Author Topic: What is the best barebones keyboard kit. (Case, pcb, mounting plate included)  (Read 7587 times)
Offline Bobbals
    • @pump_upp - best crypto pumps on telegram !
I would like to know what the best case that comes with a pcb and mounting plate. I have my own keycaps and switches. I don't want to have to build anything and it should be hotswap(I do not have a solder kit). Thanks for the suggestions in advance! I also quite like 75% boards and do not have enough switches to do a full 104 but I can order more and just use the alpha keys and order new ones.
« Last Edit: Fri, 14 August 2020, 16:44:41 by Bobbals »
Offline treeleaf64
    • treeleaf64
Look @ kbdfans
Everyone must pay the cat tax
Offline Bobbals
Thanks so much I found a board that I like quite a bit.
Offline Error213
Personally I’m a huuuge fan of the gmmk and nk65 entry however they both aren’t 75% I recommend kbd75v2
« Last Edit: Sun, 16 August 2020, 15:02:01 by Error213 »
Offline scottishdrum
    • granny
Where can I buy the full set?
Offline Error213
I don’t get the question. Did you quote the wrong comment or are u talking about full size
