Author Topic: toxicity/dangers of lube for keyboards, specifically krytox VPF 1506  (Read 3256 times)
Offline winteralfs
Are these lubes considered safe to handle for the novice? What level of toxicity do they have? Do you have to use mask/gloves, eye protection and have you gotten any on your skin? I am going to use Krytox VPF 1506 on a Topre board.
Offline jamster
Re: toxicity/dangers of lube for keyboards, specifically krytox VPF 1506
« Reply #1 on: Mon, 20 July 2020, 02:16:59 »
If you just Google the product, you can find the SDS:
https://miller-stephenson.com/product/krytox-vpf-1506/
If this is a PTFE grease rated for use in food prep areas, I wouldn't be terribly worried about it (I used some PTFE grease on my stabs yesterday)
« Last Edit: Mon, 20 July 2020, 02:20:21 by jamster »
Offline winteralfs
« Reply #2 on: Mon, 20 July 2020, 09:18:23 »
great info, thanks. Which product do you use to lube your boards ? Which kitchen safe ones?
Offline jamster
« Reply #3 on: Mon, 20 July 2020, 11:12:14 »
The food prep comment was right out of a Google search for the lube you specified.
Just google the products and look for SDS or MSDS as a search term. For stuff to do with chemicals, it's much better than trusting some stranger on the internet  ;)
The stuff that I'm using is from a company thats no longer operating, but it is just another PTFE based product.
