Author Topic: All of the "Gaming" focused keyboard don't seem to fit any keycap set.  (Read 1814 times)
Offline cheesegeese
So I wanna use the ducky PBT pudding keycaps:https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=5790 that use a standard keyboard layout but when I look at actual keyboards, none use this supposedly "standard" layout. The only keyboards that actually fit the layout were ducky keyboards. If you can help me find some RGB hot-swap keyboards that actually use this layout that would be great. Some examples of keyboards that have RGB and hot-swap but don't use this layout: Glorious GMMK, Royal Kludge SK61, Massdrop CTRL
Offline downtownHippie
Could you be a lot more specific.  What about that keycap set doesn't fit other keyboards?
It does follow that ducky's keycaps would be a set that fit their keyboard layouts specifically though.
Offline Pyk_
I think it fits those keyboards, what’s the problem?
Offline WholesomeDucky
  • lemme get uhhhhhhhhhhhhh bread
All 3 of the keyboards you named DO use the layout of the caps you linked. It very much is the standard.
That said, if you like RGB, that's cool, but the idea of a "gaming focused" keyboard is a meme. You can game, quite well, on basically any board. An argument could be made that linear switches are often better for competetive games, but even that is subjective to be honest.
« Last Edit: Thu, 16 July 2020, 07:29:22 by WholesomeDucky »
12 years of spending money on typing
"Name checks out" -Kustoms, 2020
Discord:wholesomeducky
Inbox always open, for whatever reason.
Offline yui
a few very old boards may have issues with wasd but other than that you rarely need anything that is on a gamer board for games, yeah you can use macros to cheat with some boards but that's pretty much where it ends.
