Author Topic: [Preorder]Modular Lego-like Ergo MK | Velocifire×Dumang DK6 Ergo V2 - Delivered  (Read 10994 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
Hi all,
Finally the Preorder opens at https://www.velocifiretech.com/product/dumang-dk6-ergo-v2/
Edited:
Aug. 18th 1. The listing just updated with a basedboard only, and one anykey with a USB cable that you can plug in, set to any key and put in any place you like (you can even put it under desk and press it by toes)
2. Preorder closed, available on website (price US$10 added) but delivery will be after fulling preorder orders.
Video:
You can place each key anywhere you want without changing to a new keyboard.
It has built-in mcu for every key to contact with the basdboard and communicate with PC.  In this way, no matter where you place the key, it works. No matter what you set for the key, it restores information there seperately.
Main Features:
#Unlimited layout, each key has built-in MCU to communicate with the PC via the baseboard independently.
#10 times faster than traditional keyboards
# User friendly custom software to ramap keys, set RGB backlit, macros for 4 layers.
Other Specifications:
Baseboard: Aluminum alloy
Type-C, Wired, RGB,Dumang SoftwareKeyboard
Angle: different adjustable degrees
Provided switches: Cherry/Kailh hotswap switches
Default Keycaps: ABS white/black/blue/grey
Pre-order Open: July 9, 2020 – July 23, 2020.
Estimated Delivery: First 30 keyboards will be delivered within 1 month Pre-order ends, and the rest after will be 0.5-1 months later.
Feel free to ask if you have any questions :)
« Last Edit: Mon, 17 August 2020, 21:55:38 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [Preorder]Modular Lego-like Ergo MK | Velocifire×Dumang DK6 Ergo V2
« Reply #1 on: Fri, 10 July 2020, 07:22:44 »
Approved
Offline rmendis
  • Artisan addict
« Reply #2 on: Sat, 11 July 2020, 14:19:43 »
Interesting concept. Curious to see how this progresses
Offline Tyson
« Reply #3 on: Sat, 11 July 2020, 14:51:06 »
This board is awesome! I picked one up when I was in Japan in March. I did a mini review of it on my stream a few weeks ago. If anyone is looking into getting one, I recommend it, this price seems reasonable, it's about the same price I paid when I bought it. It's a very interesting idea!
Offline john08099
  • Velocifire MK
« Reply #4 on: Sun, 12 July 2020, 22:14:29 »
Thank you. The Dumang Modular keyboards have been on Chinese and Japan market for about 2 years, works very stable now, this is not a concept only :))
Offline KingOfMemes
« Reply #5 on: Sun, 12 July 2020, 22:17:11 »
I'm assuming this isn't using open source software. What software is going to be used to program these switches, and can I get a link to confirm it works on my system?
Offline jamster
« Reply #6 on: Sun, 12 July 2020, 22:37:06 »
http://www.beyondq.com/download.html
I've spun it up in a Win10 VM, it runs, but the first thing it does is look for a keyboard. If there isn't one attached, there isn't much else you can do.
Offline john08099
  • Velocifire MK
« Reply #7 on: Sun, 12 July 2020, 22:55:11 »
You can also see some screenshots of the software at https://www.velocifiretech.com/wp-content/uploads/2020/07/Velocifire-DM-software-scaled.jpg
Offline john08099
  • Velocifire MK
« Reply #8 on: Mon, 13 July 2020, 20:32:08 »
Hey, feel free to share this with us too!
Offline john08099
  • Velocifire MK
« Reply #9 on: Tue, 14 July 2020, 05:16:13 »
Here is a review of it too.
Offline john08099
  • Velocifire MK
« Reply #10 on: Wed, 15 July 2020, 20:51:29 »
Did you also get the ergo?
Offline john08099
  • Velocifire MK
« Reply #11 on: Mon, 20 July 2020, 21:00:54 »
Last 2 days of the preorder!
Offline jamster
« Reply #12 on: Tue, 21 July 2020, 00:01:25 »
I'm using the 'full size' version, which is probably similar to TKL. I want to stick with dedicated keys for things nav buttons.
I would say that build quality is really good, much more solid IRL than is suggested by the photos. The impression I get from handling them is that they are built like high quality Apple tablets, only much denser.
No idea what the customisation software is like though, as I haven't found the need to use it.
Offline john08099
  • Velocifire MK
« Reply #13 on: Mon, 27 July 2020, 05:10:37 »
Thank you for the feedback. The software is really cool,  you can try to use it too!
Offline john08099
  • Velocifire MK
« Reply #14 on: Mon, 17 August 2020, 21:42:34 »
Already delivered, we will see more feedback very soon :)
