Author Topic: HHKB Classic - Stickiness Sound on Key Release?  (Read 2912 times)
Offline Aydo
« on: Fri, 26 June 2020, 04:51:15 »
Hello, just got an HHKB Classic which is pretty much unused. I have noticed that there is an annoying 'stickiness' sound on release on pretty much every single key. Here is a video to make it clear:
  • Black board: Stock HHKB Pro 2
  • White board: Stock HHKB Classic <-- evildoer
My HHKB Pro 2 does not make such sounds. Does anybody have a similar experience or know what causes this / how to fix it? It really makes it unusable for me. :(
Offline lolafineday
Re: HHKB Classic - Stickiness Sound on Key Release?
« Reply #1 on: Fri, 26 June 2020, 06:28:33 »
I'd say its normal but best way to find out is to open it, re assemble it and see if there is anything there or something.
Sent from my SM-G975F using Tapatalk
Offline ntnacs
« Reply #2 on: Sat, 27 June 2020, 16:46:56 »
I have a HHKB Professional Classic and tried the same thing, it seems that the stickiness sound is only present if you press down on the key with a lot of pressure.
So much so that it'd be way past the amount of pressure required to actuate the switch.
I'd say that it's normal, but if it's bugging you that much you could try looking at the membrane which seems like the most likely reason for the stickiness effect.
tokyo60 -- HHKB -- GH60 -- CM QuickFire Rapid -- Magicforce 68
"If you no longer go for a gap that exists, you are no longer a racing driver."
Ayrton Senna
Offline Sup
« Reply #3 on: Sun, 28 June 2020, 14:47:56 »
This issue is fixed most of the time if you reseat the domes.
current
Coming soon
Offline foxtrap614
  • Always rem
« Reply #4 on: Tue, 30 June 2020, 11:41:13 »
I own a classic and experience the same sound. Not sure why but might be the domes or the springs. I only experience it on hard presses, could be the sound of rubber cup being released.
"I don't think -- " "Then you shouldn't talk."
-Alice In Wonderland
