #70 on: Mon, 06 January 2020, 22:39:53 »
Port is Mini B.
Ah I guess i didn't show any pictures of the plates, my bad.  The mx variants are below, alps are more or less the same so not worth showing atm.  In these pictures the full plate has an iso split left shift, but the standard prod units will be the ansi left only like the half plate shows.
They don't have extra flex cuts or relief cuts or whatever you want to call them because the board itself is flexible enough to not need them, and I didn't notice a sound difference when I tested with a plate that had them.  As far as the full plate at least.  I took some extra material out for the half plate spacebar area to get it more pcb-mount-like.
Offline pixelpusher
Re: [IC] GSKT-00
« Reply #71 on: Mon, 06 January 2020, 22:43:23 »
glad to see this coming to the masses.  Hope I can snag one.
Offline wt1155
Re: [IC] GSKT-00
« Reply #72 on: Mon, 06 January 2020, 22:45:23 »
Port is Mini B.
Nice thank you for replying to me man  :)
Offline Acereconkeys
  • Happiness = life - expectations
Re: [IC] GSKT-00
« Reply #73 on: Mon, 06 January 2020, 22:56:46 »
Whew this came out of nowhere. I feel like i'll really regret if i don't join in on this though I wish we had a bit more time to prepare.
Either way, great work, and good luck on the buy! I think you'll need it as 200 is a colossal task!
Quick question, are all of the plate options full? or any of them half?
« Last Edit: Mon, 06 January 2020, 23:00:47 by Acereconkeys »
TMO50 | Jane V2 CE Incoming | Realforce 87u 55g | Aergo
Aergo design and build log: https://geekhack.org/index.php?topic=103681.msg2840918#msg2840918
Offline noorejji
Re: [IC] GSKT-00
« Reply #74 on: Tue, 07 January 2020, 00:05:47 »
Any recommendations on plate material and wether to use half or full for this case? I'm mostly interested in a deep and muted sound. I've never tried half-plate or PC/POM/acrylic, so I don't know how I'll like the flex. I plan to use tactile switches.
Offline renzpwns
  • I didn't like money in my wallet anyways.
Re: [IC] GSKT-00
« Reply #75 on: Tue, 07 January 2020, 00:06:08 »
Damn nice to see this happen. Been wanting one since trying them at the NorCal meet a couple of years ago.
Offline MMKB
Re: [IC] GSKT-00
« Reply #76 on: Tue, 07 January 2020, 00:06:52 »
Thumbs up for the cerakote option. (A ready-to-paint version works too.) Imo the color and finish of cerakote matches ABS keycaps better than anodization.
Offline MMKB
Re: [IC] GSKT-00
« Reply #77 on: Tue, 07 January 2020, 00:10:33 »
Polycarbonate this round please?
Offline NotBing
Re: [IC] GSKT-00
« Reply #78 on: Tue, 07 January 2020, 00:17:04 »
From my personal experience, I find that half plate mount provides for a more softer bottom out with a softer sound. I think that it's somewhat dependent on the material of the half plate that you're using as well. With an aluminum half plate, it might still be firm, but with the aforementioned softer bottom out and some flex. Granted, I haven't tried a GSKT-00 yet, so please take this with a grain of salt.
« Last Edit: Tue, 07 January 2020, 00:27:25 by NotBing »
Collection: Yohane, RS, RS60, MC65
Soon: GSKT-00
Offline temp0321
Re: [IC] GSKT-00
« Reply #79 on: Tue, 07 January 2020, 00:36:42 »
What color is the pcb? I think Taeha has red pcb but couldn't find in the thread
Offline vegs
Re: [IC] GSKT-00
« Reply #80 on: Tue, 07 January 2020, 00:41:33 »
So glad you are doing ISO!
I'm in for one if I manage to get a spot.
« Last Edit: Tue, 07 January 2020, 00:46:47 by vegs »
hhkb 4 life
buy less
Offline vegs
Re: [IC] GSKT-00
« Reply #81 on: Tue, 07 January 2020, 00:48:54 »
From OP:
- Plate: $25 Half - $30 Full
hhkb 4 life
buy less
Offline wd9001
  • Whoms't | 22nd century schizoid man
Re: [IC] GSKT-00
« Reply #82 on: Tue, 07 January 2020, 01:21:52 »
Been dreaming of this for so long! Question about Alps at101 caps support, Brendan's build seems to show that it is being supported though it isn't shown in the supported layouts. Can you confirm that they are?  ;D
Lunar AEK| Klippe R1 |
Klippe S (production)|
GSKT (Pre-Invoice)
Offline nguyenhimself
Re: [IC] GSKT-00
« Reply #83 on: Tue, 07 January 2020, 01:23:36 »
Hi, do you have any future plan to do a 65% version of this board?
I'm quite happy with my decision to stick with arrow keys, but I'm still very intrigued by the design and reputation of the GSKT.
Thanks.
Re: [IC] GSKT-00
« Reply #84 on: Tue, 07 January 2020, 01:30:07 »
From OP:
Thank you for the info! Reading is hard  :-*
Offline iJeeSung
Re: [IC] GSKT-00
« Reply #85 on: Tue, 07 January 2020, 01:43:29 »
The idea that I’d have to prepare a separate Micro B Cable for this board feels bad. But for $300 It’s hard to pass up on.
Offline IOVERCALLHISTIOCYTES
Re: [IC] GSKT-00
« Reply #86 on: Tue, 07 January 2020, 01:43:37 »
It might last a full minute!
Neat to see it out in the wild. Thank you!
Offline Lormania
Re: [IC] GSKT-00
« Reply #87 on: Tue, 07 January 2020, 01:48:35 »
Heck yeah. Hope I am fast enough
Offline nickaster1
Re: [IC] GSKT-00
« Reply #88 on: Tue, 07 January 2020, 01:49:56 »
Thanks.
Yes please? I can’t live without arrows
Offline zekth
Re: [IC] GSKT-00
« Reply #89 on: Tue, 07 January 2020, 02:00:42 »
In
Offline Vireca
Re: [IC] GSKT-00
« Reply #90 on: Tue, 07 January 2020, 02:29:20 »
The price is 225 for kit or 225+plate+PCB?
Offline vegs
Re: [IC] GSKT-00
« Reply #91 on: Tue, 07 January 2020, 02:57:51 »
Please read OP :p
Case is $225, plate $25-30, PCB $25.
hhkb 4 life
buy less
Offline funderburker
Re: [IC] GSKT-00
« Reply #92 on: Tue, 07 January 2020, 03:24:17 »
I gotta ask... If you're interested in a product you'd like to purchase, why can't you read OP thoroughly? Writing a question like that takes about the same time as a quick scroll over OP (Pricing section is even highlighted!) or using "find" function and write "pricing", then just hit "Enter". Dude...
Sorry but I still can't fathom why people can't read simple things they're genuinely interested in.
« Last Edit: Tue, 07 January 2020, 03:29:37 by funderburker »
Keyboard design by Skepur
Offline Fredington
    • Instagram
Re: [IC] GSKT-00
« Reply #93 on: Tue, 07 January 2020, 03:26:42 »
Will there be HHKB/WKL-specific plates so that the extra holes do not show through on PC cases?
Offline MyManMart
Re: [IC] GSKT-00
« Reply #94 on: Tue, 07 January 2020, 03:44:18 »
Reread the post. There will only be aluminum cases.
Offline TexMech
Re: [IC] GSKT-00
« Reply #95 on: Tue, 07 January 2020, 03:52:23 »
Hhkb time!
Sent from my SM-G950U using Tapatalk
Offline Legoo
  • Hello
Re: [IC] GSKT-00
« Reply #96 on: Tue, 07 January 2020, 04:04:34 »
Very interested, and thanks for proposing an ISO plate option :)
E6_V2 R2 | Time80RE | OTD The Cheat | J80 | Iron180 | Solenoid MX M0110A | ACR60 | HHKB Pro 2 | Brown Alps Duck Orion v3 | TGR Alice Polycarb proto | Duck Lightpad | Orange Alps Duck Raven | TADA68 | TX75 | LZ CLS MS
Offline Zeelobby
Re: [IC] GSKT-00
« Reply #97 on: Tue, 07 January 2020, 05:08:44 »
Hmm. Never tried a half plate build. Not sure if I'd even like it lol. Wish I had one readily available to try out, but I'll probably just go full plate for not knowing any better, unless someone with more experience can convince me otherwise. Haha
Offline pr0ximity
Re: [IC] GSKT-00
« Reply #98 on: Tue, 07 January 2020, 05:15:25 »
Could always get one of each, but I’d recommend everyone try at least one half plate and this is a great one.
Offline futurecrime
  • Get Zooted
Re: [IC] GSKT-00
« Reply #99 on: Tue, 07 January 2020, 05:55:16 »
This is wonderful news. I’ve heard nothing but great things about the initial run and I never thought I’d get a chance to own one. Gonna be typing my hardest for that fcfs glory.
