Author Topic: weird springy noise?  (Read 2504 times)
Offline fidda247
« on: Wed, 01 July 2020, 17:04:10 »
hey guys
is my keyboard supposed to make this weird springy noise? it’s my first one (rk61) https://imgur.com/a/CReVM0t
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: weird springy noise?
« Reply #1 on: Wed, 01 July 2020, 17:32:13 »
Your video has no sound so we couldn't tell you. Although i will say spring ping, case reverberation, & super rattly stabilizers are very very common issues with prebuilt MKBs that have bone dry stock switches & no sound dampening mechanisms.
Offline fidda247
« Reply #2 on: Wed, 01 July 2020, 17:38:58 »
thanks for the reply!
sorry im an idiot, here you go
is there any way i can fix iT?
Offline Rob27shred
« Reply #3 on: Wed, 01 July 2020, 17:43:25 »
Much better, that sounds like mostly case resonation to me. So I'd start off by finding some thick foam you can cut to size & filling the bottom of the case under the PCB with it. For best results make sure you make it thick enough that it gets slightly compressed between the bottom of the case & PCB.
Offline fidda247
« Reply #4 on: Wed, 01 July 2020, 18:10:50 »
thanks for the advice!
im really new to the keyboard scene, is there a specific type of foam i should be using?
Offline -bustin-
    • instagram
« Reply #5 on: Wed, 01 July 2020, 18:37:41 »
You could invest in a desk mat. A 3mm one might be chunky enough to dampen it!
Offline FreshFromTheGrave
« Reply #6 on: Thu, 02 July 2020, 06:46:00 »
I think it can be a few things and sometimes foam doesn't help or cure it completely. Like I lined my Alt with neoprene foam above and below the pcb and it did absolutely nothing :) For me I think it comes from the springs in my heavy switches. Because if I remove a switch I can get the same pinging sound from the switch squeezed between my fingers, it's just softer without the aluminium to reverberate through.
So definitely try lining the case with foam (sorbothane is best but wowee it's expensive) but it might not totally fix it, in which case lubing the springs can help dampen it. It's a tricky problem to solve sometimes though.
