Author Topic: Model M QMK PS2 to USB converter  (Read 3591 times)
Offline DzR
« on: Wed, 29 July 2020, 12:07:20 »
Hello,
I've spent the past few days researching the subject but I can't find a definite answer.
I'm trying to convert a PS2 Model M to USB using a Pro Micro using the original IBM controller. I managed to get Soarers working but I'd like to use QMK.
I used the qmk configurator with the "converter/modelm101" keyboard but it's not working. Do I need to resolder the wires to different pins, am I using the wrong keyboard or what am I missing?
Offline hyto
Re: Model M QMK PS2 to USB converter
« Reply #1 on: Thu, 24 September 2020, 14:43:01 »
Have you been able to make it work with qmk?
I'm having the same problem.
Offline DzR
« Reply #2 on: Thu, 24 September 2020, 15:48:54 »
Ive given up on qmk as it seems there isn't a proper converter available, or at least there wasn't when I was looking around.
I even asked on the qmk discord server but I still wasn't able to make it work.
I'm using "tmk_keyboard/converter/ibmpc_usb" that I was able to configure. Only downside is that I'm not able to setup a hotkey to reboot to bootloader. There was a post on reddit that claimed to fix it but that didn't work.
