Author Topic: simple Keyboard debugging question  (Read 1858 times)
Offline jrsmile
« on: Sun, 26 July 2020, 06:57:58 »
Hi There,
i just registered to ask a question,
i have a problem with my first Handwired Keyboard.
whenever i push a key it also sends the key in the row above, i have watched several images of keyboards and i am nearly sure it is not the diode direction i got wrong, i probed every cable for shortcircuits but could not find any,could someone have a look and point me in the right direction?
the code is for a teensy 4.1 derived from one here on the forum, it coundn't be much simpler.
but still whenenver i press "q" or "a"  i get "qa" if i hold "q" or "a" i get "qaaaaaa"
i just want nkro to work :-(
Code: [Select]
 * Programming by Stefan Jakobsson, 2019
 * Released to public domain
#define ROW_COUNT 2        //Number of rows in the keyboard matrix
#define COL_COUNT 4       //Number of columns in the keyboard matrix
#define DEBOUNCE 10         //Adjust as needed: increase if bouncing problem, decrease if not all keypresses register; not less than 2
#define SCAN_DELAY 5        //Delay between scan cycles in ms
#define KEY_UNDEFINED -1    //For keyboard matrix positions not in use
int rowPins[] = {2, 3};   //Teensy pins attached to matrix rows
int colPins[] = {7, 6, 5, 4};  //Teensy pins attached to matrix columns
//Key codes for layer 0 (standard layer)
int layer_0[] = {KEY_Q, KEY_W, KEY_E, KEY_R,
                 KEY_A, KEY_S, KEY_D, KEY_F};
int currentRow = 0;
int keyStatus[ROW_COUNT*COL_COUNT];
void setup() {
  //Row pins
  pinMode(rowPins[0], OUTPUT);
  digitalWrite(rowPins[0], LOW);
  int i;
  for (i=1;i<ROW_COUNT;i++){
    pinMode(rowPins[i], INPUT);
  //Column pins
  for (i=0;i<COL_COUNT;i++){
    pinMode(colPins[i], INPUT_PULLUP);
  //Clear keyStatus
  for (i=0;i<ROW_COUNT*COL_COUNT;i++){
    keyStatus[i]=0;
void loop() {
  scanKeys();
  delay(SCAN_DELAY);
 * Scan keyboard matrix, results stored in keyStatus array
 * Key status values:
 * DEBOUNCE*2                   = key press event
 * DEBOUNCE+1 to DEBOUNCE*2-1   = key down
 * DEBOUNCE                     = key release event
 * 0 to DEBOUNCE-1              = key up
void scanKeys(){
  int i;
    int pin = getKeyPin(i);
    if (keyStatus[i]==0 && digitalRead(pin)==LOW){
      //Key press event
      keyStatus[i] = DEBOUNCE*2;
      keyPress(i);
    else if (keyStatus[i]>DEBOUNCE+1){
      keyStatus[i]--;
    else if (keyStatus[i]==DEBOUNCE+1 && digitalRead(pin)==HIGH){
      //Key release event
      keyStatus[i]--;
      keyRelease(i);
    else if (keyStatus[i]>0 && keyStatus[i]<=DEBOUNCE){
      keyStatus[i]--;
 * Returns input pin to be read by keyScan method
 * Param key is the keyboard matrix scan code (row * COL_COUNT + col)
int getKeyPin(int key){
  int p = key/COL_COUNT;
  if (p != currentRow){
    pinMode(rowPins[currentRow], INPUT);
    pinMode(rowPins[p], OUTPUT);
    digitalWrite(rowPins[p], LOW);
    currentRow=p;
  return colPins[key % COL_COUNT];
 * Sends key press event
 * Param keyCode is the keyboard matrix scan code (row * COL_COUNT + col)
void keyPress(int keyCode){
  if (layer_0[keyCode]!=KEY_UNDEFINED){
    Keyboard.press(layer_0[keyCode]);
 * Sends key release event
void keyRelease(int keyCode){
    Keyboard.release(layer_0[keyCode]);
 * Relases all keys in the layer; called upon change of layer, i.e. press or release of FN key
 * Param layer[] array of key codes for the layer to be released
void releaseLayer(int layer[]){
  int i;
    if (isKeyDown(i)){
      keyStatus[i] = DEBOUNCE;
      Keyboard.release(layer[i]);
 * Returns 0 if the specified key is pressed, otherwise a value not equal to 0
 * Param keyCode is the keyboard matrix scan code (row * COL_COUNT * col)
 int isKeyDown(int keyCode){
 if (keyStatus[keyCode]>DEBOUNCE) return 1; else return 0;
Offline jrsmile
Re: simple Keyboard debugging question
« Reply #1 on: Mon, 27 July 2020, 00:20:33 »
got it workling,
i am using a teensy 4.1
it is so fast that the voltage has no time to sink during row change.
a delay during the key read did the trick
Code: [Select]
    currentRow=p;
  delayMicroseconds(200);
« Reply #2 on: Mon, 27 July 2020, 00:39:42 »
Always makes me laugh when things are too good, not something you expect to see!
Glad you got it working and thanks for documenting the problem and the solution :)
