Author Topic: Acquired first Model M. A few questions.  (Read 3883 times)
Offline n3rrd
« on: Fri, 16 July 2010, 08:19:39 »
Hey guys,
So I recently snagged a Model M 1391401 off of eBay for about $35 with shipping.  I received it last night and the board is in pretty good condition;  no stains, just crumbs, and dust, etc.  I played around with it for a bit before starting to pull key caps for cleaning.  The only bummer was that the alt and ctrl key caps are blue/red, and the shift keys are green.
Is it normal for some of the springs to sit rather loosely in the barrels once the key caps are removed?  To the point that they tip over and lean against it?
All of the springs in the bolt mod thread seem to sit mostly centered in the barrels.  The first key I noticed it on was my right shift key, so I replaced the key cap to see how it felt compared to the other and, while it still worked, it definitely didn't have the same click.
I haven't been able to take it apart, but I'm heading to Princess Auto to grab a hex key tonight (none of my sockets will fit far enough down to reach the screw heads).
Also, would anyone have spare Ctrl, Alt or Shift key caps that they'd be willing to part with?  :P
Offline microsoft windows
  • Blue Troll of Death
  • President of geekhack.org
    • Get Internet Explorer 6
« Reply #1 on: Fri, 16 July 2010, 08:24:19 »
Are the keys themselves colored or just the text? I might be able to do a trade-in.
Offline n3rrd
« Reply #2 on: Fri, 16 July 2010, 08:29:14 »
The whole keys are colored.  The ctrl keys are blue and the alt keys are red, both have white pad printed text.  The shift keys are green and I'll have to double check how the label is applied to those.
Offline mcdonc
« Reply #3 on: Fri, 16 July 2010, 09:19:54 »
The springs move around a good bit, it's normal that they flop whichever way you have the keyboard propped.
Owned: bunches of Model Ms,  Model F AT, Dell AT101W, Amiga 500.
Offline mcdonc
« Reply #4 on: Fri, 16 July 2010, 09:22:13 »
I bought this from Amazon to take out the 5.5mm bolts:
http://www.amazon.com/gp/product/B00144HOW8/ref=oss_product
People seem to have problems finding something that will work retail.  I didn't even try.
Offline EverythingIBM
« Reply #5 on: Fri, 16 July 2010, 09:22:42 »
Quote from: n3rrd;203297
A lot of people like those coloured keys you know.
I just like plain beige, but it sure makes certain keys easier to see.
Offline n3rrd
« Reply #6 on: Fri, 16 July 2010, 10:04:37 »
I thought I had replied again but apparently the post got eaten, or I discarded it by closing a tab.
mcdonc, thanks for posting that link.  I'm going to pick up a set that's slightly more expensive and has a 5.5mm hex key in it just because it's local and will be faster than waiting for something to get shipped.
You say the springs normally flop around?  Are they not attached to the hammer?  If so, I'd assume the hammer moves too... maybe the spring wasn't sitting correctly when I put the key back on.  I'll have to double check.  I'll learn more once I crack the board open.
EverythingIBM, I can understand why some people would prefer coloured keys for visual cues.  I don't look at my keyboard very often, but when I do, the brightly coloured keys scream "look at me, look at me."  Meh.  Not a life or death predicament either way.
Offline mcdonc
« Reply #7 on: Fri, 16 July 2010, 10:17:08 »
Quote from: n3rrd;203315
Be careful; apparently sets that say they have a 5mm hex key sometimes aren't thin enough to fit into the deeper holes for the three screws nearest the sides.
The springs are attached to the hammer.  It's just that the hammer itself has a bit of play in the barrel.  But at this point, we're probably talking about two different things.  I thought the question was in general, not about one specific spring behaving differently.
Offline quadibloc
  • Layout Fanatic
    • John Savard's Home Page
« Reply #8 on: Fri, 16 July 2010, 17:50:33 »
Quote from: n3rrd;203292
Oh, yes, that is completely normal.
« Reply #9 on: Fri, 16 July 2010, 17:52:45 »
Quote from: quadibloc;203415
Is it normal to see them dancing around and spring out at you?
Offline ch_123
« Reply #10 on: Fri, 16 July 2010, 17:53:02 »
You could even say that the keyboard would not work otherwise...
« Reply #11 on: Fri, 16 July 2010, 18:00:56 »
Quote from: ch_123;203420
Hey look, tactile seats:
They buckle when you sit down.
Offline TexasFlood
« Reply #12 on: Fri, 16 July 2010, 18:02:28 »
Quote from: EverythingIBM;203426
Clickly buckling spring seats that hammer your face into the floor?  Cool...
  • Live long and prosper
« Reply #13 on: Fri, 16 July 2010, 18:02:52 »
Imagine if there was a keyboard large enough for those springs to fit in...
tp thread is tp thread
« Reply #14 on: Fri, 16 July 2010, 18:05:51 »
It wouldn't be ergonomic.
« Reply #15 on: Fri, 16 July 2010, 18:06:24 »
Quote from: microsoft windows;203433
Sure it would! For apple's standards.
Offline sam113101
« Reply #16 on: Fri, 16 July 2010, 20:30:13 »
Quote from: kishy;203435
Not sure I like the layout though.
why is God using CRT monitors anyway
Hoping to hear from you again, your dearest friend, sam113101.
« Reply #17 on: Fri, 16 July 2010, 20:39:18 »
Quote from: sam113101;203479
Because Satan uses widescreen LCDs. Even ask MW.
