Author Topic: How durable are sublimation legends?  (Read 6470 times)
Offline 32kms
  • computer engineer
« on: Thu, 06 August 2020, 14:58:34 »
I have a question, I want to make a design and print it by sublimation, but how long would the legend print last?
Re: How durable are sublimation legends?
« Reply #1 on: Thu, 06 August 2020, 16:33:37 »
With industrial-grade equipment, it is extremely long-lasting.
- D Trump 2026-10-24
Offline Rob27shred
  • Insane in the Membrane! 👻
« Reply #2 on: Thu, 06 August 2020, 17:01:28 »
Yep, if done properly with the proper equipment dye subbed legends will last a lifetime practically.
Offline Pyk_
« Reply #3 on: Thu, 06 August 2020, 21:10:04 »
I believe the idea is the dye actually sinks into the plastic and becomes part of it, so in order for them to wear off you have to wear down the plastic itself.
Offline Pylon
« Reply #4 on: Sat, 08 August 2020, 01:30:31 »
I've seen a Model F with shiny keycaps and somewhat faded legends, so it is possible to wear dye sub off, though it will take a long, long time to wear dye-sub legends off PBT.
