Author Topic: KC87 Keyboard with Pudding keycaps  (Read 9146 times)
Offline KPrepublic
  • * Moderator
    • KPrepublic
« on: Fri, 21 August 2020, 05:41:00 »
SPEC
Dual Mode-Bluetooth 5.0+Cable Mode​
Hot Swappable Sockets
Cable Length- 150cm ± 2cm
Keycap-  Pudding PBT Doubleshot keycaps
Button Number- 87
Back Light- 16.8 million RGB
NKRO- Yes
Compatibility- Windows 2000/XP/Win7/8/10, Mac etc
Connection- Type-C USB detachable, plug and play
Switch- Gateron (Hot swappable)
Working Voltage- 5V ≤ 500mA
Battery-2700mAh
Wired mode & Bluetooth mode switching instruction
Turn battery button on, press FN+Tab to enter Bluetooth mode, press FN +Q\W\E to choose 1 device mode(it can connecnt with 3 different devices), then press FN+P for 5 seconds to enter Bluetooth Pairing Mode, P key will be blinking, finally open device bluetooth and search KC87 keyboard to connect it:)
Fn Key Func
FN+Up Arrow=Brightness +
FN+Down Arrow=Brightness -
FN+Left Arrow=RGB Light Speed -
FN+Right Arrow=RGB Light Speed +
Fn+Ins=Open/Close Backlit
Fn+PgUp=RGB Light Cycle Mode
FN+PgDn=Single Color Light Cycle Mode
Fn+Win=Lock\Unlock Win
Fn+Spacebar for 3 sec=Factory Data Reset
Fn+Tab=Cable/Bluetooth Mode Change
Fn+S=MAC OS Mode
Fn+A=Windows Mode
Offline KPrepublic
  • * Moderator
    • KPrepublic
Re: KC87 Keyboard with Pudding keycaps
« Reply #1 on: Fri, 21 August 2020, 05:41:49 »
Purchase here
