Author Topic: HHKB Hybrid vs Hybrid Type-S vs Pro Classic  (Read 5733 times)
Offline Pxlp
« on: Mon, 27 July 2020, 23:22:26 »
I'm finally getting a HHKB but after numerous hours of research and listening I can't decide if I want the regular Hybrid, the Hybrid type-s, or the Pro Classic
I like the sound of the Pro 2 a lot as the new models have a more high pitch sound compared to the low pitch of Pro 2 but I need the features that are available with the new models such USB-C, better feet, etc. So i guess which board sounds the most similar to the Pro 2 and or sounds the best
Or would it make more sense to get either the Hybrid or Classic than lube and add silencers or to just get the Hybrid Type-S
Sorry for all the questions
Anyways Thank You and have a wonderful day
Offline rxc92
Re: HHKB Hybrid vs Hybrid Type-S vs Pro Classic
« Reply #1 on: Tue, 28 July 2020, 03:31:40 »
They all should sound pretty much the exact same. Any difference in sound that isn't from silencing is due to wear on the domes over time as there aren't significant changes to the case.
If you need the features on the Hybrid, just get it. You can't really 'add' silencing without a lot of work and buying extra parts, so if you want silenced then just get it stock.
