Author Topic: QMK keymap flashing issues  (Read 1987 times)
Offline aceofspades
« on: Wed, 08 July 2020, 12:43:46 »
I recently purchased an Arisu kit from a user on mm. After completing assembly, I created a keymap using QMK configurator and flashed it to the board using QMK toolbox, which is where the issues started.
I had tested the PCB before soldering and after soldering and all the keys worked. However, after flashing the keymap, most of the keys do not register, and those that do are out of wack. For example, LALT registers as L, and 2,3,4 register as I,K,[,].
What I have done: I tried flashing it using Msys2 which ends with the same result. I have tried flashing different keymaps, even the creators' which still doesn't work
At this point I am completely baffled as to what the issue is. One idea I had was that this possibly isn't an Arisu which would account for why the keymap wouldn't work. However, this doesn't really make sense as from what I know there are only two alice's with arrow keys - Gothic70 and Arisu, and it definitely isn't a gothic70 so not sure how that would be possible.
Would appreciate any guidance, thanks!
