Author Topic: High-Speed internet on WFW 3.11?  (Read 5879 times)
  • Live long and prosper
« on: Thu, 15 July 2010, 19:06:27 »
Just installed Windows for Workgroups 3.11, with IE 5.01, and an ethernet card.  Is it even possible to get it on the internet via high-speed internet?  EIBM might have some info... maybe?
tp thread is tp thread
« Reply #1 on: Thu, 15 July 2010, 19:18:50 »
I have all of those, except I don't know how to manually configure the DCHP for my router.
« Reply #2 on: Thu, 15 July 2010, 19:51:13 »
ok well then I have an issue, because the DCHP is set for auto and I have TCP/IP installed and IE 5.01, and nothing happens in IE.  Advice on another web browser?
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #3 on: Thu, 15 July 2010, 20:02:30 »
Windows 3.1 can handle only up to IE5.01.
« Reply #4 on: Thu, 15 July 2010, 20:06:02 »
I know for a fact that there is no IE 6 for WFW 3.11, and yes, the lights on the ethernet card are on and flashing.  If it helps for diagnostic purposes, I have a Netgear router and the ethernet card I am using is a SOHOWare 10/100.  I doubt that will be of any help though.  I will try another browser.  If that doesn't work I will post and update soon.
« Reply #5 on: Thu, 15 July 2010, 20:14:47 »
I got the driver right from SOHOWare and it had a folder labled "WFW311", and I just coppied all tose files to a floppy and then installed them in Windows.  It seemed there was nothing wrong with the driver installation, but I could be wrong.  That was yesterday, and I have enough trouble remembering what I said 10 minutes ago, so...
Offline D-EJ915
« Reply #6 on: Thu, 15 July 2010, 20:55:19 »
I wouldn't bother with DHCP on that, it might not like your router, open up TCP/IP and set the address manually.  Other than that make sure your DNS is working and set up correctly on the machine.
Offline EverythingIBM
« Reply #7 on: Fri, 16 July 2010, 01:37:36 »
Quote from: Computer-Lab in Basement;203146
I've never really used windows 3.1 (I've always been a windows 98 guy), and secondly, I HATE NETWORKS. I am able to set up networks and all that, but half of the time I really have no clue what I'm doing. I just get it working through trial-and-error.
Printers & networks are a pain to get working on older computers.
« Reply #8 on: Fri, 16 July 2010, 18:10:11 »
Ok, having just turned on my Windows 3.11 machine, I just discovered that it is indeed connected to the network, I was able to access it on my network from my Windows 7 computer.  However, it still won't connect to the internet.  Any ideas why?
« Reply #9 on: Fri, 16 July 2010, 18:12:29 »
Quote from: Computer-Lab in Basement;203438
Try some different browsers. Check your proxy. etc.
« Reply #10 on: Fri, 16 July 2010, 18:16:24 »
Quote from: kishy;203442
Well, that's definitely a good sign.
Uh...hmm. What I would try (not knowing if such options even exist, tbh) would be to open IE, Tools > Internet Options (or w/e it's called), then the Connection tab and if given the option, set up the connection as a LAN connection which is always on and requires no username or password.
EIBM: not quite right. Internet access is handled by the application in pre-Win95 so it's going to be settings in the browser just to get even basic connectivity. No browser is likely to do it automaticallly.
That's weird. So what if you wanted to play Warcraft 3? It would be handled by IE???
« Reply #11 on: Fri, 16 July 2010, 18:19:24 »
I think Warcraft 3 might require Windows 95.
Offline TexasFlood
« Reply #12 on: Fri, 16 July 2010, 18:20:25 »
Well if you have a home router any equipment on the router same subnet will see each other just by ARPing, no routing required really.  To get to the Internet you're going to have to route out through the gateway so perhaps you don't have the correct default gateway?
« Last Edit: Fri, 16 July 2010, 18:24:33 by TexasFlood »
« Reply #13 on: Fri, 16 July 2010, 18:21:56 »
ok thanks for the help guys, I got it working.  I made this post from Windows 3.11!
« Reply #14 on: Fri, 16 July 2010, 18:25:18 »
Good job!
