Author Topic: IBM model M - some keys stopped working  (Read 5878 times)
Offline adi.hodos
« on: Mon, 12 July 2010, 20:26:08 »
Hello everyone, I would like some advice. I have acquired an old IBM model M (1391406) - manufactured in the UK, in the year 1990. It worked perfectly until 3 days ago, when some keys refused to send any scan codes to the OS (k, 0, p), although they still make that clicky sound. So I have dismantled the keyboard and cleaned it up. There were traces of some sticky fluid spilled in it a long time ago (probably coffee) and some of the springs were a little bit rusty (the upper end). After cleaning it, I assembled it back, and it worked flawlessly for another 2 days. But now the same keys don't work anymore. Is there anything that can be done ? Could the connecting cable be faulty ? Or the springs ?
I will try to upload some photos that I took in the cleaning process.
Offline wellington1869
« Reply #1 on: Mon, 12 July 2010, 22:53:49 »
If you're handy with a volt meter you could check the connections on the motherboard. On the other hand, a replacement will cost only about 20 to 30 bucks on ebay.
using: ms 7000/Das 3
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #2 on: Mon, 12 July 2010, 23:27:11 »
Quote from: wellington1869;202137
Or, you know, here on geekhack...
kishy.ca
Offline adi.hodos
« Reply #3 on: Tue, 13 July 2010, 14:17:53 »
Well I don't think that the cable or the motherboard connectors are at fault here, since only some keys do not work (k, -, 0, p). And it's random, now it's working, I'm typing at it and all the keys are ok. This is very strange... Could it be the fact that the springs have a little rust at their upper end ? If so, is it possible to replace the springs ?
Offline timw4mail
    • https://timshomepage.net
« Reply #4 on: Tue, 13 July 2010, 14:23:23 »
Quote from: adi.hodos;202296
That's unlikely to matter, because the mechanism is not capacitive.
I believe Unicomp refurbishes Model Ms at a decent price.
Buckling Springs IBM Model F AT, New Model F 77, Unicomp New Model M
Clicky iOne Scorpius M10, OCN-branded Ducky DK-9008-C, Blackmore Nocturna, Redragon Kumara K552-1, Qtronix Scorpius Keypad, Chicony KB-5181(Monterey)
Tactile Apple AEKII (Cream damped ALPS), Filco FKBN91M/JB (Japanese Tenkeyless), Cherry G84-5200, Cherry G84-4100LPAUS, Datalux Spacesaver(Cherry ML), Redragon Devarajas K556 RGB, Newmen GM711, Poker II (Cherry MX Clear), Logitech G910 Orion Spark, Logitech K840
Linear Lenovo Y (Gateron Red), Aluminum kiosk keyboard (Cherry MX Black)
Offline kishy
  • Eye Bee M
    • http://kishy.ca/
« Reply #5 on: Tue, 13 July 2010, 14:25:27 »
A question: how long does it take these problems to surface?
Do you keep your computer on all day, every day without shutting down at night?
My suspicion, if this takes a while to happen and the computer is on for ages at a time, would be that there may be a power issue of some kind which only surfaces after having the keyboard (known to be a power hungry one) powered up for a long time.
kishy.ca
Offline ch_123
« Reply #6 on: Tue, 13 July 2010, 15:05:37 »
Quote from: timw4mail;202299
Wouldn't matter either way... in the capacitive mechanism, the hammer is made out of conductive plastic, so it's not going to rust.
« Last Edit: Tue, 13 July 2010, 15:31:52 by ch_123 »
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #7 on: Tue, 13 July 2010, 17:24:50 »
Quote from: kishy;202301
I've got a computer with an M5-2 and it's been on for a few months. No problems.
Power issues with keyboards tend to happen when you start the computer.
Offline adi.hodos
« Reply #8 on: Wed, 14 July 2010, 09:42:34 »
Sometimes it works for a period after booting the computer. Other times it simply refuses to send those keystrokes from booting until shutdown.
Offline timw4mail
« Reply #9 on: Wed, 14 July 2010, 09:46:53 »
Quote from: adi.hodos;202576
I assume you have it hooked up via PS/2? If so, you should try and see if a USB adapter will work.
Offline adi.hodos
« Reply #10 on: Wed, 14 July 2010, 09:51:08 »
Yes, it's hooked via PS2. My motherboard is a MSI P35-Neo2. I'll try to find a PS2 to USB adapter.
