Author Topic: Apple keyboard M3501 with Mitsumi switches  (Read 2299 times)
Offline winteralfs
« on: Sat, 15 August 2020, 01:53:11 »
I purchased a sight-unseen M3501 Apple extended keyboard 2 and it turned out to have Mitsumi 2 tactile switches. What can I do with those switches? Can I desolder them and use them on a modern aftermarket Alps PCB for a custom board the same way other modern custom Alps boards are made?
Re: Apple keyboard M3501 with Mitsumi switches
« Reply #1 on: Sat, 15 August 2020, 05:02:22 »
No, the Mitsumi switches have a different pinout from Alps. I have never seen a custom PCB that would fit them.
The switches do fit in plates made for plate-mounted Cherry MX so you could use one and hand-wire the keyboard matrix.
I dunno about the stabilisers for the larger keys. I suspect that it uses Alps-style stabilisers like in AEKII with Alps switches, in which case a Cherry MX plate wouldn't work. You could check!
« Last Edit: Sat, 15 August 2020, 05:04:53 by Findecanor »
Offline mode
« Reply #2 on: Sat, 15 August 2020, 05:50:36 »
Mitsumi switches are not very good. I don't often advocate for breaking up vintage boards, but, I wouldn't feel too bad about swiping the keycaps off it, and buying some genuine alps and using them on a modern build.
« Reply #3 on: Sat, 15 August 2020, 11:49:50 »
Have you even tried these ones?
Offline Sup
« Reply #4 on: Sat, 15 August 2020, 19:46:18 »
You just where unlucky. I would say buy aek keycaps and some alps switches
current
Coming soon
