Author Topic: Box Whites vs Box Glazed Green  (Read 5517 times)
Offline wyz3
« on: Sat, 25 July 2020, 04:54:07 »
The title is clear. Is there any real difference? I know there is a slight pitch difference but asides from that is there anything that stands out between the two? Is the bottom out heavier on the whites? If you have used either of the switches your input would be very much appreacited. Thank you
« Last Edit: Sat, 25 July 2020, 05:03:14 by wyz3 »
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
Re: Box Whites vs Box Glazed Green
« Reply #1 on: Sat, 25 July 2020, 08:33:17 »
Are you really, really, really sure you don’t want to just get a switch tester at this point?
Five of eight of your topics posted since you joined are Swtich A vs Switch B, and a switch tester would solve all your issues. Even if you don’t have the budget to get one AND get switches, you can always buy it, use it to make your decision, then sell it on.
"Romeo"     "Split75"   "Melody96"     "KBD8X MKII"     "Womier K87"
Offline wyz3
« Reply #2 on: Sat, 25 July 2020, 09:23:19 »
If i can find the switches i want on it for a decent price then maybe
Offline Sup
« Reply #3 on: Sat, 25 July 2020, 09:30:04 »
Only way to know what you like is to try it out.... And a switch tester doesn't really give you a idea how the switch really is on a full board.
current
Coming soon
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #4 on: Sat, 25 July 2020, 10:14:57 »
Sure, sure - but this particularly user has posted five threads asking Switch A vs Switch B questions, at this point a switch tester should help narrow it down more than we can.
Well a switch tester comes with switches, that’s kind of the point, hehe.
Offline jamster
« Reply #5 on: Sat, 25 July 2020, 10:52:29 »
This is textbook paralysis by analysis. You've got a list of over 20 switches. From weights of reds to blacks, linear, clickies, maybe a tactile or two. It's totally all over the place.
Just choose the ones that look good on paper, order a ten pack of each, and go to town on your hotswap keyboard. I mean, that's the whole point of buying a hotswap keyboard anyway. It's so you can try switches that you actually buy and own.
If money is tight, buy less variety. You'll be typing for years, you don't need the perfect answer first shot, your tastes are likely to change over time, new and exciting switches will come out a year or two or five from now.
With some experience you can then triangulate on others' impressions meaningfully. If you have enough experience, you'll be able to use force/distance graphs. But you need to just get out and try stuff, with your own fingers.
I've read similar many times, but I've been able to use testers or a couple of samples to get a good idea of whether I'd like a switch or not. I can quickly reject switches (Aliaz with its wobbly start before the bump, overly tactile box royals, most Hakos). It might be a bit harder to identify what I like, but as a screening tool, it's been useful so far.
« Last Edit: Sat, 25 July 2020, 11:04:52 by jamster »
Offline Avi_
« Reply #6 on: Sat, 25 July 2020, 12:11:55 »
I'm using Whites in one of my keyboards. I ordered a few Glazed Greens, just to try them out, and couldn't tell the difference.
Offline wyz3
« Reply #7 on: Fri, 31 July 2020, 07:05:55 »
Thanks Avi. I guess they legit made the same switch but at least I heard that the Glazed Greens doesn't have that keycap problem anymore or at least not as much as the whites. I guess I will get the Glazed Greens just so they don't break my keycaps.
Offline -Jerry-
  • OR '1'='1'
    • Jerry Talks Tech
« Reply #8 on: Fri, 31 July 2020, 07:14:38 »
As far as I'm aware, any issues with Box switches damaging keycaps have been resolved.
Offline Sintpinty
  • Carbon Based Life Form
    • My Roblox Profile
« Reply #9 on: Sun, 02 August 2020, 08:02:55 »
Wait are these switches new? I've never heard of them.
Just my thoughts
Offline dusan
« Reply #10 on: Mon, 03 August 2020, 06:06:30 »
From specs, they both have the same actuation force but different bottom out forces. Glazed Green is lighter. But the difference is just 10gf which is IMO very small. So, let me guess. The design intention was to reduce fatigue while not to induce any noticeable difference. Glazed Green is probably suitable for those whose job is typing all day continuously.
Topre Type Heaven | Filco Majestouch w/MX blue | CM Storm QF w/MX green | Asus Echelon w/MX black | Razer Tournament 2014 w/Razer green, Keychron K1 w/Gateron LP red | TypeMatrix 2030 | custom 6x16 ortho w/MX black | Atreus 44 w/Kailh box white & Gateron Pro yellow.
Offline treeleaf64
    • treeleaf64
« Reply #11 on: Mon, 03 August 2020, 12:23:25 »
They are special Chinese color edition of Box switch.
Same tactility as Box white.
Read more here:
https://www.theremingoat.com/blog/from-the-vault-kailh-china-style-box-switch-review
treeleaf ~~~~
Everyone must pay the cat tax
