Author Topic: [help] KBDFANS19X not registering in switchhitter  (Read 1625 times)
Offline gisigwilgwelk
« on: Fri, 10 July 2020, 21:24:45 »
Just finished soldering the board and cannot get any keys registering. I tested it before I started and the PCB was working fine. Odd thing is i can access the second layer and change the underglow, which is working so it is getting power just fine. Any help would be appreciated!
Offline pixelpusher
Re: [help] KBDFANS19X not registering in switchhitter
« Reply #1 on: Fri, 10 July 2020, 23:38:50 »
Maybe you pressed a combo and put it in a higher layer than the base? Is is stuck in the 3rd layer or something?  Did you try a different cable and/or port on the computer?  Reflash from https://config.qmk.fm/#/kbdfans/kbd19x/LAYOUT_ansi
