Author Topic: [GB] Tind: Series I [COMPLETED]  (Read 41572 times)
Offline dommyy13
Re: [GB] Tind: Series I - 60% Mekanisk Gasket Mount [RAFFLE 03.07.2020]
« Reply #50 on: Sat, 04 July 2020, 05:38:52 »
curious how many people entered?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #51 on: Sat, 04 July 2020, 09:18:29 »
A lot of people, I won't say exact numbers. There was a low chance of winning, however Series II is coming.
Offline gotpan
Re: [GB] Tind: Series I [MANUFACTURING]
« Reply #52 on: Sat, 04 July 2020, 15:59:13 »
Congrats to those who won. Do you have an estimate on when Series II will be available?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #53 on: Sun, 05 July 2020, 08:41:10 »
 ;D ;D ;D ;D
Most winners have made their choice. For the last few, please go through with the purchase ASAP.
Unpaid orders will be re-raffled tomorrow.
Offline pixelpusher
« Reply #54 on: Sun, 05 July 2020, 10:18:28 »
Offline prognostics
« Reply #55 on: Sun, 05 July 2020, 11:08:32 »
Took my time to decide on the plate material... excited to have won.
Might only get one Think6.5 v2 this month now.  :p
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #56 on: Sun, 05 July 2020, 11:28:08 »
Starting redraws slowly today(as they come in), and will continue tomorrow. There are only 1 so far.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #57 on: Sun, 05 July 2020, 18:23:40 »
Everyone should have gotten a mail with their result. Check your spam mail.
Thanks everyone!
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #58 on: Mon, 06 July 2020, 17:50:29 »
A few redraws.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #59 on: Sat, 11 July 2020, 04:08:32 »
Invoiced the Norwegians, or sent a follow up mail.
Anyway, Tind Series I production is ordered.
Due to demand, we will push Series II up the queue and hopefully we will be able to announce the theme for Series II soon.
Here is the status update page.
Mekanisk.xyz
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #60 on: Mon, 13 July 2020, 07:15:52 »
I am doing some in-depth testing of the Tind. Since the plate is totally isolated, the plate is super important to sound.
The copper plate plate feel great and clacky, but in certain configurations it can produce a light metallic sound on hard bottom outs (almost pinging), this is especially true for unlubed switches. The same goes for brass, but in a much lesser degree. Carbon fiber does not have this issue. Most of you already chose carbon fiber as the plate material.
If you want to change plate to carbon fiber, or make any other changes, please reply to your order confirmation.
Keep in mind that all plates will be for sale so you can just buy a new plate after you have tested for yourself.
Thank you!
Offline prognostics
« Reply #61 on: Mon, 13 July 2020, 08:10:42 »
Mekanisk.xyz
Appreciate the updates. :)
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #62 on: Wed, 15 July 2020, 15:13:26 »
We had 65% choosing Ultramarine and 35% choosing Dark Gray.
I don't want to confirm entry numbers, but I can confirm we had more than a thousand entries.
Series II is in the works. Together with the 65% and TKL versions(both after Series II).
I recommend joining our Discord.
Offline fritte
« Reply #63 on: Sun, 26 July 2020, 17:40:18 »
Will Series II be a limited GB as well?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #64 on: Mon, 27 July 2020, 12:07:57 »
Yes
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #65 on: Thu, 17 September 2020, 12:22:24 »
Hi!
Time for an update.
We finalized the design, but we want to run one more prototype with some adjustments just to make sure all of you get the best 60% keyboard there is. So we are officially waiting for a new prototype.
Updates:
- gasket compression adjustment, reduced a little bit
- plate adjustment for both ANSI and ISO
- screws will be M3 Torx socket-head in the same length for bottom mounting (M3x8mm)
- screws for weight mounting will be a combination of M3 Torx countersunk and socket-head.
- tools for Torx will of course be included in the package, as we do understand not everyone use Torx
- slight USB updates
Will let you know of any future updates, but I recommend joining the Discord.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #66 on: Tue, 10 November 2020, 15:59:42 »
Everything is machining nicely.
All the weights are done.
Offline honoka
« Reply #67 on: Tue, 10 November 2020, 19:38:22 »
Thank you for the update
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #68 on: Wed, 02 December 2020, 20:13:49 »
Machining almost finished.
Waiting in queue for anodizing.
Offline pixelpusher
« Reply #69 on: Wed, 02 December 2020, 21:41:10 »
Great news.  Hoping that the anodizing goes smoothly since it’s your tried and true ultramarine.   :thumb:
Offline honoka
« Reply #70 on: Thu, 03 December 2020, 01:50:36 »
did you just assume my choice of color?
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #71 on: Sat, 12 December 2020, 06:16:39 »
Hey!
We are still looking at a January 2021 shipping date. Thanks for the patience.
Everything is at the anodiser now. All machining is finished.
Offline honoka
« Reply #72 on: Sat, 12 December 2020, 06:23:34 »
thanks for the update
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #73 on: Wed, 16 December 2020, 12:58:02 »
Waiting for anodizing still.
Then quality control.
Then shipment.
We are still waiting for PCBs which are estimated in January as well.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #74 on: Sun, 10 January 2021, 06:47:32 »
QC QC QC
Waiting for a few more parts to arrive, then these will start to go out.
Offline FlitzDeelman
« Reply #75 on: Sun, 10 January 2021, 07:12:05 »
Wow, these look like they will be delivered on time. Well done.
Mind you, that happened with my Klippe T too.
Offline prizeS
    • TastyKeys
« Reply #76 on: Sun, 10 January 2021, 21:18:26 »
Lookin' good! can't wait to see these roll out
i lub 65% and wkl tkl.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #77 on: Wed, 13 January 2021, 15:39:41 »
PCBs ready.
Waiting for some stuff to arrive early next week.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #78 on: Thu, 21 January 2021, 05:51:32 »
Offline honoka
« Reply #79 on: Thu, 21 January 2021, 18:35:18 »
Almost there now
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #80 on: Sat, 23 January 2021, 14:01:55 »
Shipping update:
25% of Tinds are shipped. These first shipments are split into two deliveries, so expect two packages if you got a shipping confirmation yesterday.
The remaining 75% will ship next week.
Thank you.
Offline honoka
« Reply #81 on: Sun, 24 January 2021, 03:59:01 »
Shipping update:
Thank you.
How will the declared value be split between the two shipments?
VAT and customs fees would be charged on the two separate shipments so it would be good to know.
Offline Poesjuh
Re: [GB] Tind: Series I [SHIPPING]
« Reply #82 on: Sun, 24 January 2021, 09:14:34 »
You’ll get cucked twice since you play vat on the shipping costs as well. So either way it’s extra money to pay.
Offline honoka
« Reply #83 on: Wed, 27 January 2021, 15:38:36 »
Cucked I got! But hey, we got a carry case for the keeb so im not complaining. Also the keeb smells nice so we are double OK.
Offline prognostics
« Reply #84 on: Thu, 28 January 2021, 06:05:21 »
Shipping update:
Thank you.
Just got my shipping notification. I am impressed with how you ran this from start to finish. Thank you LeandreN. I will be keeping my eyes out for anything else Mekanisk puts out.
Offline LeandreN
  • Mekanisk.co
    • Mekanisk
« Reply #85 on: Mon, 08 February 2021, 03:09:34 »
Just want to confirm everything has been shipped  :thumb:
Offline honoka
Re: [GB] Tind: Series I [COMPLETED]
« Reply #86 on: Mon, 08 February 2021, 08:30:05 »
nice! got mine. happy af
Offline pixelpusher
« Reply #87 on: Mon, 08 February 2021, 18:06:13 »
It’s hard to capture the color but it’s a slight more blue and just slightly less saturated than TU1
261823-0
Looks great with neutrals and tans
261825-1
