Author Topic: keyboard powered by python  (Read 9024 times)
Offline Yihui
« on: Mon, 22 June 2020, 04:09:24 »
Two month ago I made a hand-wired keyboard powered by Python (CircuitPython). After spending some time to improve the python keyboard,
it has similar features like TMK/QMK based keyboards now.
While, with python inside,  the keyboard has some unique features. When connected to a computer, it is not just a keyboard, but also a USB drive.
The python code is in the USB drive, which make it super easy to modify keyboard code and add a extension.
To configure the keyboard's keymap, we can just edit keyboard.py in the USB drive with any text editor.
For example, use d key as a Tap-key to activate navigation functions (similar to vim).
The keymap is:
Code: [Select]
L1D = LAYER_TAP(1, D)
KEYMAP = (
    # layer 0
        ESC, 1,  2,  3,  4,  5,  6,  7,  8,  9,  0, '-', '=', BACKSPACE,
        TAB,  Q,  W,  E,  R,  T,  Y,  U,  I,  O,  P, '[', ']', '|',
        CAPS,  A, S, L1D,  F,  G,  H,  J,  K,  L, ';', '"',       ENTER,
        LSHIFT,  Z,  X,  C,  V,  B,  N,  M, ',', '.', '/',       RSHIFT,
        LCTRL, LGUI, LALT,        SPACE,         RALT, MENU,  L1, RCTRL
    # layer 1
        '`',  F1,  F2,  F3,  F4,  F5,  F6,  F7,  F8,  F9, F10, F11, F12, DEL,
        ___, ___, ___, ___, ___, ___, ___,PGUP, ___, ___, ___, ___, ___, ___,
        ___, ___, ___, ___, ___, ___,LEFT, UP,DOWN,RIGHT, ___, ___,      ___,
        ___, ___, ___, ___, ___, ___,PGDN, ___, ___, ___, ___,           ___,
        ___, ___, ___,                ___,               ___, ___, ___,  ___
The project is at https://github.com/makerdiary/python-keyboard
As hand-wiring a keyboard is hard and is not for everyone, so I'm preparing a new keyboard pcb which will be powered by python.
What's your idea of a keyboard powered by python?
Re: keyboard powered by python
« Reply #1 on: Mon, 22 June 2020, 04:49:29 »
Being able to change the keymap anywhere there's a text editor sounds great :thumb:
« Reply #2 on: Mon, 22 June 2020, 05:09:51 »
BTW. I see that you are also the ones selling the microcontroller board in this keyboard.
It looks similar to a Feather board, but the pinout is not compatible. Why did you choose not to? I haven't seen any requirement for a license fee.
Offline Yihui
« Reply #3 on: Mon, 22 June 2020, 06:15:18 »
Feather form factor is cool. However, when designing the board, Feather was not as popular as today. Besides, Feather is a little small to place three antennas (NFC/Bluetooth/WiFi).
Offline Yihui
« Reply #4 on: Sun, 05 July 2020, 22:16:06 »
The design of the keyboard PCBA is finished.
It has modular design with nRF52840 M2 module and is hot-swappable.
Offline JCraftCables
    • Instagram
« Reply #5 on: Mon, 06 July 2020, 09:30:22 »
Cool! Who are you going to get to make the PCB?
Offline Yihui
« Reply #6 on: Mon, 06 July 2020, 19:48:06 »
As I'm in Shenzhen, finding a factory to make the PCB is quite easy.
Offline Yihui
« Reply #7 on: Tue, 14 July 2020, 10:42:21 »
Have been tested the keyboard PCBA. It works well. With Python firmware, its latency is about 8 ms at the moment. It's OK for daily use.
While, there are a lot to improve.  Still working hard to decrease the latency and to improve power efficiency.
If you are interested, you can check our github repo https://github.com/makerdiary/python-keyboard,
you can also pre-order the keyboard PCBA at https://makerdiary.com/collections/frontpage/products/m60-mechanical-keyboard-pcba now.
Offline Yihui
« Reply #8 on: Tue, 28 July 2020, 09:11:41 »
Working on reducing power consumption of the python keyboard. Right now, its current is 400 uA when Bluetooth is connected an no key is pressed.
When holding a key down, the current is 550 uA
It is not final result yet. With further optimizing, it can be better.
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #9 on: Tue, 28 July 2020, 09:36:57 »
This is really interesting, excited to see how the performance increases go:)
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline AngryCoder
« Reply #10 on: Wed, 29 July 2020, 07:36:16 »
I love that. But what are the benefits of the nRF52840 over ESP32? I will follow this project.
Offline Yihui
« Reply #11 on: Fri, 31 July 2020, 10:33:22 »
IMHO, using ESP32 on a keyboard is not a good idea, as ESP32 doesn't have USB and is power hungry。
Offline Yihui
« Reply #12 on: Sat, 22 August 2020, 08:44:34 »
With further works, the power consumption of the keyboard is lower. 0.05mA in sleep mode. 0.16mA when bluetooth is connected.
With a 1200mAh battery, the keyboard can be standby for several months.
