Author Topic: das cable  (Read 2786 times)
Offline sam113101
das cable
« on: Tue, 13 July 2010, 00:39:03 »
I find that my das keyboard model s has a big cable. I wanted a wireless keyboard, which I can't find in the mechanical keyboard world (I heard of a wireless filco keyboard, this would be a very nice thing, but I think they don't make it anymore).
I can't find a wireless mechanical keyboard, so I wanted something with a subtle cable. Seems like das' one is bigger, I think it's because of the usb hub, might be that. I plan to buy a filco board, does anyone has both das model s and filco, and can tell me if the filco's cable is smaller*?
Thanks.
Also, are the browns very different from the blues*?
Will I tell myself, «*well, these are like blues but without the click sound*»*?
Hoping to hear from you again, your dearest friend, sam113101.
Offline wellington1869
das cable
« Reply #1 on: Tue, 13 July 2010, 00:52:45 »
no, browns are lighter.
i too wish the das cable were smaller/shorter
using: ms 7000/Das 3
Offline sam113101
das cable
« Reply #2 on: Tue, 13 July 2010, 01:06:32 »
well, by smaller I mean thinner, don't you mean that too*?
I don't really care of the length since it's hidden behind my desk, it's okay, just fine
das' cable is thicker than any other keyboard, that's what I really meant
das cable
« Reply #3 on: Tue, 13 July 2010, 09:26:44 »
if you figure out how to make it wireless be sure to post your mod here!
Offline Mental Hobbit
das cable
« Reply #4 on: Tue, 13 July 2010, 09:37:07 »
Quote from: sam113101;202166
Blues have about the sharpest tactile response of any keyswitch, while the response of browns is hardly noticeable. They feel totally different.
Typing on blues.
