Author Topic: [IC] ePbt - Be The One - GB February 1st!  (Read 193872 times)
Offline SirTimmyTimbit
Re: [IC] ePbt - Be The One
« Reply #100 on: Tue, 01 September 2020, 09:52:56 »
Any chance you'd consider putting the green legend on any other key instead? Cause in HHKB the colors are pretty red/yellow-ish
Red appears on 3 rows. Two shades of yellow appears twice. Red, brown, yellow and purple they all look kinda similar.
« Last Edit: Tue, 01 September 2020, 09:55:45 by SirTimmyTimbit »
Offline zekth
« Reply #101 on: Tue, 01 September 2020, 10:33:55 »
There is green on ESC also. But on HHKB you can put Super instead of ALT here.
Offline ideus
  • Björkö.
« Reply #102 on: Tue, 01 September 2020, 10:40:54 »
You should take advantage for the opportunity to improve some of the euro legends that ePBT has wrong, like ´`| and ¨^~ keys. Make them closer to GMK to get them right.
Offline zekth
« Reply #103 on: Tue, 01 September 2020, 10:51:29 »
I did a lot of work on alignments on the whole template regarding legends.
What's the issue with those legends? The size?
Offline zekth
« Reply #104 on: Tue, 01 September 2020, 10:56:27 »
Not a deal breaker at all, but could it be possible to have Alt Gr keys?
i've thought about it yes but the issue is it will add too much keys in Base / Rainbow / Mono kits :/ sorry
Offline ideus
  • Björkö.
« Reply #105 on: Tue, 01 September 2020, 17:37:11 »
I will post some pictures later for the main offenders, for you to analyze them and decide if they worth a fix.
Offline evanh
« Reply #106 on: Tue, 01 September 2020, 18:28:52 »
Very interested depending on price! One Dark Pro is my go-to.
Offline konstantin
  • Formerly constexpr
« Reply #107 on: Thu, 03 September 2020, 11:06:24 »
Caveats of using Super instead of Alt: it wouldn't be the correct legends for people who aren't on Mac, and it still doesn't fix the issue of the set not having enough green in this case (which I agree that it doesn't).
Perhaps it would be reasonable to make the R3 1.75u Control key green instead? I believe this would be a satisfactory solution for everyone.
Edit: Here's a mockup of what I mean, before vs after:
« Last Edit: Thu, 03 September 2020, 12:31:44 by konstantin »
Offline Ramen Champ
« Reply #108 on: Thu, 03 September 2020, 12:17:41 »
Absolutely love the rainbow modifier set
twitch.tv/ramenchamp_
Offline zekth
« Reply #109 on: Fri, 04 September 2020, 01:57:49 »
Indeed r3 control looks like a cool trade off. Personnaly i like both i don't really mind and even if you still want red you can keep the Caps Lock icon cap.
Offline roguesystem087
« Reply #110 on: Fri, 04 September 2020, 02:01:09 »
any idea on when this is starting?
Offline zekth
« Reply #111 on: Fri, 04 September 2020, 03:45:59 »
Pricing?
Regarding those question, nothing will be done untill i got the samples.
Offline tehfrawg
« Reply #112 on: Fri, 04 September 2020, 13:38:59 »
Any chance of a set of white, err light-theme, alphas to go with this?
Offline Kawamashi
« Reply #113 on: Sat, 05 September 2020, 13:08:56 »
Wow, so in for the Bépo kit !
Would a Ergo kit be possible ?  ;)
Offline DrHigsby
  • The doctor is in.
« Reply #114 on: Sat, 05 September 2020, 17:46:15 »
I’d love to see a mono 40s kit.  :cool:
Offline zekth
« Reply #115 on: Mon, 07 September 2020, 12:40:58 »
R3 control has been modified
Offline konstantin
« Reply #116 on: Mon, 07 September 2020, 12:47:29 »
Offline vladimir108
« Reply #117 on: Wed, 09 September 2020, 16:42:28 »
Just idea: add also special "WASD" keycaps into the "Be the navigator" in same colours as "HJKL" or "[;'/"
Offline xc0mr4de
« Reply #118 on: Tue, 15 September 2020, 08:31:13 »
when is it estimated to be on GB? 2020/2021?
Offline zekth
« Reply #119 on: Tue, 15 September 2020, 09:12:23 »
https://geekhack.org/index.php?topic=108119.msg2949321#msg2949321
Regarding the time frame of the potential GB, i don't think about it untill i got the samples to check if this is possible with ePbt. When i have an idea i'll post it.
Offline Darthbaggins
  • PC Cannibal
« Reply #120 on: Tue, 15 September 2020, 10:17:08 »
I'll take a set -  :thumb:
Offline zekth
« Reply #121 on: Sun, 20 September 2020, 03:38:03 »
Just made a minor modification to space and 40 kit. Adding legends as caps will be convex
Offline stoffelduss
« Reply #122 on: Sun, 20 September 2020, 07:23:47 »
ooooh this is sick! I'll take one with the alternative layouts kit  ;D
Offline i luv chuletas
« Reply #123 on: Sun, 20 September 2020, 09:04:35 »
Super cool set! Love the compatability in the 40s kit as well. Will be keeping an eye out on this for sure!
Offline Parchment
« Reply #124 on: Thu, 24 September 2020, 03:30:54 »
This looks fantastic, great job! I'm definately in, new to GBs and this vommunity, any ideas on pricing for a base kit?
Offline Rivazza
« Reply #125 on: Wed, 07 October 2020, 11:47:56 »
Looks great. Definitely interested in the Base, Monos, and Frozen North kits.
Offline kennsama93
« Reply #126 on: Thu, 08 October 2020, 11:36:01 »
Hi there, have you ever considered making a 1.5u (if I'm not mistaken) FN key for the upcoming Bella kit by KBDFans?
I am interested in this keycaps set but it seems that it is missing the support for the FN key in Bella.
Offline konstantin
« Reply #127 on: Thu, 08 October 2020, 18:20:19 »
That keyboard is fully programmable, so you can assign that key to whatever you like. Most people use 1.5u Alt, not Fn, on layouts like that.
Welcome to Geekhack, by the way.
Offline kennsama93
« Reply #128 on: Fri, 09 October 2020, 12:25:20 »
Thank you for the advice! I am new to the mecha keyboard scene so I appreciate any advice I can get from the community.
Offline zekth
Re: [IC] ePbt - Be The One - Waiting for samples!
« Reply #129 on: Sun, 25 October 2020, 04:56:32 »
Since i got asked few times lately, clarifying the current situation of this project.
  • Waiting for samples with the new ePbt tooling for reverse dyesub
  • Ergo kit is planned
  • No date of GB / shipping estimations untill the prototypes are validated
  • Some Collabs planned
  • Will there be a deskmat? Maybe
Offline dibstern
« Reply #130 on: Sun, 25 October 2020, 17:55:50 »
Keen! Looks like my first navy keycap set :)
Offline harlekein
« Reply #131 on: Tue, 27 October 2020, 08:41:58 »
I didn't expect to see a Colevrak kit here! Now I'm intrigued!
Offline REMAKEGKD
« Reply #132 on: Tue, 27 October 2020, 17:25:08 »
when will these be available, I’m so excited about this set
Offline CountKeepo
« Reply #133 on: Thu, 29 October 2020, 22:12:35 »
Made an account just for this set. Looks amazing, can't wait for updates.  :thumb:
Offline treeleaf64
    • treeleaf64
« Reply #134 on: Thu, 29 October 2020, 22:16:00 »
Looks cool enough
But a little similar to monokai material
Everyone must pay the cat tax
Offline zekth
« Reply #135 on: Fri, 30 October 2020, 04:08:32 »
Looks cool enough
Why choose ePbt? Because the MOQ policy is way more flexible for child kits with less popularity like FR/BE/Norde/dvorak and so on. This set without this compatibility makes no real sense to me as i mainly made it for people not being able to get for example GMK Oblivion / Nord which are in the same tones / theme.
 :confused:
Offline dstaar
« Reply #136 on: Sat, 31 October 2020, 03:25:27 »
will GB of this take place before end of the year?
Offline zekth
« Reply #137 on: Sun, 01 November 2020, 04:37:04 »
Definitely not. I'm still waiting for the samples to be validated.
Offline dibstern
« Reply #138 on: Mon, 02 November 2020, 01:35:20 »
Another reason for this set -> PBT instead of ABS. I don't feel comfortable sinking more money into ABS sets until someone figures out a way to prevent shine.
Also, I know this is probably waaaay too late zekth, so feel free to disregard this, but I do love the way that the classic GMK legends were fixed in KAT Refined, to make them sharper and more legible. If that were possible for this, even in a R2, it would be legit.
Offline Scriba
« Reply #139 on: Fri, 20 November 2020, 06:38:59 »
read again, it's not about PBT or ABS, it's about that ePBT is producing it. Inifikey has proven that they have mastered reverse dyesub perfectly (e.g. pbt hive).
Offline krzank
« Reply #140 on: Fri, 20 November 2020, 07:27:51 »
I'm in for BASE/MONO/COMPACT/FRENCH (maybe also UK?)
Offline arkze
« Reply #141 on: Fri, 20 November 2020, 08:33:42 »
Legends were crisp but the color matching was off... It was supposed to be dark blueish gray and they were just as black like my other black pbt keycaps. I was able to sell them with profit luckily.
Offline Scriba
« Reply #142 on: Fri, 20 November 2020, 08:55:21 »
You need experts for color matching, like dixiemech for example has.
Offline Scriba
« Reply #143 on: Mon, 23 November 2020, 08:43:40 »
after checking this, yea you're right. the reverse dyesub and legends were good but the color matching was off. that's a big off if you want blueisch/gray keycaps and get black ones...
Offline TheCaptain
  • I come in 3 sizes: Large, Extralarge and Big Daddy
« Reply #144 on: Tue, 24 November 2020, 18:22:16 »
Definitely getting this but what about a Be the Pizza kit with Iso IT accented vowels?
Offline Martakia
  • Sup.
    • FL Discord
« Reply #145 on: Tue, 24 November 2020, 19:58:33 »
Looking forward to this :D
Offline ideus
  • Björkö.
« Reply #146 on: Wed, 25 November 2020, 10:59:40 »
I am very tempted to join this: The set has nice colors, the material is shine-proof, and the vendors (KBDFans) have very competitive shipping costs. Above all, it includes a Nord set. Just hoping for a proper edition of some of the legends that have always being off the actual OG reference.
Offline Razer1987
« Reply #147 on: Wed, 25 November 2020, 17:39:17 »
In for most of the mods + iso-fr !!!
Offline azhdar
  • Praise the AZERTY god
« Reply #148 on: Thu, 26 November 2020, 10:34:00 »
following this
Azerty Propagandiste
Offline krzank
« Reply #149 on: Mon, 30 November 2020, 01:36:03 »
if people interested in other language i'm willing to add those if enough people interested in.
If cyrillic with R3:Tilde/GraveAccent/Ё, count me in.
If arabic with R3:Tilde/GraveAccent/ذ, count me in.
I assume the R4:Pipe/Backslash will be available through UK-ISO.
