Author Topic: Right alt KBD75V1  (Read 1712 times)
Offline Xagell
Right alt KBD75V1
« on: Sat, 25 July 2020, 15:04:53 »
Hello all! ,
I have the KBD75V1 , but I am having issues with my right alt. The right alt is behaving as alt-gr (right alt+ left ctrl) , looking at http://qmkeyboard.cn/ I can't find an option to overwrite the function of this specific key I can only overwrite the right alt button which somehow is not available.
Can someone help me to assign right alt on my right alt?
regards!
Offline Xagell
Re: Right alt KBD75V1
« Reply #1 on: Sat, 25 July 2020, 15:28:29 »
Just got the solution apparently Windows was doing some funny business, putting the keyboard to us instead int fixed the issue.
« Reply #2 on: Sat, 25 July 2020, 15:35:11 »
Right Alt is the same keycode as Alt Gr so according to QMK (and any other firmare) they are the same.  I've just had a look on the linked site and RALT is default on the KBD75, just like all the other boards...
Is it possible Windows (or whatever you use) has defaulted this keyboard to your native language when you usually set it to American?
