Author Topic: [IC] KBD67 MKII plates (POM and FR4)  (Read 18573 times)
Offline Morthekaiser
« on: Mon, 22 June 2020, 08:17:34 »
I start this IC with the intention of offering the option to buy plates of other materials for KBD67, being them FR4 and POM (just these for now). The idea is that users can have a wider range when choosing what type of plate to use, thus having a possibility of feelings in sound and tactility when typing on their keyboard. If interested, fill out this Form
As for POM, I am still researching supplier and prices, I will update them when I get it.
Layout
Version Soldered
FR4 Color Black
MOQ
FR4
Thickness: 1.5mm
Color: Black
MOQ: 0/10
Price: $25
POM
Thickness: 1.5mm
Color: Black or White
MOQ: 0/20
Price: (Estimated Price $ 30) (It will still be updated as I find a factory for processing)
Note
Leave your comment. Help me with feedback to improve this IC
There won't be a GB, this IC is to give me the basis of how many people are interested in what is offered in this post, my intention is to sell the plates in stock. That way I don't produce a quantity that is too high, so there are no stranded plates, nor do I produce a quantity so low that I cannot meet the demand.
« Last Edit: Mon, 22 June 2020, 10:30:15 by Morthekaiser »
Offline honoka
Re: [IC] KBD67 MKII plates (POM and FR4)
« Reply #1 on: Mon, 22 June 2020, 08:20:28 »
Be sure to adapt for kerf when laser cutting!
Sent from my SM-G970F using Tapatalk
« Reply #2 on: Mon, 22 June 2020, 08:23:36 »
I am taking utmost care to perform this service
Offline honoka
« Reply #3 on: Mon, 22 June 2020, 08:24:33 »
Never doubted that. I've personally made that mistake before and want to warn others
« Reply #4 on: Mon, 22 June 2020, 09:09:23 »
I made a prototype plate, I'm just waiting to get to the test, I mean FR4. Then I start selling
« Last Edit: Mon, 22 June 2020, 09:13:55 by Morthekaiser »
Offline rbgzz
« Reply #5 on: Wed, 24 June 2020, 03:02:25 »
by soldered version, does that mean the hotswap version has a different plate layout, which you are not catering to? or is the soldered plate the same as the hotswap plate?
Offline PantoneC
« Reply #6 on: Wed, 24 June 2020, 03:22:58 »
With how we in a pandemic it be easier just to have a local laser cutter make and ship to you vs gb find cost might be cheaper and faster since all shipping broken.  ;D
Offline CrlaoSvloadr
« Reply #7 on: Wed, 24 June 2020, 11:09:30 »
Been after this very thing! Have found no luck but this sounds promising.
Keeping tuned for updates- can't wait :)
« Reply #8 on: Wed, 24 June 2020, 13:47:06 »
the hot swap plate is different from the soldered one. The reason I don’t support hot swap plate, is that kbd changed the plate design
« Reply #9 on: Wed, 24 June 2020, 13:55:37 »
Thank you for your support. In talking about updates, I asked a friend of mine to help me finish the FR4 board, with those gold or silver-plated edges that come on a PCB. See this example: https://brianleereviews.files.wordpress.com/2018/11/ltarnxt.jpg?w=750
Offline chriszhu
  • (* ̄(エ) ̄*)''
« Reply #10 on: Wed, 24 June 2020, 14:00:36 »
Looks nice!
Offline buumb
« Reply #11 on: Sat, 27 June 2020, 15:58:09 »
im very interested in this as well. in regards to plate-pcb compatibility, am i mistaken to think a solder plate is still compatible with hotswap pcb albeit without the standoff holes?
« Reply #12 on: Mon, 29 June 2020, 12:28:47 »
Sorry for the late reply. I can't say, you could try, but I don't guarantee anything.
Offline octol
« Reply #13 on: Wed, 01 July 2020, 07:32:59 »
This is great, been looking for a FR4 plate for some time!
Offline Kick
  • Fuego
« Reply #14 on: Thu, 09 July 2020, 01:33:36 »
Is this still active?
Solder plates will work with hotswap if you do not use standoffs. this just means that youll have to take out one switch at a time to swap or take the pcb off the case and swap switches that way as the switches are the only thing holding the plate and PCB together.
Offline keenerz
« Reply #15 on: Mon, 03 August 2020, 01:40:58 »
Would love an FR4 plate for my KBD67 MKii. Hopefully this is still going on.
Offline vaf1en
« Reply #16 on: Mon, 03 August 2020, 02:42:33 »
I would also be interested - even more so if I would not have to pay out my rear for shipping (Europe).
Offline Dandy
« Reply #17 on: Tue, 04 August 2020, 01:51:31 »
If this is still a possibility I'd happily buy an fr4
Offline neutralstate
« Reply #18 on: Thu, 06 August 2020, 08:54:44 »
still quite keen for this, hopefully its not dead.
Offline CustomerSupport
  • 🕸 developer
    • Discord
« Reply #19 on: Thu, 06 August 2020, 13:42:13 »
Any available sound tests? Or other descriptions of the differences in these versus the stock brass plate?
Offline mightylink
« Reply #20 on: Sat, 08 August 2020, 02:52:04 »
I would be interested
Offline Grey_Warden
« Reply #21 on: Tue, 18 August 2020, 15:03:33 »
Idk if this is still a thing, but I'm definitely interested.
Offline Draxion
« Reply #22 on: Mon, 02 November 2020, 01:03:34 »
Is this gonna happen? I'd be down
Offline natemcrice
« Reply #23 on: Sun, 06 December 2020, 17:37:55 »
Hopefully this is still going on, will really like a fr4 plate for my kbd67mkii.
Offline Dran
« Reply #24 on: Mon, 04 January 2021, 06:52:42 »
If this is happening I would be so down for both plates.
Offline v4lkism
« Reply #25 on: Mon, 11 January 2021, 10:26:01 »
Im interested if this is still a thing
Offline hngtx
« Reply #26 on: Mon, 08 February 2021, 10:15:04 »
I'd also be in for both plates. Maybe there is a chance for a small run?
Offline Leandre
« Reply #27 on: Wed, 17 February 2021, 14:34:19 »
also very interested in both the plates
