Author Topic: Anyone knows if the Rama Kara is going to be a kit or just the case?  (Read 2226 times)
Offline ThePotatoCouch
Title. Intending on getting that cause of looks, but I'm not sure if the $160 price tag is for the case itself or for the entire kit. Has Rama ever launched just a case without a PCB? Just wanted to know. Thanks
Offline Rob27shred
  • Insane in the Membrane! 👻
Re: Anyone knows if the Rama Kara is going to be a kit or just the case?
« Reply #1 on: Sat, 01 August 2020, 06:31:08 »
The Kara will be a kit that comes with everything but stabs & switches. I don't think Rama ever launched just a case TBH, unless you want to count the M65a. Which Rama made just the case for then Jchan had some terrible PCBs made to go with the kits.
