Author Topic: [In stock]KK Light Wave Switch(Mint Green) - Delivered  (Read 11416 times)
Offline john08099
  • Velocifire MK
    • Mechanical keyboards for typers
« on: Tue, 28 July 2020, 22:18:51 »
Edit: August 5
kk Light Wave Switch 3000 In stock now  ;)
Price: $4.5(10 PCS)
Specs: Linear Switch | 60 grams of Gold Plated Spring | Pre-Lubed |4.0MM TRAVEL | 2.00±0.5MM ACTUATION | 35GF PEAK FORCE| 45±10GF ACTUATION | 65GF BOTTOM OUT
Translucent Housing: PC (Pantone color 3308C) Stem: POM  (Pantone color 7488C)
Manufacturer: Kingkeyboard  Mould: Gateron custom mould
Price: $4(10 PCS)
Preorder Open: July 28, 2020-August 3, 2020(Will close immediately once quantity reaches 20K)
Estimated Delivery: August
« Last Edit: Wed, 19 August 2020, 03:25:36 by john08099 »
Velocifire Website: https://www.velocifiretech.com/
E-mail: John@velocifiretech.com
Make Typing Better | Velocifire
Offline Signature
  • master of puppers
  • * Moderator
  • snoozing
Re: [Pre-order]KK Light Wave Switch(Mint Green)
« Reply #1 on: Fri, 31 July 2020, 05:49:05 »
approved
Offline Clay333
« Reply #2 on: Fri, 31 July 2020, 08:12:51 »
Any chance you could get these with no lube applied from the factory? There are a lot of switches I would like to try but I pass on many of them because of factory lube. I don't mind lubing switches but hate having to wipe off factory lube
Offline Anthixious
« Reply #3 on: Fri, 31 July 2020, 12:06:33 »
Possible typing or sound test? I do have a set of GMK Wavez caps and would love a green keyboard in the future. Green switches would be amazing.
Offline pixelpusher
« Reply #4 on: Fri, 31 July 2020, 12:10:10 »
Just realized these were by gateron and not JWK.  Interesting.  Should sound like a tealios switch if that’s the case.  Can’t tell if that’s polycarbonate or just a very translucent recolor of the normal rgb gateron housing.  Sure looks like polycarbonate.
« Last Edit: Fri, 31 July 2020, 12:17:27 by pixelpusher »
Offline Anthixious
« Reply #5 on: Fri, 31 July 2020, 12:54:02 »
Yep, it's polycarbonate, on the switch housing spec.
Offline pixelpusher
« Reply #6 on: Fri, 31 July 2020, 12:59:19 »
Okay so this seems more than worth it if that’s the case.  Very nice  :thumb:
Offline Anthixious
« Reply #7 on: Fri, 31 July 2020, 13:14:16 »
Just pulled the trigger on x300.
Offline Ashardalon
  • Ashkeebs
    • Ashkeebs Lubing Service & Shop
« Reply #8 on: Fri, 31 July 2020, 14:10:18 »
 Going to pick some up for review!
Offline rooski15
« Reply #9 on: Fri, 31 July 2020, 16:14:25 »
No PCB mount legs on the housing?
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #10 on: Fri, 31 July 2020, 16:23:01 »
Agreed, that might be the thing that makes me pass on grabbing some of these. It's simple enough to clip the extra legs off if you really need the switches to be plate mount, don't get why anyone would make a 3 pin switch for sale loose TBH......
Offline lakeboredom
« Reply #11 on: Fri, 31 July 2020, 18:23:39 »
Double length springs?
Gonna need some info, I can't see any reason someone would want these. Is the housing adjusted for tighter tolerances like Tealios? Will final product have pcb legs? Will there be factory lube applied?
Offline pixelpusher
« Reply #12 on: Fri, 31 July 2020, 19:24:53 »
Lool!  Those springs!  So many questions on this one.  Also, the Pantone for housing and stem listed are identical? Is that a typo?  Are the renders wrong?
Offline john08099
  • Velocifire MK
« Reply #13 on: Mon, 03 August 2020, 02:47:58 »
Yes, we will consider it next time  ;)
Offline john08099
  • Velocifire MK
« Reply #14 on: Mon, 03 August 2020, 20:38:28 »
Looking forward to your review. Thanks for your support!
Offline john08099
  • Velocifire MK
Re: [In stock]KK Light Wave Switch(Mint Green)
« Reply #15 on: Wed, 05 August 2020, 05:09:54 »
In stock now  :thumb:
Offline KVLT
« Reply #16 on: Wed, 05 August 2020, 06:00:28 »
Already jump d on the GB!! Exciting news!
Only problem is the gb for my HS tkl is suspended.
the bad guy wins in this one
Offline john08099
  • Velocifire MK
« Reply #17 on: Wed, 05 August 2020, 23:09:13 »
Thank you, we already received the switches and preparing and packing to start delivery in 3-4 business days.
Offline john08099
  • Velocifire MK
« Reply #18 on: Mon, 17 August 2020, 21:39:02 »
Delivered, you will receive tracking in 2-3 business days :)
