Author Topic: I do not use my left shift  (Read 2608 times)
Offline gnho
« on: Sat, 20 June 2020, 00:03:45 »
I have never given this much thought before getting into this hobby, or more precisely, smaller keyboards (60%). My default layout is HHKB and I'm having a hard time figuring out what I should do with my left shift. It's just in a pretty awkward place as I'm right-handed with a weak left pinkie. Any recommendation?
Offline powwu
    • Discord
Re: I do not use my left shift
« Reply #1 on: Sat, 20 June 2020, 00:06:46 »
I only use right shift as well, and I have my left shift as (surprise) a shift. Don't overthink it. If you don't see something screaming at you to be put there, then it's probably just better to leave it as a shift.
Offline lakeboredom
« Reply #2 on: Sat, 20 June 2020, 01:12:46 »
I hit space with my right thumb.
Offline gnho
« Reply #3 on: Sun, 21 June 2020, 02:31:15 »
I found a solution! For now I'm experimenting it with autohotkey:
LSHIFT & A:: Send, {( down}{(up}{) down}{) up}{LEFT 1}
LSHIFT & S:: Send, {{ down}{{up}{} down}{} up}{LEFT 1}
LSHIFT & D:: Send,{[ down}{[ up}{] down}{] up}{LEFT 1}
Offline Maledicted
« Reply #4 on: Sun, 21 June 2020, 18:02:00 »
I don't use left shift either, unless I'm gaming, which means my right hand is on my mouse. That reason alone is enough for me to leave left shift alone even though I almost never use it.
Offline equalunique
« Reply #5 on: Sun, 21 June 2020, 19:46:19 »
Wow. I typically use both but I thought the majority of users preffered left shift instead of the right, e.g. the single left shift key on the Planck & hobbled right shift keys on 60% layouts that cram an arrow cluster on the lower right.
Offline Maledicted
« Reply #6 on: Sun, 21 June 2020, 19:54:59 »
For some reason I don't seem to mind even 1u right shift keys.
