Author Topic: GK64X number "6" key being highlighted  (Read 1537 times)
Offline xepova
« on: Thu, 23 July 2020, 10:53:39 »
Hi,
I got GK64X with kailh silent pink swithes and I'm very happy with it so far. One thing that bothers me is that when I press FN, the "6" key is always highlighted. It also highlights the key that represents current layer, which makes sense.
Anyone knows why 6 is being highlighted? Anyway to disable it?
Thanks
Offline pewpewnii
Re: GK64X number "6" key being highlighted
« Reply #1 on: Mon, 10 August 2020, 01:10:27 »
Same, I got it for like 2 months and I still not really get use to it on the GK software. What can I tell is I am not a high micro or macro keyboard user, i just use it for normal typing and gaming. I think the 6 have its own function that's why while you pressing FN key , the "6" will light up.
