Author Topic: [IC] Modern F | Top Mount 60% Case  (Read 65271 times)
Offline Havattack
Re: [IC] Modern F | Top Mount 60% Case
« Reply #100 on: Sat, 04 December 2021, 02:37:18 »
Let me just chime in as somebody else who is watching this project.
I have a split-spacebar DZ60 already built with BOX Pink clicky switches that I would love to transfer straight into this case.  Need bezels to give it some physical presence!
What the guy above was trying to say,  I assume, is that while the keeb is dz60 compatible, it probably is not compatible with whatever plate you have it built with, and if you used no plate, it will still probably require the plate that comes with it, in order to work. Some conjecture on my part, but as was all ready said: just sayin'.
Offline pelinot
« Reply #101 on: Sun, 21 August 2022, 22:02:53 »
Well I guess this board is never happening
« Reply #102 on: Mon, 22 August 2022, 10:07:29 »
ellipse is making an actual modern model F so it's not like you're missing out that much
https://geekhack.org/index.php?topic=79141.msg2029543#msg2029543
https://geekhack.org/index.php?topic=114105.0
a lot of new ppl don't know about these but they're incredibly high quality faithful reproductions
