Author Topic: [IC] GMK Red Alert - March 5 to April 9, 2021 on Mechs & Co 🔴🟤  (Read 114983 times)
Offline switchnollie
  • sleever supreme
  • greyhat co-leader
Re: [IC] GMK Red Alert - the classic returns 🔴🟤
« Reply #50 on: Fri, 24 July 2020, 13:16:44 »
I couldn’t leave this up for more than two days without adding the OG Number Kit, so: there is now an OG Number Kit.
Love the inclusion of this kit, but would it be possible to expand it to include backspace, insert, home, pg up, and |\ as well for that full row on TKL/60?
Yeah I'd like to see the stripe go further for TKL like what they you can do with Toxic.
Offline catamscott
« Reply #51 on: Fri, 24 July 2020, 13:59:45 »
bought dcs red alert but will still buy this too, looks great. i'd definitely extend the red kit to include backspace/tkl/numpad keys as well though, just looks better (that full stripe is too hot)
Offline SupportGG__
« Reply #52 on: Fri, 24 July 2020, 14:35:19 »
+1 bump for interest
Sent from my Pixel 3 using Tapatalk
Offline break
« Reply #53 on: Fri, 24 July 2020, 16:39:12 »
Gonna need that red number row.
It took me a few hours to decide on this. OG Number Kit added and updated to extend through the standard R1 keys covering up to 1800. Won’t cover alternative layouts (split backspace, Delete/End in R1 etc), sorry folks.
As for an aluminum artisan: I plan to offer one but it will not be white-on-red like the RAMA options for GMK Classic Red. If you like that design, check out that GB before August 1st!
« Last Edit: Fri, 24 July 2020, 22:05:05 by break »
Offline Auxo
  • Formerly CJD_Anthony
Re: [IC] GMK Red Alert - the classic returns [emoji837]🟤
« Reply #54 on: Fri, 24 July 2020, 22:36:17 »
NE chance of return of Joker keycap  :-[
I second this!!
I found but lost this pic. Ugh. Which of the 16 different Red Alert ran with this keycap?
Here is a photo of it on my board from the OG GMK run..
https://imgur.com/g1zUisx
Well I’m definitely offering that somehow!
**** yes, we're in business boiz
Offline Daggerfall
« Reply #55 on: Tue, 28 July 2020, 14:08:31 »
Can't afford it, but big props for considering NorDe. So appreciated.
Sent from my ONEPLUS A5000 using Tapatalk
Offline westway
« Reply #56 on: Tue, 28 July 2020, 15:52:54 »
I'm a simple man: I see R5, I buy.
Offline break
« Reply #57 on: Tue, 28 July 2020, 17:28:13 »
Same here. R5 is the best.
Puttin numbers on ya board
No promises here but I'll at least consider it!
I'm taking this week off to relax - between this and GMK Birch I'm exhausted. Next steps: novelty kit design and getting renders sorted.
Offline Little4Real
« Reply #58 on: Tue, 28 July 2020, 17:58:47 »
Any way you could possibly add either icon mods, or even white icon mods with red (P3 hopefully) legends like the original DCS Red Alert set?
Offline IOVERCALLHISTIOCYTES
« Reply #59 on: Tue, 28 July 2020, 18:44:33 »
Hard to get alt alphas kits run now at 70-80$, alt mods kits go to 100 or more and haven't sold well ever. I wanted classic red alt alphas to be another base (red alphas, w white mods) because of exactly what you'd said.
Warrenified and vendors seem to have picked the right thing tho: there wasnt the volume that classic blue w 2 base kits had, and while alt alphas will be made, they may need extras for the last push.
Offline westway
« Reply #60 on: Wed, 29 July 2020, 07:20:02 »
I second this. With icon mods it would look even better IMHO :thumb:
Offline wholypantalones
  • text and icon mods plz.
« Reply #61 on: Wed, 29 July 2020, 08:31:14 »
pls no icon mods.
Offline break
« Reply #62 on: Wed, 29 July 2020, 08:54:13 »
This set primarily revives the GMK version of Red Alert, which always runs with text+icon mods.
There also will not be an alt mod or base kit. I’m not looking to run a complex GB, and DCS Red Alert just completed back in April.
Offline westway
« Reply #63 on: Wed, 29 July 2020, 09:21:47 »
I imagined it before writing the message, but I tried. I'll buy it anyway :thumb:
Offline break
« Reply #64 on: Wed, 29 July 2020, 09:22:53 »
Thanks for understanding, and thanks for your support!
Offline break
« Reply #65 on: Mon, 03 August 2020, 11:47:04 »
Vendors for US, SEA, EU, AU and CA are confirmed. I am currently working as if the GB will happen as 2020 ends, although (as always) that can change!
Base kit has been updated to include UK-ISO number row. I think I'm keeping the R3 |\ and R4 >< as-is, sorry UK folks.
OG Number Kit has been updated to support split backspace. It will not support UK-ISO, sorry.
Some folks asked about the second B. It's in base because I don't plan to offer a split/40s module (I don't think demand for this keyset is there). You can use the B + Hiney's OG Spacekeys Round 2 in L9 + U9 to support Alice-style layouts.
I'm working on an Extras Kit which will include a few novelties. I hope you all enjoy them. :) I am also working on aluminum artisans. I hope you enjoy those too!
I know yall know what this keyset looks like, but I'm in queue for kit and board renders now. Once those are done it's GMK quotin' time.
Questions For You All
  • Would you like a R0 top row?
  • Would you like to see any other kitting changes?
« Last Edit: Mon, 03 August 2020, 11:51:29 by break »
Offline gnhuy91
« Reply #66 on: Mon, 03 August 2020, 12:43:04 »
I'd love R0 top row, works so well with boards that dont have spaces between r1 and f-row, like Volt, Godspeed75 etc.
Offline huey
« Reply #67 on: Mon, 03 August 2020, 13:57:15 »
This IC is looking good chief. Thank you for adding UK-ISO support, it's genuinely appreciated.
Small niggle though. Having R3 |\ and R4 < > makes UK-ISO incomplete; To fully support UK-ISO R3 would need to become #~ and R4 would be \|. I'm confused as to why you'd add UK specific numrow keys but not have the correct legending across the rest of the set.
Best of luck!
« Last Edit: Mon, 03 August 2020, 13:59:25 by huey »
Offline break
« Reply #68 on: Mon, 03 August 2020, 15:55:20 »
Best of luck!
Oops, I forgot a few things. I also forgot the R3 @'. Fixed.
Offline huey
« Reply #69 on: Mon, 03 August 2020, 17:05:33 »
Best of luck!
muchas gracias amigo
« Reply #70 on: Mon, 03 August 2020, 17:13:13 »
I'd like R0 top row, but it's not a dealbreaker
Offline heavyheaded
« Reply #71 on: Mon, 03 August 2020, 22:12:43 »
The number row kit really needs a 1U pipe-backslash to support HHKB/tsangan.
Offline Ensaum
« Reply #72 on: Tue, 04 August 2020, 00:00:38 »
It has one though.
« Last Edit: Tue, 04 August 2020, 00:03:01 by Ensaum »
Offline break
« Reply #73 on: Tue, 04 August 2020, 00:17:54 »
It has one though.
Thanks. Yeah, I specifically added it in because I strongly prefer split backspace.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #74 on: Tue, 04 August 2020, 04:23:20 »
I am against R0 personally. If it is included, I'd prefer it be defaulted to R1 in base and R0 as a separate kit.
Offline break
« Reply #75 on: Tue, 04 August 2020, 06:23:24 »
Thanks Lightning. I think I’m going to skip it here. It complicates the board’s layout, and I’m not willing to bother fixing that.
So: no R0.
Offline heavyheaded
« Reply #76 on: Tue, 04 August 2020, 11:30:36 »
It has one though.
LOL, yeah I'm a dummy. You already took care of me!
« Reply #77 on: Tue, 04 August 2020, 12:02:35 »
Same, keep it in a separate kit please.
Offline break
« Reply #78 on: Tue, 04 August 2020, 13:03:14 »
No worries here - there will be no R0 for this set.
Offline gok_nz
  • Enjoy your PBT
    • Website
« Reply #79 on: Tue, 04 August 2020, 14:20:41 »
I changed the colour of my zenith from moss to halt because of this.
Can't wait.
Offline break
« Reply #80 on: Wed, 05 August 2020, 09:34:08 »
Can't wait.
Oof, when gok is interested in a keyset you're running...  :cool:
That said, this is not my keyset. I hope to design something you all would love. On that note, I'll be transparent about my design process so far.
Here's a first look at the novelties I've worked up. I'm working with Cherry to obtain licensing for their classic trademarks now, and you can also see some callbacks to classic set runs.
pwade asked if I would re-use existing Cherry molds. I don't know! I planned on using the same molds as GMK Denim, and only intended to use these as render representations...but then I started having fun tweaking these. Let me know what you think.
Would you like to see anything else here? Some historically inspired ideas: programming keywords (FORTRAN, C; goto, void, do), classic Cherry design elements, possibly some homages to OTD (the first runners of Red Alert), R4 text mods ("Red," "Alert").
I won’t be designing C&C: Red Alert novelties, because I don’t want to secure licensing and the set is not inspired by the game at all.
« Last Edit: Wed, 05 August 2020, 10:22:03 by break »
Offline hineybush
  • student of error
    • hineybush keyboards
« Reply #81 on: Wed, 05 August 2020, 12:53:35 »
2-cherry logo best cherry logo
Offline break
« Reply #82 on: Wed, 05 August 2020, 12:57:52 »
No vintage logo love eh?
Offline Auxo
« Reply #83 on: Wed, 05 August 2020, 19:01:19 »
Might agree on this one, looks a bit cleaner with one less cherry :thonk:
« Reply #84 on: Wed, 05 August 2020, 20:22:01 »
I am convinced by Hiney
Will buy 3 cherry caps anyways tho
Offline break
« Reply #85 on: Wed, 05 August 2020, 21:01:19 »
Dammit Hiney stick to bringing your heat in your own ICs.  :D
« Reply #86 on: Wed, 05 August 2020, 23:07:14 »
r0 would be a dealbreaker for me
also i don't think novelties really matter for this set since i think most just want the base kit
classic colorways like this don't really need frills to sell imo
Offline break
« Reply #87 on: Thu, 06 August 2020, 15:41:49 »
I think you're right Puddsy, and in that spirit I've pared back my novelty ideas. This will instead become an Extension Kit, looking something like this
You'll see some keys here (1u and 1.75u Enter) pulled from the base kit. I'm slimming the 40s support in base down and tossing it in here. There should be enough in here to support Adelie, TMO, etc.
Would love thoughts, as always.
Offline hineybush
  • student of error
« Reply #88 on: Thu, 06 August 2020, 17:47:10 »
7u spacebar in extension kit is a no go
Offline break
« Reply #89 on: Thu, 06 August 2020, 18:57:27 »
I really should label these, but those are supposed to be two 6u bars - one centered and one off-centered. I wouldn’t stick the Tsangan bar in the Extension Kit.
I’ll double check and fix it if there’s a 7u.
Offline hineybush
  • student of error
« Reply #90 on: Thu, 06 August 2020, 18:58:19 »
ahhh okay. that's fine then. i just looked at the pic real quickly.
« Reply #91 on: Thu, 06 August 2020, 20:19:28 »
combining extras and spacebars is quite clever since i think a lot of people will specifically want both for this set, i think this is a good kit
my main issue was problems with licensing the cherry logo since that seems like a giant timesink, so i think just red enters would be smarter, or something to that effect
but otherwise thumbs up from me
Offline break
« Reply #92 on: Thu, 06 August 2020, 20:33:41 »
I think this is the right move too, thanks. I’m working on the Cherry licensing now. :)
Offline forevermadrigal
« Reply #93 on: Thu, 06 August 2020, 21:05:06 »
Cherry rama cap like dolch r5 has would be sick
Offline break
« Reply #94 on: Thu, 06 August 2020, 22:36:53 »
Hell yeah, that would be incredible.
I am about 85% sure that (1) the new logo looks much better and (2) the new logo looks much worse on the Enter key with the old-style Cherry text logo. So I'm considering spiking those Enter keys. Let me sleep on it.
Offline hineybush
  • student of error
« Reply #95 on: Thu, 06 August 2020, 22:45:22 »
oh yes. rama cap ples.
Offline LightningXI
  • PPD
    • ArtisanMacro
« Reply #96 on: Thu, 06 August 2020, 23:09:08 »
I like the vintage logo better when juxtaposed with the CHERRY text. Just like on GMK KA 1953.
I think for this one, though I agree that the modern one looks cleaner on 1u caps, I'd lean towards vintage for the sake of the theme of the set.
Offline JFKroflcopter
« Reply #97 on: Thu, 06 August 2020, 23:28:27 »
This just keeps getting better and better. At this rate I'll have to buy each kit - can't wait for this  :thumb:
Offline JustinMalcontento
« Reply #98 on: Thu, 06 August 2020, 23:57:38 »
Add alt mods to match alphas?
Offline break
« Reply #99 on: Fri, 07 August 2020, 00:04:59 »
Food for thought!
No alt mods or anything like that here - I'm planning on straightforward kitting. Base, OG Number, and Extension - that's it. I totally understand if that's a dealbreaker, I've been there too.
If you'd like pure red-on-white, Seoulcialite ran this exact combo as DCS Red Alert earlier this year. It's DCS, not GMK, but the set looks amazing. You can find pics floating around, and Dixie will have tons of extras soon.
